.029" straight pins for body mounting
11 replies to this topic
#1 John Gorski
John Gorski
  • 2,228 posts
Posted 11 October 2018 - 03:11 PM
Anyone know who has .029" OD undersize straight pins and who makes a strong .035" drill bit to fit a regular chuck hand drill?
John Gorski, Jr.
#2 John C Martin
John C Martin
    J.C Martin
  • 1,066 posts
Posted 11 October 2018 - 03:43 PM
Walmart has some really small dia pins. Also some big head pins.
#3 Dave Crevie
  • 1,345 posts
Posted 11 October 2018 - 04:05 PM
If you are only going to shop hobby shops, X-acto has drill bits even smaller than that. They only come as strong as they are.
They are HSS. I don't break too many of them.
#4 tazman
tazman
  • 248 posts
Posted 11 October 2018 - 05:21 PM
Wall mart has some really small dia pins also some big head pins..
I just got some pins from Walmart to pin 1/24 bodies and for pinning my HO chassis at the rear axle.
Sent from my SM-N950U using Tapatalk
  • John C Martin likes this
Rick Ortogero
#5 wbugenis
wbugenis
  • 325 posts
Posted 11 October 2018 - 05:56 PM
Steinlauf & Stoller - not many stores like this around any more:
http://www.steinlauf...lk Straight.htm
  • C. J. Bupgoo likes this
William Bugenis
#6 Dominator
Dominator
  • 2,186 posts
Posted 11 October 2018 - 06:11 PM
Irwin makes small bits also. I use a .032 or .035 for cleaning out the pin tubes.
  • A. J. Hoyt likes this
Dominic Luongo
NERR photos from 2016 to now
#7 Phil Hackett
  • 4,761 posts
Posted 11 October 2018 - 07:38 PM
Anyone know who has .029 OD under size straight pins &
who makes a STRONG .035 drill bit to fit a regular chuck hand drill?
By asking that the drill "fit" a hand drill chuck, are you looking for something with a, say, 1/8 shank and then the .035 (#65) drill size ground the rest of the way? Those are called circuit board drills... only bad part is they're carbide. I have never seen them in HSS...
#8 havlicek
  • 10,721 posts
Posted 13 October 2018 - 10:03 AM
Hi John,
I don't know where reduced shank very small drill bits can be had, but you can get hex-shank drill chucks to fit your hand drill's "regular" 1/4" or "3/8" chuck.  These should be able to hold down to 1/32" drill bits or even smaller.
#9 Pablo
  • 14,230 posts
Posted 13 October 2018 - 12:50 PM
I just chuck the tiny bits into the mini-drill bit casing, then chuck the casing into my drill motor.
The OD is .373"so it fits a 3/8" chuck.
  • olescratch likes this
#10 Zippity
Zippity
  • 4,738 posts
Posted 13 October 2018 - 03:45 PM
I purchased a StyleX (DT-626) Drill Bit Kit in Seoul, Korea, last week for about $13 US  :)
It contains 14 bits ranging in size from .02 to 1.5 mm in 0.1 increments.
The 0.7 mm bit equals 0.02755"
Ron Thornton
#11 John Streisguth
John Streisguth
    Johnny VW
  • 4,909 posts
Posted 14 October 2018 - 05:52 AM
Carbide will break if you bend it at all while drilling.  You may want to try a cobalt drill bit, wire size #65.
You can order them from McMaster Carr, part#
3033A282
"Whatever..."
#12 Zippity
Zippity
  • 4,738 posts
Posted 16 October 2018 - 02:55 PM
Micro-Mark sells 6-packs of drills in sizes from #80 upwards.
https://www.micromar...in-vises?page=2
Ron Thornton
