Pablo Hawk Retro Cucaracha Jail Door Thingie
57 replies to this topic
#1 Pablo
  • 15,685 posts
Posted 11 February 2019 - 08:05 PM
My work plate is empty, so I dug through my vintage body stash and found a Billy Watson Cucaracha.
A rough Parts Gathering phase has begun:
Motor: JK Hawk Retro
Bracket: BWA/Professor Motor
Rears: 3/32 unflanged rims with vintage orange donuts
Fronts: 1/16 O-Rings
Tongue: Dynamic
Chassis: ISO with tilting body mounts
More to follow........
  • Jencar17, airhead, Peter Horvath and 5 others like this
#2 Martin
  • 1,682 posts
Posted 12 February 2019 - 08:25 AM
I'm In :good:
#3 airhead
airhead
  • 720 posts
Posted 12 February 2019 - 11:28 AM
I had some La Cucarachas get loose in the track, and now they are breeding. Bring your dog, JoJo up and see if he can sniff them out.
Billy Watson
#4 Pablo
  • 15,685 posts
Posted 12 February 2019 - 08:49 PM
Billy, your Cuc bodies are popular but JoJo only kills rats :laugh2:
The fresh orange donuts I have always perform well on jaildoor chassis cars - so they got the nod. Found some inserts that may work well.
Champion speed ring oilites soldered home on the bracket
  • Peter Horvath, olescratch, C. J. Bupgoo and 1 other like this
#5 Pablo
  • 15,685 posts
Posted 13 February 2019 - 06:54 PM
My goal of making both bracket and motor sit level at ground zero with .032 clearance is mathematically impossible.
A Parma 26 mikes at .647", which "drives" the entire situation.
So, here's my plan:
-Parma 26T (dyed black) sleeved to 3/32 with a hollow set screw (makes it balance)
-ARP 9T angled steel pinion (not because it's needed for hypoid - because of the small crown OD)
-Orange donuts at about .750"
-Clearance .062" rear, angled to .032 front
-Chassis will be an ISO (because all Cucs are ISO lol) with tilting rod body mount outriggers
-I reserve the right to possibly use Swiss plated wire here and there, but it will be almost all brass rod
Photo is rough trim of the wheels to 13/16" OD, PCH axle trimmed to correct length to make it 3.00" wide.
Note to potential buyers - unlike my previous car which was full of high dollar rare collectible parts, this car is going to be very affordable :sun_bespectacled:
  • Peter Horvath and Geary Carrier like this
#6 Pablo
  • 15,685 posts
Posted 13 February 2019 - 08:04 PM
$13 motor - wire connections tinned, pinion installed, brushes broken in
#7 Pablo
  • 15,685 posts
Posted 28 February 2019 - 07:09 PM
Back to the "budget" Cuc - I guess you could call me the "Cucaracha Whisperer" :music:
Getting all jiggyed up with a steel tongue/brass chunk sandwich, tilted up slightly for .032/.063 slope
Jig motor and bracket set
  • Peter Horvath, Geary Carrier and mike1972chev like this
#8 Geary Carrier
Geary Carrier
    all there...???
  • 584 posts
Posted 28 February 2019 - 08:12 PM
This build just feels right...
  • olescratch likes this
#9 Pablo
  • 15,685 posts
Posted 01 March 2019 - 06:37 PM
Thanks Geary, I'm sure you will see a lot of endbelldrive, dc-65x, and Jairus here.
ISO's always seem to handle like a dream when done right.
Some rear end bracing
Main rails are Swiss .063 plated wire
  • Geary Carrier likes this
#10 mike1972chev
mike1972chev
  • 274 posts
Posted 01 March 2019 - 08:34 PM
Hey Mr. Pablo,
Did you think that heavy,cast motor bracket needed that added bracing ??? It looked like a pretty substantial bracket right out of the box to me?? (Just asking cause I have the SAME one I am using on my "thingie" build I am doing... ;) )
Michael J. Boruff
#11 Pablo
  • 15,685 posts
Posted 01 March 2019 - 08:51 PM
Thanks for asking. My answer is, if it was an original BWA bracket, no. But it's not, it's a copy of the BWA and not near as strong. The extra bracing probably isn't necessary, but, I'm an "overbuilder". Also, it's almost all weight down low, so there is no penalty. The "U" brace is .055 and the "L" braces are .047.
Another factor is, the use of oilites instead of racing bushings allows a slight amount of flex without binding the axle. If I was using Slick 7 bushings, I'd say "yes", it needs the braces.
From the main rails, four .063 tubing pieces, then a set of brass rod rails, and ISO tube at the rear
#12 Bill from NH
  • 11,138 posts
Posted 01 March 2019 - 09:36 PM
Mike, thanks for asking that question. You saved me from asking it. I hadn't heard that the BWA brackets were machined out of better brass billet than the PMs.
