Professor Motor B52 ball bearing motor
91 replies to this topic
#26 bbr
bbr
  • 1,700 posts
Posted 02 April 2019 - 01:02 PM
I did a 5 sec dip in simple green and about 30 sec in water for clean out at 2.5 volts
Mike Low
#27 MSwiss
  • 22,848 posts
Posted 02 April 2019 - 01:09 PM
How did it perform vs. Hawk Retro?
#28 bbr
bbr
  • 1,700 posts
Posted 02 April 2019 - 08:40 PM
Ran it in a CA after the last retro race at Bpr.
TQ was 3.9 range that day. I let Alex run some laps and he did some 3.9s. The chassis setup was a little loose, with a proper setup may be 3.8 - 3.7s possible.
The b52 certainly winds up faster. I definitely think that the bb keeps everything line up and spins more rpms.
  • Mark Mattei likes this
Mike Low
#29 Upfront slot cars
Upfront slot cars
  • 263 posts
Posted 03 April 2019 - 08:15 PM
The arm is a diff wind from the retro hawk.
Andrew Ford
#30 MSwiss
  • 22,848 posts
Posted 03 April 2019 - 08:24 PM
What is the wind? (unless that is classified info-lol)
#31 Upfront slot cars
Upfront slot cars
  • 263 posts
Posted 03 April 2019 - 08:32 PM
56-.25mm
Andrew Ford
#32 MSwiss
  • 22,848 posts
Posted 03 April 2019 - 09:24 PM
Thanks.
I thought for a second, it was super-top secret, like the recipe for Pancake Pantry Cinnamon Creme syrup. Lol
#33 Upfront slot cars
Upfront slot cars
  • 263 posts
Posted 03 April 2019 - 09:40 PM
That syrup is too sweet in my opinion ! I order the pigs in a blanket.
  • MSwiss likes this
Andrew Ford
#34 TallyBernie
TallyBernie
  • 142 posts
Posted 04 April 2019 - 09:16 AM
I recently bought two B52s for testing but have not had time to put one in a car.
Based on the B52s packaging (50K RPM on label) wouldn’t a better comparison be made between it and the Hawk 7 (not HR)?
At this time more a point of curiosity....
Keith Bernstein
#35 swodem
swodem
  • 996 posts
Posted 28 May 2019 - 06:49 PM
3 of us ran the B52 in our Handout 4.5hr enduro over the weekend
No run in at all except practice
So maybe got 5hrs true running time in heavy Mack Genesis lazercut chassis with LMP bodies
This is a (poorly focused) pic I got sent of one of the motors post race
To me it looks like the brushes are barely worn...
When I get my car back I’ll do a set of pics
Impressed with the motors so far...
Steve
  • MSwiss and Geary Carrier like this
Steve Meadows
#36 TallyBernie
TallyBernie
  • 142 posts
Posted 29 May 2019 - 10:34 AM
I finally tested the B52 50K motor and found it to be very smooth and pretty quick. With my limited time, and all other factors being the same, Id say easily on pace with a Hawk 7.
Were still testing when time permits. Have yet to use one in competition.
Keith Bernstein
#37 swodem
swodem
  • 996 posts
Posted 29 May 2019 - 03:34 PM
56-.25mm
Anyone know the wind on the B52 25k motor?
Steve Meadows
#38 Greg VanPeenen
Greg VanPeenen
  • 1,146 posts
Posted 29 May 2019 - 05:21 PM
Someone on this thread said they were 56 of .25mm
#39 swodem
swodem
  • 996 posts
Posted 29 May 2019 - 05:22 PM
That’s the 50K model
Steve Meadows
#40 swodem
swodem
  • 996 posts
Posted 08 June 2019 - 05:08 AM
So got the car back today
It did a 4.5hr Enduro with me, then we sent them to the Wellington City club and they ran a 2.5ht enduro.
So it’s had a genuine 7hr plus a bit of practice run time
Brush wear almost non existent
Steve Meadows
#41 swodem
swodem
  • 996 posts
Posted 08 June 2019 - 05:14 AM
And one of the other motors from another of the cars
  • Tim Neja and bbr like this
Steve Meadows
#42 TallyBernie
TallyBernie
  • 142 posts
Posted 08 June 2019 - 09:39 AM
Impressive! Are you finding it similar to the Hawk 7 in performance, in otherwise identical setup?
