Pro-Track hubs re-rubbering question
13 replies to this topic
#1 Pablo
  • 18,454 posts
Posted 26 January 2019 - 05:48 PM
Will lacquer thinner mess with the anodized color?
#2 Ramcatlarry
  • 2,945 posts
Posted 26 January 2019 - 06:46 PM
Abrasives will, like steel wool or harsh Scotchbrite.
#3 Pablo
  • 18,454 posts
Posted 26 January 2019 - 07:11 PM
I'm not wanting to remove it, I want it to stay.
#4 Zippity
Zippity
  • 5,278 posts
Posted 26 January 2019 - 09:00 PM
Isn't anodising an electrolytic process?
Lacquer thinners should have NO effect on it :)
  • Ramcatlarry and Jesse Gonzales like this
Ron Thornton
#5 Dave Crevie
  • 4,536 posts
Posted 27 January 2019 - 12:38 PM
Won't affect it.
  • Jaeger Team likes this
#6 Pablo
  • 18,454 posts
Posted 27 January 2019 - 03:16 PM
Thanks Dave.
#7 Phil Hackett
  • 5,693 posts
Posted 27 January 2019 - 05:29 PM
Don't soak it.
#8 Pablo
  • 18,454 posts
Posted 28 January 2019 - 07:01 PM
Just when I thought it was OK to soak with Dave's advice, Phil says "no soak".
We shall see :)  I put a little puddle of thinner in a cup and placed one hub in it, inner race down
#9 Pablo
  • 18,454 posts
Posted 28 January 2019 - 08:29 PM
After a 1.5 hour soak, the red anodizing shows zero sign of dissolving
So it's time for a good soaking
#10 Dave Crevie
  • 4,536 posts
Posted 29 January 2019 - 12:36 PM
To get the rubber off, you don't have to soak long. The adhesive should soften enough to rub the residual rubber off with your fingers.
You won't need to use steel wool. While with the Bensenville Bombers I did lots of these tires.
#11 Pablo
  • 18,454 posts
Posted 29 January 2019 - 05:12 PM
Thanks for the coaching, guys. I gave them the rough treatment for my experiment - overnight soak.
Not because I felt it necessary - because I was lazy.
Result: Thinner DID affect them, but very slightly, as it turned it slightly pink. But the anodizing held fast.  I'd say, use it but don't soak it, like Phil and Dave said.
  • Ramcatlarry likes this
#12 Dan Miller
Dan Miller
  • 128 posts
Posted 17 February 2019 - 12:06 PM
For tires glued on with contact cement, try soaking in camper fuel. It works well and after 24 hours the tire and glue just roll right off. It will not attack magnesium so no worry about anodized hubs. A quick rinse in lacquer thinner to remove the very light oil film and you are ready to glue them up. If you forget them for a couple of days you will not hurt them. I have soaked magnesium hubs for 2 - 3 days with no problem.
  • Jesse Gonzales likes this
#13 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 17 February 2019 - 01:24 PM
Nice hubs.  I would mind making up some fronts with those.  First time I've seen them.  Part # or I.D.?
Mark Wampler
?/?/1950-3/8/22
#14 Pablo
  • 18,454 posts
Posted 17 February 2019 - 05:08 PM
They are from my Driftin' Fifties proxy car; I don't remember the exact part # sorry.
