what would work best?
Loctiting spur gear on axle
Posted 20 January 2019 - 07:34 PM
Posted 20 January 2019 - 07:39 PM
Are you asking about Loctiting the set screw or the entire gear hub?
My Series Spring 2016 4" NASCAR, JK LMP State Champion, and Endurance State Champion
My Series 2015 4" NASCAR, GTP and Endurance State Champion
GRRR 2015 4 1/2" and F1 Champion
GRRR 2013 & 2014 Evil Flexi Champion
1968 Hinsdale ARCO Amateur runner-up
Posted 20 January 2019 - 07:41 PM
If your just trying to keep the swr screw from coming loose here are a couple things to do:
1. With the gear off the axle run the set screw through the hole then use a reamer to clean up the axle hole on the hub.
2. Place the gear on the axle and apply blue lock tight on the set screw then tighten on the axle. You can also use an axle with flats.
- SpeedyNH likes this
Dominic Luongo
NERR photos from 2016 to now
Posted 20 January 2019 - 07:56 PM
I have done some of this and it’s risky stuff. If they let go it’s race over.
Always ensure surfaces are very clean, use solvents on axle and inside gear boss. You may also like to rough the surface a little (when using the epoxy, not the Loctite).
Loctite 620 (edit) 638 is the best of the retaining compounds and I don’t think it’s let me down (only used in FK motors though)
Loctite 680 is good but I have had occasional and eventual failures.
They both will lock up quickly once assembled but still need 24hrs to fully set
I have also used a UHU 2part Resin Epoxy, it hasn’t failed and I have used this up to G12
http://www.hobbiespl...640-p-2371.html
Hope this helps you.
I’m interested in others experiences on this too
Steve Meadows
Posted 20 January 2019 - 08:04 PM
Use a setscrew and be done with it. That is what everyone does and it works.
That said if I were Loctiting a gear on an axle I would use Loctite 680 Retaining compound. I starts to setup quick so you need to get the gear in position quick with a even coating of compound. Make some test before trying it on good parts. I use 680 to install pinions on motors but do not let it get into the motor bushings at all.
Good luck
Posted 21 January 2019 - 12:01 AM
Use a setscrew and be done with it.....
....I use 680 to install pinions on motors but do not let it get into the motor bushings at all..
Use solder and be done with it...
- Phil Beukema likes this
Steve Meadows
Posted 21 January 2019 - 01:05 AM
It’s Loctite 638 (not 620) that’s the superior Retaining Compound
Steve Meadows
Posted 21 January 2019 - 10:00 AM
I soldered pinions for years with great success, but for the last couple of years I have been using 680 with great success. Whatever works for you.
- DOCinCanton likes this
Posted 21 January 2019 - 01:01 PM
I use the Loctite 638 for my Eurosport stuff. I have had them let go, very risky but doable. Things must be cleaned well with solvent.
The safest and best for me, is to notch axle where the set screw touches, remove set screw and replace with 4-40 aluminum threaded rod, tighten threaded rod, cut off, and turn down both the boss and rod with your lathe. The only failure I've experienced with this is when I've taken the boss down to a very small diameter.
Some of the other 1/32 eurosport racers will glue the gear on and remove the entire boss so they don't need the reverse hub wheels usually required for 32ES. I've tried this for practice, but has eventually failed for me.
- Rob Voska likes this
?/?/56-6/12/23
Posted 21 January 2019 - 09:11 PM
Or just notch and Alloy rod?
Steve Meadows
Posted 22 January 2019 - 10:02 AM
Steve, yes 638 glue and the threaded rod before turning boss down. Credit to my friend George Russell for this recommendation!
I had some failures with the glue only. Since adding the threaded aluminum rod for that little extra insurance, I've only had one failure which I attribute to getting a bit too aggressive in my machining of the boss.
The failures that I had with the glue only appear to be heat related. I could run dozens of laps without fail, but after car had a complete cool down and I would take the car back out, within a couple laps the gear would let go.
?/?/56-6/12/23
Posted 22 January 2019 - 03:57 PM
Eddie
I think my post went right over your head
Steve Meadows
Posted 22 January 2019 - 04:32 PM
Eddie
It probably did I am a very shallow thinker.
