Ultimate Thingie: Pablo Choti Ultra #5 Lenz U-Go Mura
165 replies to this topic
#1 Pablo
  • 15,681 posts
Posted 14 December 2018 - 06:50 PM
Looking for a buyer. This won't be a "budget" car. Even I can't afford it :)
Assembly by yours truly, and body will be painted by Jairus Watson.
Parts shown in this post are original vintage and genuine rare items
  • Jencar17, MSwiss, miko and 5 others like this
#2 Jairus
  • 9,874 posts
Posted 14 December 2018 - 07:02 PM
You found a body then?
Super.
Take my advice and pull down your ....
Wrong advice.
Cut and mount first then send me the body.
K?
#3 Pablo
  • 15,681 posts
Posted 14 December 2018 - 07:18 PM
Trim and mount then send, understood :D
#4 Pablo
  • 15,681 posts
Posted 17 December 2018 - 07:32 PM
Lenz double 27 reverse timed .510" OD .500 stack length armature.
  • Jencar17 and Geary Carrier like this
#5 Geary Carrier
Geary Carrier
    all there...???
  • 584 posts
Posted 17 December 2018 - 08:01 PM
That should spin up quite nicely...
  • Pablo likes this
#6 Pablo
  • 15,681 posts
Posted 18 December 2018 - 06:29 PM
Yuuup :)  Weldun wheels polished and ready for "Mmmmm Donuts"
  • Jencar17, Peter Horvath and Bud Greene like this
#7 Pablo
  • 15,681 posts
Posted 18 December 2018 - 08:35 PM
Recently I had a bad experience with a new-looking Mura endbell on a different car - bushing looked new, so I assumed it was good to go. It turned out to be really sloppy and I caught it in on a track test
http://slotblog.net/...to-be-havlicek/
This time, again, endbell and bushing appear fresh. But I was looking for a sloppy bushing, and I found it.
Probably came from the factory like this. Moral of the story is, "trust, but verify" :)
  • Jencar17 and Peter Horvath like this
#8 SlotStox#53
  • 4,084 posts
Posted 18 December 2018 - 09:23 PM
Wow! UGO bracket and guide thingy, Lenz double wind :heart: long super strong Versitec mags.. looks like you just walked out of a raceway with all the "right" parts :D
One supercharged Choti coming up!!
#9 Martin
  • 1,677 posts
Posted 18 December 2018 - 09:54 PM
Watching your build with interest. Could you show a step by step of the donut gluing and truing  method you use. I have  a lot of wheels that need this. But always put it off.
#10 Bill from NH
  • 11,138 posts
Posted 18 December 2018 - 10:54 PM
Have you tried another bushing in these endbells? Or, is the problem caused by the endbell plastic itself? That is, the bushing bore isn't aligned straight?
#11 havlicek
Posted 19 December 2018 - 07:27 AM
10-4.  These bushings are pretty sloppy right out of the box (*both the Tradeship and Mabuchis), but this one looks to be at least "average".  ;)
#12 Pablo
  • 15,681 posts
Posted 19 December 2018 - 09:39 AM
It's not an alignment issue or an endbell issue; it's a bushing slop issue due to either wear or high tolerance manufacturing. I'll be correcting the issue later today.
Martin, I'll PM you the donut instructions I have :)
Wish Mura hadn't chosen a bastard size for their bushing OD - .165 (11/64).
If it was .157 (4mm) I'd already have an SKF in there :dance3:
#13 dc-65x
  • 5,644 posts
Posted 19 December 2018 - 11:25 AM
I can send you a new old stock and checked for fit bearing. :)
#14 Pablo
  • 15,681 posts
Posted 19 December 2018 - 12:15 PM
That would be super, thanks Capt. Rick :)
#15 Pablo
  • 15,681 posts
Posted 19 December 2018 - 05:41 PM
These pics are for Martin. JK donut tool, 1/8 aluminum tube sleeve, fireworks cone (trimmed to slightly bigger than rim flange OD and small end snipped off to allow 1/8 axle)
Setscrew end towards tool handle
10 second dip, push donut to the hilt, remove cone & sleeve, done
  • Jencar17, olescratch and Geary Carrier like this
#16 dc-65x
  • 5,644 posts
Posted 19 December 2018 - 06:30 PM
Hi Pablo,
I've got some goodies ready to ship. The bearing you needed and a pair of shunted 16D brushes and some "invisible" brush spring insulation in case you're feeling frisky about your motor build. :D
#17 Pablo
  • 15,681 posts
Posted 19 December 2018 - 07:04 PM
Thanks Capt. Rick. I already have the shunted brushes and insulation.
But if you send more I won't complain :D
  • olescratch likes this
#18 Pablo
  • 15,681 posts
Posted 19 December 2018 - 09:11 PM
The setup needs to match the arm, so it's all kind of tricky. Obviously some honing is in order.
My plan for the final hole size is .530
Mags secured in the shim with clips and some micro-squirts of Loctite® CA. Resulting hole mikes about .513
I probably need about a .522 hone in between ......
  • Jencar17 and havlicek like this
#19 Martin
  • 1,677 posts
Posted 19 December 2018 - 09:18 PM
Thanks Paul, got to make me one of those tools.
#20 olescratch
olescratch
    olescratch
  • 903 posts
Posted 20 December 2018 - 01:11 PM
  Pablo, thanks very much for the pics of the donut tool in use.  I avoided buying one because it didn't have cones as big as the rims I wanted to use.  Fireworks cones, I never would have guessed!  Thank you!
John Stewart
#21 Pablo
  • 15,681 posts
Posted 20 December 2018 - 02:47 PM
Mark your calenders, 1 Jan 2019. Get there before the cleanup crews arrive and, "free donut cones everywhere - all sizes" :D If you don't score, send me a PM, I'll get enough for all of us.
If Martin makes some I'm sure they would sell :good:
#22 dc-65x
  • 5,644 posts
Posted 21 December 2018 - 12:24 PM
Pablo, I've got your replacement Mura endbell bearing, shunted brushes and insulation in the mail.
I checked all the Mura bearings I have and they all have a little "slopskee" though not nearly as much as you show in your picture above.
I have some associated "slop free" bearings (pictured on the right) that are a tight fit on the armature shaft and would require some fiddling with to get to work.
The other "mystery" bearing (shown on the left) is a nice fit on the shaft.......maybe a little tighter than the Mura bearing sent.
The Associated brass endbell bearing plate shown is an option for fitting bearings to endbells.
Is any of this stuff something you'd like to fiddle with?  :unknw:
  • Jencar17 likes this
#23 Pablo
  • 15,681 posts
Posted 22 December 2018 - 05:05 PM
I think the stuff you are sending is good for now, thanks Rick :)
Question: were Lenz motors always traditionally painted dark red?
I'm considering tumbling my can and leaving it virgin, with a Lenz sticker.
Would that be sick? :shok:
Body, I located a very rare new Truescale, and I'm thinking dark red with a black accents fade, with maybe some gold.
Or black with fade to dark red accents.
My doggone .522 hone should arrive soon :dance3:
#24 dc-65x
  • 5,644 posts
Posted 22 December 2018 - 07:08 PM
Okie Dokie Pablo.
Lenz motors were painted in more colors than I know of. Sometimes I think Lenz and Mura painted their motors with whatever spray cans of paint were on sale at the retailers at the time. Off the top of my head, I can think of dark metallic red, dark metallic blue, orange and chrome cans.
On my last build I left my B-can bare metal and polished the pee out of it:
I gave it a generious coat of paste wax to protect it..............unfortunately the very next day it had already started to rust! :shok:
I ended up spraying on a coat of clear.
#25 Jairus
  • 9,874 posts
Posted 22 December 2018 - 07:10 PM
Rust is a color!
