Any knowledge appreciated.
![05ecaa37c30542b0057704db7aa2c4bf.jpg](https://uploads.tapatalk-cdn.com/20190426/05ecaa37c30542b0057704db7aa2c4bf.jpg)
![f80a4e1e2e92ce4133b12316307a63a3.jpg](https://uploads.tapatalk-cdn.com/20190426/f80a4e1e2e92ce4133b12316307a63a3.jpg)
![ea0f85f2bbf64625c3dbc92dd3d66ab6.jpg](https://uploads.tapatalk-cdn.com/20190426/ea0f85f2bbf64625c3dbc92dd3d66ab6.jpg)
Posted 25 April 2019 - 10:55 PM
Posted 25 April 2019 - 10:59 PM
Posted 25 April 2019 - 11:16 PM
Posted 26 April 2019 - 06:36 AM
It appears to be 1/24.
IIRC, it was very common with 1/32 cars in the UK.
You should approach George Kimber on Facebook.
Adrian Gay is another slot racer from those times in FB. ( adrian.gay.9 )
Posted 26 April 2019 - 08:55 AM
The soldered axle tube is 'common practice' with pre-springsteel frames in 1/32 (Saloon) cars from the 1980s+ as is the Mura can. That might be an early hand cut steel frame and used the older axle system.
British "1-0-1" frame?
racing around Chicago-land
Posted 26 April 2019 - 09:48 AM
Love the gear guard.
Posted 28 April 2019 - 07:51 PM
Posted 28 April 2019 - 08:16 PM
Charles, I'd pull off the endbell to take the motor apart for freshening, but leave the can soldered to the chassis.
Posted 29 April 2019 - 12:24 AM
We used to that in OZ, chassis were built that way in the early 70 s.
Posted 29 April 2019 - 11:36 AM
It looks like it uses a brass reamed axle tube, cheap way of going racing and if you got a good one and kept it oiled it could outlast bearings! also you could get a shallower motor angle.
[oneofwos]
Posted 29 April 2019 - 12:07 PM
