This one started as a Russkit "22", and the end bell (in my best Maurice Chevalier..."but of course mes ami!") got tossed. Can got stripped and painted gloss light blue and the el-junko can bushing replaced by a 5mm x 2mm bearing. For a new end bell, I used one from a Hong Kong produced Mabuchi FT160. These are both "genuine Mabuchi" product, and at this stage definitely "vintage". While they look sort of like a cross between a Mabuchi FT16D and Champion end bells, these things are made from an extremely tough, durable and heat-resistant material...seemingly as tough as any modern end bell, maybe tougher? I removed the stock sintered metal (magnetic/iron content) bushing, machined a reducer and epoxied-in a 5mm x 2mm bearing up there as well. Lastly, I trimmed the edges of the end bell so it's not proud of the can (*the HK Mabuchi has a MUCH thicker can metal). Lastly, I drilled top and bottom inspection/cooling holes and dyed the end bell purple.
I had one of the Mura can-in-a-can shims and epoxied that, along with a set of really stout ceramics (after a fresh zap, they measure over 1300, about the top on my meter for ceramic singles). By removing the shim's internal clips, I wound up with about a .535 "hole".
Like I said, these end bells are tough as nails. No real bulletproofing is needed here, although I will install post sleeves just to increase the posts' OD to better fit the springs. For an arm, I built a .460 stack and wound it 38/27R.
