Angled vs straight pinions effect on arm position
Posted 18 April 2019 - 08:37 PM
Whats your opinion?
Posted 18 April 2019 - 09:07 PM
With a wing car, having maximum tooth engagement is all important.
Something being .0001 faster isn't really important, if you are in the pits, changing your spur.
Regardless, if angled pinions were really slower and hotter, they wouldn't be outselling straight pinions, which certainly is the case at my raceway.
PS- what I like about a straight pinion with a straight spur, is on a ready to run car, like a JK, I can add a spacer between the spur and the bushing, to tighten up a gear mesh, that has too much lash.
Back with the JK C7, that was real handy, with the motor being soldered in.
- Kevan likes this
Posted 18 April 2019 - 11:47 PM
Are we talking about anglewinders or inlines?
Posted 19 April 2019 - 01:01 AM
Posted 19 April 2019 - 08:23 AM
someone commented in a post that an angled pinion will force the armature towards the end bell bearing which makes motor run hotter and is slowe?
I'd like to see that post, please.
I would think a straight pinion in an anglewinder would push the arm in or out under power more than an angled pinion, if anything.
- Ramcatlarry likes this
Posted 19 April 2019 - 10:08 AM
The post in question was by Dom Loungo in an unrelated thread, it had to do with pinions for inlines.
Cheers
Faster then, wiser now.
Posted 26 April 2019 - 05:35 PM
- MSwiss likes this
Posted 27 April 2019 - 08:33 AM
Straight pinion angled spur full tooth contact, angled pinion straight spur not so much. The angled pinion works best if it engages the spur at the big end of the pinion. I have even used angled spurs with angled pinions just to get a smoother mesh. I believe the angled pinion climbs the spur unless it's perfectly aligned with the spur gear. The angled pinion straight spur combo has at least one redeeming quality, it allows for faster spur gear replacement. It's a much more time consuming process with straight pinions and angled spurs. To each his own and good luck racing.
Posted 14 May 2019 - 07:30 AM
... The angled pinion straight spur combo has at least one redeeming quality, it allows for faster spur gear replacement. It's a much more time consuming process with straight pinions and angled spurs...
FF if you use Drag pinions you can have fast axle and/or gear change with straight/straight option
Steve Meadows
Posted 14 May 2019 - 11:31 AM
No thanks Steve I prefer straight pinions with angled spurs, I like the full tooth contact. I just deal with the fact that it's going to take longer to change out a spur "IF" it gets damaged. I once ran a white angled spur gear, ARP or GT-1 don't remember who made them, in 4 different GP12 races and it was still good. Those were suppose to be the weakest gears on the market. Just goes to show if you don't get tooth damage and have full tooth contact, well I like my way.
Posted 14 May 2019 - 11:33 PM
- Tim Wood likes this
