Pablo Hawk Retro Cucaracha Jail Door Thingie
57 replies to this topic
#26 Bill from NH
  • 11,144 posts
Posted 04 March 2019 - 09:07 PM
I used to use what i got, glued them to the wheels & trued them with the Unimat. The groove in the wheel took care of any o-ring twist. From the photo, your hubs look more like JK than Parma. One of  my daughter's  old insulin pump has provided me more 5/8" o-rings than i'll probably use. Ace Hardware is another good source.
#27 Pablo
  • 15,816 posts
Posted 04 March 2019 - 09:50 PM
Outstanding catch, Bill, the 5/8" OD fronts are JK indeed, not Parma as I had thought.
I hereby crown thee "King of Mardi Gras" and "Knight of Slot Cars".
Proof positive, I have smart people watching over me :D
#28 Pablo
  • 15,816 posts
Posted 05 March 2019 - 05:34 PM
Uprights and one piece axle will join the outriggers together. Front axle height math:
Wheel OD .556/2 = .278 - .032 (half the axle OD) = .246
My square jig blocks are .248 thick so they elevate the dummy axle to the correct height.
Now I can go nuts with uprights :)
Axle assembly ready to go at 3.00" width. If I'm careful to make all uprights exactly 90 degrees it will drop right in
  • Geary Carrier likes this
#29 Pablo
  • 15,816 posts
Posted 05 March 2019 - 08:14 PM
Perfect time to trim the wire upright ends before slicing and discarding the dummy
Soder-Wick cleanup of the wires and the (real) axle assembly slips right in perfectly
  • Peter Horvath and C. J. Bupgoo like this
#30 Pablo
  • 15,816 posts
Posted 05 March 2019 - 08:53 PM
Front wheel assembly complete. Time for a cleanup and I will stop for tonight with one thought:
Nothing ruins a good handling slot car quicker than front wheels done wrong.
They should provide nothing but a gentle rolling reminder to the chassis - don't tilt too far
  • Peter Horvath, C. J. Bupgoo, Jaeger Team and 1 other like this
#31 Pablo
  • 15,816 posts
Posted 06 March 2019 - 06:39 PM
Center section downstops are a pair of tinned .032 wire gizmos.
Painter's tape is about 5 thou, so two layers over the cross connector wire makes 10 thou.
They lay in place for a tack
Then a check, slight tweaks, then fully soldered. About 10 thou of drop is more than enough
  • Peter Horvath, olescratch, C. J. Bupgoo and 1 other like this
#32 Pablo
  • 15,816 posts
Posted 06 March 2019 - 07:53 PM
The car is SOLD :)
  • Peter Horvath and Geary Carrier like this
#33 olescratch
olescratch
    olescratch
  • 903 posts
Posted 07 March 2019 - 02:48 PM
  DAMN!  IT'S NOT EVEN FINISHED YET.  Yes, it's already looking like another awesome build.  Think I'll be following this one closely for future copying/ideas.
  • Pablo likes this
John Stewart
#34 Pablo
  • 15,816 posts
Posted 07 March 2019 - 05:25 PM
Outrigger tilting body mounts are four rods 2.5" long
Four 3/32 hinge tube pieces of equal length (+/- 2 thou) done with a hand drill and a Dremel :hi:
I added an extra rod to the outer section to lessen the space between it and the outriggers.
A tip for those who may not have seen it before: slide a dummy rod or wire through both hinge tubes for installation, then remove it when done. Add drops of ATF if you feel the need to prevent solder wicking into them
  • olescratch and mike1972chev like this
#35 Pablo
  • 15,816 posts
Posted 08 March 2019 - 09:10 PM
Washed up and ready to tumble in the morning.
055" bite bar, .039" downstops, 1/2" pin tubes, .063" rod hinge connectors.
Nothing fancy, just the basics. Little bit of slop, lift, tilt, drop is all it takes
  • slotbaker, Hack, olescratch and 2 others like this
#36 Martin
  • 1,760 posts
Posted 08 March 2019 - 10:09 PM
Looking good, :clapping:
#37 Pablo
  • 15,816 posts
Posted 09 March 2019 - 07:51 PM
Out of the tumbler:
  • slotbaker, Peter Horvath, Hack and 5 others like this
#38 Geary Carrier
Geary Carrier
    all there...???