#13 Pablo
  • 15,685 posts
Posted 02 March 2019 - 09:30 PM
Wire/spacers/rod, Wire/spacers/rod.
Beginnings of the outer section are cross-connected up front with Swiss plated .047 wire.
ISO hinge wires mañana
  • Peter Horvath, Hack, olescratch and 3 others like this
#14 Martin
  • 1,682 posts
Posted 02 March 2019 - 10:07 PM
Looking good Paul :good:
  • olescratch and mike1972chev like this
#15 Pablo
  • 15,685 posts
Posted 03 March 2019 - 06:22 PM
Thanks Martin. Hinge wires are Swiss plated .063, side to side slop keepers are custom cut 3/32 tube pieces, rear cross connector is tinned .038 wire. Spacing is 15 thou total (7.5 thou/side)
#16 Bill from NH
  • 11,138 posts
Posted 03 March 2019 - 06:49 PM
Pablo, where'd the .038 wire come from? Is it metric?
#17 Pablo
  • 15,685 posts
Posted 03 March 2019 - 07:20 PM
.039 is what I should have said. 1mm K & S :)
#18 Pablo
  • 15,685 posts
Posted 03 March 2019 - 08:10 PM
Cockroach Facts
  • Cockroaches have been around since the time of dinosaurs
  • A cockroach can live almost a month without food
  • A cockroach can live about two weeks without water
  • Some female cockroaches only mate once and stay pregnant for life
  • A cockroach can live for up to one week without its head
  • Cockroaches can hold their breath for up to 40 minutes
  • Cockroaches can run up to 3 miles an hour
Cockroaches can cause allergies, trigger asthma attacks, and spread 33 different kinds of bacteria
An original Cox La Cucaracha:
-handles like a tilting pile
-fails constantly due to flimsy chassis, binding axles, overheated motors, stripped gears
-requires constant fiddling
-spends more time upside down at high speeds than in the slot
-is a constant annoyance to it's owner
My new, improved version, once finished:
-never needs food or water
-never mates
-doesn't require air
-runs like a banshee
-is a pleasure to drive
#19 Martin
  • 1,682 posts
Posted 03 March 2019 - 08:23 PM
It does seem to have a habit of reproducing though. In a good way. :)
  • olescratch and Geary Carrier like this
#20 mike1972chev
mike1972chev
  • 274 posts
Posted 04 March 2019 - 08:51 AM
Cockroach Facts
Cockroaches can cause allergies, trigger asthma attacks, and spread 33 different kinds of bacteria....
Sounds A LOT like my Ex GF...  :unsure:
Nice chassis build Mr. Pablo.
  • Silver Fox and Samiam like this
Michael J. Boruff
#21 Bill from NH
  • 11,138 posts
Posted 04 March 2019 - 09:09 AM
Mike, are you saying your Ex GF had cockroaches?  :laugh2:  The biggest roaches I've seen were in Bermuda.
#22 old & gray
old & gray
  • 716 posts
Posted 04 March 2019 - 09:13 AM
Taken in perspective, at the time of the Cox La Cucaracha introduction at my local track (212 foot Engleman) the fast setup was a 36d sidewinder with 1¼ inch tires.
It was a revelation that the fastest car on the track wasn’t the fastest on the straight. If I only knew then what I’ve learned now.
Your car is beautiful and if it was in my case back then I would have been king of the track.
  • boxerdog likes this
Bob Schlain
#23 Pablo
  • 15,685 posts
Posted 04 March 2019 - 09:20 AM
Thanks guys. Think of all the motor combinations possible with a simple $14 screw-in FK motor:
Hawk Retro
MiniBrute
PS 4000 series
Hawk 7
Phoenix
Hawk 25
etc. etc.
Down in Australia they have flying cockroaches. They target you and do strafing runs :o
#24 olescratch
olescratch
    olescratch
  • 903 posts
Posted 04 March 2019 - 12:50 PM
  Chassis looking good as usual.  These roaches do seem to multiply even though they spend most of the time inside a pitbox lol!  I started out with one, now there are six that I know of !  Build on Mr. Pablo!
John Stewart
#25 Pablo
  • 15,685 posts
Posted 04 March 2019 - 06:11 PM
Will do :D I changed my mind on front wheels - 5/8" OD instead of 1/2".
They will ride on a one-piece Swiss .063 wire axle, secured to the outriggers via .047 wire uprights.
Here's something I never though of before, for all you high speed and good handling crazed morons:
if you buy Oring wheels with the rings, peel them off and inspect. Mine were crusty and out of true
Opened up my vintage front wheel drawer of horrors, and found the solution