Keith Bernstein
#43 swodem
swodem
  • 996 posts
Posted 08 June 2019 - 04:53 PM
To be honest we haven’t used H7 down here since 2015.
Our current motor is the PS4002Fk which has its issues
On paper it should do well, but those who have run it like-for-like against a 4002 say it’s not as fast. So I would then say it’s slightly slower that a H7 too
Don’t know why because it’s wind spec indicates it should be a little faster, but I’m not clear on it’s arm timing or magnet type until I pull one down
It’s certainly smooth so would do well in a class that has low downforce
Steve Meadows
#44 Alchemist
  • 1,919 posts
Posted 09 June 2019 - 04:17 PM
Hi Steve,
That is excellent information!
Thank you for sharing it.
May I inquire as to what gear ratio you employed during that Enduro race please - and what type of track was the Enduro run on?
Thanks again Steve.
#45 swodem
swodem
  • 996 posts
Posted 09 June 2019 - 04:26 PM
The chassis has a special cradle for supporting bolted in tin can motors both ends
It’s designed for 64p 11t pinion and 37t (angled) gear
So that’s what we ran and the mesh was perfect.
No gear failures or issues in both races and no parts were changed
The 4.5hr track used is 3-lane home built garage flat track with all corners, no straights (true). Lap times in the region of 3.3sec as average
The 2.5hr track is our Nationals track down in Wellington. It’s a 6- lane, 53m long flat track and average lap time (with this setup) 6.6sec. Some long straights
  • Greg VanPeenen likes this
Steve Meadows
#46 Greg VanPeenen
Greg VanPeenen
  • 1,146 posts
Posted 09 June 2019 - 06:15 PM
I just got 4 of the B52 50K motors. Will be running one in a Trans-Am race this coming Tuesday. Flexi chassis, 10 tooth pinion 64P rule, .750 rear tires, Trans-Am bodies Camaro, Mustang, and AMX. We also run the same chassis set up in 4 inch stock car with low down force COT bodies, The motor rules call for Hawk 7's So we will see how the B52 50K motor stacks up against a flock of Hawks.
I can tell you that the ear tach says the B52's Rev quicker and are much smoother . Hanging from the power supply wires a 6 volts the B52 motors move very little to none compared to the Hawk 7. Another thing I noticed was that 2 of the B52 motors were balanced with a grinder and the other 2 were drilled to balance. It didn't seem to make any difference.
I will post how they do after the race.
Regards,
Greg VanPeenen
  • Eddie Fleming and swodem like this
#47 Jay Guard
  • 1,769 posts
Posted 09 June 2019 - 06:22 PM
Greg:
In what series are you running the Trans-Am cars?  Also, who makes the bodies? Finally, I'd love to see a few pictures of the cars you are running, sounds like a great class. (Sorry for the thread drift!)
Thanks!
#48 Rotorranch
Rotorranch
    What's a title?
  • 1,303 posts
Posted 09 June 2019 - 06:27 PM
The AMX is not a Trans-Am body but the Javelin is!
The AMX is a 2 passenger car derived from the Javelin.
The Trans-Am Series was for 4 passenger cars.
Rotor
Jeff Chambers
                                         "Kinky Kar"
#49 swodem
swodem
  • 996 posts
Posted 09 June 2019 - 08:41 PM
Gave the B52 motor and chassis a good cleanup today, and got rid of all the black scum on the comm.
Now it runs much better with pretty consistent amp draw at low voltage and seems a little happier
"A clean slot car is a happy slot car" someone once said
Steve Meadows
#50 Greg VanPeenen
Greg VanPeenen
  • 1,146 posts
Posted 10 June 2019 - 12:26 AM
Rotor
The American Motors Javelin AMX was a Javelin called an AMX the Javelin had a back seat and the AMX did not.  I have never seen a true Trans-Am  Race Car with a back seat.  I have owned all 3 cars Camaro 69 Z-28 with 4 wheel Disc brakes, and the duel quad Intake. Heater and radio delete. 1969 Ford Mustang Boss 302 , and a 69 AMC Javelin/AMX . I am not a MoPar fan so I never owner that one.
