Gear ratio misstep
25 replies to this topic
#1 Uncle Fred
Uncle Fred
  • 1,367 posts
Posted 30 November 2018 - 12:29 PM
Recently, at the "Texas Two Step" at Dallas Slot Cars I had a very poor performing Can Am.  It had poor straightaway speed and no punch through the corners. We run PS4002FK motors with mandated 8 tooth pinions.  I had replaced the springs with Champion lights (Red) and radiused Mura Big Foot brushes and broke it in accordingly.  My car weighed in at 114 Grams and everything was in good order, bearings good, gear mesh good....  The day after I tore the car down looking for a motor problem.  I found that I had inadvertantly installed a 7 Tooth Pinion on the motor!  Coupled with a 30 tooth crown for an insane gear ratio!  But why wouldn't the car accelerate? Was the 7/30 .810 tire combo too much for such a low torque motor to handle? Especially on a flat track?  What do you guys think?
Fred Correnti
#2 MSwiss
  • 25,904 posts
Posted 30 November 2018 - 12:40 PM
I wouldn't call a 4002FK a low torque motor.
Did you have any push start issues?
If so, possibly you lost a pole, and the motor is flat because of it.
#3 Uncle Fred
Uncle Fred
  • 1,367 posts
Posted 30 November 2018 - 12:44 PM
No push start issues.  The motor sounds good and runs cool...…..
Fred Correnti
#4 swodem
swodem
  • 1,176 posts
Posted 30 November 2018 - 02:59 PM
Gearing just too low
Actually gearing isn’t that low given your large tyres
Must just be a dud motor
Steve Meadows
#5 MSwiss
  • 25,904 posts
Posted 30 November 2018 - 03:18 PM
I thought of the same thing, but with a racer as experienced as Fred, it seems like he would feel a touch of acceleration.
Did the car have massive brakes?
Regardless, you'll find out more when you try the motor again, geared correctly.
#6 Pablo
  • 18,448 posts
Posted 30 November 2018 - 04:40 PM
I think you should give the motor an 8T and foggettaboutit.
Don't overthink why a wrong gear ratio does the opposite of what you'd think.
They do that sometimes. Been there done that got the tshirt :)
#7 Uncle Fred
Uncle Fred
  • 1,367 posts
Posted 30 November 2018 - 06:55 PM
No the brakes seemed about the same but the motor was so cool after 7 heats you could touch it with your tongue...……...NOT :shok:  :crazy:  that I would suggest that.   I'm just thinking that an FK type motor in a heavy car just can't pull that kind of gear coming off a slow corner.
Fred Correnti
#8 gotboostedvr6
  • 2,321 posts
Posted 30 November 2018 - 09:22 PM
Take A pic of the brush faces.
If they look like this you need to true the comm.
Screenshot_20181130-212128_Gallery.jpg Screenshot_20181130-212047_Gallery.jpg
David Parrotta
#9 Uncle Fred
Uncle Fred
  • 1,367 posts
Posted 01 December 2018 - 12:39 AM
Sealed motor.
Fred Correnti
#10 tonyp
  • 15,325 posts
Posted 01 December 2018 - 06:57 AM
Sounds just like the gearing was out of the power band of the motor.
  • Uncle Fred and Eddie Fleming like this
#11 gotboostedvr6
  • 2,321 posts
Posted 01 December 2018 - 07:24 AM
I never said you had to take off the seal. It can be done pretty easily without touching the seal
David Parrotta
#12 MSwiss
  • 25,904 posts
Posted 01 December 2018 - 07:59 AM
Yes, Fred.
Every slot racer has a comm lathe set up to true comms inside a sealed motor.
It should be in your box, in the drawer next to the Allen wrench and bottle of oil. Lol
#13 Uncle Fred
Uncle Fred
  • 1,367 posts
Posted 01 December 2018 - 08:44 AM
Next  you'll be telling me you can rewind the arm without taking it out! LOL You can't, ……..can you? :o
Fred Correnti
#14 gotboostedvr6
  • 2,321 posts
Posted 01 December 2018 - 09:37 AM
Need videos?
David Parrotta
#15 gotboostedvr6
  • 2,321 posts
Posted 01 December 2018 - 10:11 AM
Here is a pic or 2
This job takes a few min to complete.
David Parrotta
#16 Uncle Fred
Uncle Fred
  • 1,367 posts
Posted 01 December 2018 - 10:36 AM
And the rewinding?  Just kidding.  Thanks for posting those photos Dave, but the comm on my motor was fine. I'm thinking more along what Tony said, the ratio fell so far out of the power band it just didn't work at all.
Fred Correnti
#17 Eddie Fleming
  • 2,922 posts
Posted 01 December 2018 - 11:34 AM
Truing the com on cheep sealed motors
Is it legal--- sometimes? but probably not.
Is it one of the reasons cheep sealed motors of this type are a farce?--- Yes
#18 Richard G With
Richard G With
    Outside Agitator
  • 281 posts
Posted 01 December 2018 - 02:20 PM
8/29 is generally standard at DSC. I'm surprised that a 30 tooth crown got past tech due to clearance.
I've had PSFK motors at DSC that liked 8/28 if the bite is low enough.
#19 Uncle Fred
Uncle Fred
  • 1,367 posts
Posted 01 December 2018 - 02:35 PM
Your right Richard, thats what I usaually run as well.
Fred Correnti
#20 idare2bdul
idare2bdul
  • 5,799 posts
Posted 02 December 2018 - 12:55 AM
Before changing the pinion consider racing it on a very short track. Or do what I am doing, hand the car to a grandkid so it is too slow to crash.
Mike Boemker
#21 Richard G With
Richard G With
    Outside Agitator
  • 281 posts
Posted 02 December 2018 - 10:06 AM
One of the points about this is that DSC uses RETRO rules which mandates 8t pinion for the ProSlot motor. Apparently it's not a problem if a 7 slips through tech as it will be sort of a self enforcing rule due to the performance hit at DSC.
The rear clearance, under both RETRO and IRRA rules is 050 minimum. With fresh 8125 tires, a Parma 29 is barely legal With some sanding. A 30 tooth Parma crown would not give legal clearance. Go fast and Koford gears are a bit smaller diameter but not enough to allow 30 teeth.
So I contend Fred's car should have failed tech on both pinion and gear clearance.
#22 Uncle Fred
Uncle Fred
  • 1,367 posts
Posted 02 December 2018 - 10:24 AM
Yes!  I intend to rib Ken Stevens about it.
  • Richard G With likes this
Fred Correnti
#23 Ramcatlarry
  • 2,944 posts
Posted 02 December 2018 - 12:26 PM
How far off was the ratio? ---8/28 is 3.5/1;  with a 7T, you would need a 24 or 25 spur.  Even an 26 would not run that good.    Tech should  have caught it.
#24 Uncle Fred
Uncle Fred
  • 1,367 posts
Posted 02 December 2018 - 12:29 PM
7/30= 4.285
Fred Correnti
#25 swodem
swodem
  • 1,176 posts
Posted 02 December 2018 - 11:30 PM
7 or 8 tooth what’s best?
It’s just a matter of a pinion       :D
  • Tex, Uncle Fred and Greg Erskine like this
Steve Meadows