  • 586 posts
Posted 09 March 2019 - 08:19 PM
:good:
#39 Martin
  • 1,760 posts
Posted 09 March 2019 - 09:14 PM
 Good looking Paul. Especially like the rear hinge pic. :good:
#40 Pablo
  • 15,816 posts
Posted 10 March 2019 - 03:37 PM
Thanks. Yup, a little bit of wiggy-waggy at the rear is good, not just for slot cars.
The late Ray Price called it "rear-steer". Dogs wag their tails to show emotion and for balance.
Women, well I won't go into that here  :laugh2:
Minimal decals applied to the inside as usual with 3 coats of glazing medium
Despite the fact the Billy Watson body is "good", it does have wheel well marks waaay bigger than what I need, and nothing I can do about that except close one eye and fart
Maybe Billy can find a way to make those disappear, or maybe Vic F. will start making Cuc bodies again.
Meantime, it is what it is :)
#41 Pablo
  • 15,816 posts
Posted 10 March 2019 - 07:56 PM
A microdot of Loctite 271 on each 2mm JK screw is overkill but good insurance
Customer requested a Swiss Red Fox flag. Obviously he reads Slotblog :)
Since they only come in .032 thickness, I added an .032 Mylar flag spacer underneath
  • Peter Horvath likes this
#42 Pablo
  • 15,816 posts
Posted 11 March 2019 - 06:17 PM
Goal for initial assembly was to attach major parts and test front/rear balance.
With the plastic flag nut, it was slightly too far to the rear. With a Classic brass weight, it meets my goal and will fit under the body. Balance point is now halfway between the axles
Just in case, I added another coat of Glazing Medium to the #98 decal in case of contact
Pablo plaque JB Welded to the forward right side of the outrigger rods.
Makes it jet through the donut on a King track and keeps Bill from NH happy :laugh2:
#43 Bill from NH
  • 11,144 posts
Posted 11 March 2019 - 06:47 PM
That's not where I'd have placed it.  :laugh2:  I'd want it to show from the bottom of the chassis, so every time someone looks at the car & chassis they'd know who made it without removing the body. :shok:
#44 Pablo
  • 15,816 posts
Posted 11 March 2019 - 07:22 PM
God made it, I just assembled it. If the owner wants to engrave the underside "Pablo" I can't prevent it   :)
#45 Bill from NH
  • 11,144 posts
Posted 11 March 2019 - 09:28 PM
Brass chassis I built are engraved on the bottom. My Dremel engraver was some of the best $12 i ever spent.  :laugh2:  In 1997, I met a man who had bought one of the chassis I built to be sold for $10 through Modelville Hobby back in 1970. I didn't know him, but he approached me at a Nats warmup race through the engraving on the bottom of that chassis. I never heard who bought the other 6 or 8 similar chassis I built..
We'll agree that we disagree on this topic. :)
#46 Pablo
  • 15,816 posts
Posted 12 March 2019 - 05:25 PM
Bill, I engraved the motor "R MADE IN CHINA" on the underside just for you :P
Next step is orange paint, hopefully something like this shade
#47 Bill from NH
  • 11,144 posts
Posted 12 March 2019 - 09:17 PM
Thanks, I think. :laugh2:  :laugh2:   But for such  a car, why  would I care what version of an RH was used?
#48 Pablo
  • 15,816 posts
Posted 12 March 2019 - 09:53 PM
Bill, I purposely made the car so the owner can vary the power by simple motor swaps. See my post #23.
FYI, there is no such motor as a "RH".
Fluorescent orange backed with white looks good, I think
  • Peter Horvath, olescratch and C. J. Bupgoo like this
#49 Martin
  • 1,760 posts
Posted 12 March 2019 - 10:27 PM
I do like that orange, you wont lose that on the track.
  • Pablo and olescratch like this
#50 Bill from NH
  • 11,144 posts
Posted 13 March 2019 - 09:02 AM
I thought RH stood for Retro Hawk. To be truthful, the IRRA has had such a myriad of legal motors, me not racing retro, I haven't bothered to keep track of which is what. :laugh2:
