Riggen 5003 chassis building tips
5 replies to this topic
#1 Steve Adkins
Steve Adkins
  • 210 posts
Posted 03 December 2018 - 07:41 AM
Here's how to brace up the Riggen 5003 chassis to make it a winner. They say that a photo is worth a thousand words and these pictures attest to that.
First, bracing is a must. The Riggen will bend like a cat from Trinidad doing the Limbo Rock. This chassis is recommended for the AWRA classes that allow bracing, even though it has won races in an unbraced state.
The chassis needs to be blueprinted. Like most Womp chassis, the 5003 isn't straight and square. Luckily, the AWRA classes that allow bracing also allow a slew of chassis mods. You will need a jig to properly build a race-worthy 5003. If you don't have one, get one. When you measure the chassis, you will notice that the rear axle towers are off. You will have to even these up before starting with the bracing.
The photos will show you how to properly brace your 5003 for competition. Good luck and remember, "Rubbin' is racin', son." So stay square and stay straight!
The photos and build are by Dean Stewart, who is the AWRA test guy, He checks all the chassis for approval and also builds some super Womps.
Attached File  w1.jpg   92.39KB   15 downloads
Attached File  w8.jpg   76.12KB   9 downloads
Attached File  w2.jpg   71.19KB   10 downloads
Attached File  w3.jpg   52.34KB   8 downloads
Attached File  w4.jpg   58.43KB   8 downloads
Attached File  w5.jpg   48.62KB   8 downloads
Attached File  w6.jpg   35.47KB   8 downloads
Attached File  w7.jpg   77.07KB   7 downloads
  • Pablo, Tim Neja and justDave like this
#2 Pablo
  • 18,495 posts
Posted 03 December 2018 - 09:27 AM
Beautiful work.  :sun_bespectacled:
  • Cheater and Steve Adkins like this
#3 Ramcatlarry
  • 2,956 posts
Posted 03 December 2018 - 10:59 AM
No rear pan stops?  Or crossbar to eliminate chassis flex to be equal to other womp frames?
#4 Troy Beeler
Troy Beeler
  • 69 posts
Posted 31 January 2020 - 10:46 PM
What size wire are you using.
  • Steve Adkins likes this
#5 Steve Adkins
Steve Adkins
  • 210 posts
Posted 23 September 2021 - 04:35 PM
The trick here is strengthening the chassis while retaining the natural flex. Dean Stewart has managed how to accomplish this. This Riggen is solid as a rock but handles nearly as well as some flexi chassis.
#6 Steve Adkins
Steve Adkins
  • 210 posts
.047
