H&R front engine
10 replies to this topic
#1 chasbeeman
chasbeeman
  • 215 posts
Posted 03 March 2019 - 08:28 PM
Never knew that it existed until I saw this one on eBay. I find myself in need of a coupling for the drive shaft. I don't know of a part for this so hoping fellow racers will know what works best. Thanks in advance for any info related to this topic!641f2598fff680d1ccbda2c90be4ae4e.jpg
Sent from my SM-J327T1 using Tapatalk
Charles Beeman
  • 10,204 posts
Posted 03 March 2019 - 08:57 PM
The front motored chassis with the driveshaft was a Protrack rather than a H&R. Not many sold, until Protrack began to put 16D motors & sealed "FK" cans in the rear. All this happened before H&R was started. I don't recall driving one of the Protrack chassis, but when set up properly, the H&R is sweet. They make a great hard body car.
:) Insect jokes bug me! :)
#3 Ramcatlarry
  • 2,296 posts
Posted 04 March 2019 - 12:35 AM
They used a spring about one inch long to couple the motor to a length of 2mm/5/64" 'driveshaft.  Mine always slipped so soldering or locktiting the ends helped.  Similar 'flex couplings' are found in front motor 1/32 plastic cars like Monogram and Slot-it.  They do not like to work with even moderate torque levels, but those designers are more interested in having a 'full interior' than running a full race.
Worst case scenario - solder a length of brass tubing as a coupler.  Do not forget the pinion support bushing, either.
Host 2006 ISRA/USA Nats
#4 Mark Wampler
Mark Wampler
  • 7,107 posts
Posted 04 March 2019 - 02:52 PM
Here's a novelty 1/32 hot rod car that Larry Shepherd  built.  No date on it. Its a hardbody.
  • MSwiss likes this
You can quote me.
-Mark
#5 Bill from NH
  • 10,204 posts
Posted 04 March 2019 - 03:16 PM
Mark, Larry built some neat-looking cars over the years. Many times, I wish all his posted online photos didn't disappear with his passing. Nice to see you have one of his cars. I still have some Toy-Tech clear bodies as well as a Champion can & endbell he gave me.
#6 Mark Wampler
Mark Wampler
  • 7,107 posts
Posted 04 March 2019 - 03:38 PM
I actually had acquired a small collection of Larry's 1/32 cars, mostly euro proxy cars.  I'll be posing some pics soon !
  • Samiam likes this
You can quote me.
-Mark
#7 Bill from NH
  • 10,204 posts
Posted 04 March 2019 - 04:45 PM
Sounds good, I'll be waiting. :)
#8 Dave Crevie
  • 1,463 posts
Posted 05 March 2019 - 12:26 PM
Spring driveshafts work OK for 1/32nd since the lengths are short. I bought a bare Protrack chassis from a shop that closed, and
assembled it using Hobbytown of Boston universal joints. It required soldering a length of tubing with two ball bearings into the rear
bushing mount. It was very quiet, and ran good with an old Parma 16D. I converted it to rear motor when my Friday night group built
an oval track and I needed the chassis for a vintage NASCAR class racer.
#9 Mark Wampler
Mark Wampler
  • 7,107 posts
Posted 05 March 2019 - 01:15 PM
With that length of span, a center bearing and housing would smooth things out..  The chassis would have to be super rigid if you used a spring off the motor..  U joints would probably be the best way to go on that setup.
You can quote me.
-Mark
#10 chasbeeman
chasbeeman
  • 215 posts
Posted 06 March 2019 - 03:09 AM
Thanks for the information and tips, I shopped locally and no luck, purchased some 2mm ID tubing online. I will use the loctite 680 to make a connector. I have hope that it will work! Thanks gents.
Charles Beeman
#11 Bill from NH
  • 10,204 posts
Posted 06 March 2019 - 08:46 AM
Back along, I believe someone posted that they used the red squirt tubes from WD-40 & ballpoint pen refills to connect motors to driveshafts. i've not tried either.
