Tumbling advice for scratchbuilt chassis
29 replies to this topic
#1 MSwiss
  • 26,012 posts
Posted 03 May 2019 - 11:54 AM
It's been hammered, but after tumbling a couple chassis for my hardbody racers, I (and many others) will reiterate, the way to go;
Thumler's Tumbler rotary drum tumbler
ceramic media from Buffalo Arms
detergent from Buffalo Arms
Lake Michigan water (essentially as good as bottled water)
overnight / approx.15 hours
I can't imagine a better job can be had.
  • Pablo, Zippity, Half Fast and 6 others like this
#2 dc-65x
  • 7,075 posts
Posted 03 May 2019 - 12:15 PM
You've got it Mike. :good:
That's what Mike Steube told me and I shared in my thread.............more than a dozen years ago. :shok: Yikes! I'm old.  :laugh2:
  • tonyp, Tim Neja and Jesse Gonzales like this
#3 MSwiss
  • 26,012 posts
Posted 03 May 2019 - 12:17 PM
Yes, of course.
Your stuff is the standard on clean building.
I pinned my post, as newbie's occasionally post, looking for advice.
  • tonyp and Tim Neja like this
#4 dc-65x
  • 7,075 posts
Posted 03 May 2019 - 12:26 PM
I think the only thing I'd stress is that all water is not created equal. Where I used to live the water caused pitting and corrosion when the weather was hot....90+ degrees. Maybe it was acidic or something.  :unknw:  But, it was bad and the problem went away when I started using distilled water.
Pablo offered to send me his great Mississippi water but the shipping cost was to high. :D  :victory:
  • tonyp and Jesse Gonzales like this
#5 MSwiss
  • 26,012 posts
Posted 03 May 2019 - 12:29 PM
That's why I equated our Lake Michigan water to bottled water.
I haven't noticed any difference from it, to cheap, bottled drinking water, or distilled water.
I think the rule of thumb should probably be, if you aren't excited about drinking it, buy something that you would.
#6 CDavis7
CDavis7
  • 196 posts
Posted 03 May 2019 - 12:41 PM
I use distilled water. Its a $1 a gallon and has nearly zero potential contaminates. I was not getting the best results with my regular tap water previously. Switching to distilled made a huge improvement. YMMV
  • MSwiss likes this
Chris Davis
3d-Racing
#7 Matt Sheldon
Matt Sheldon
    Duffy's HMI Executive
  • 2,245 posts
Posted 03 May 2019 - 01:37 PM
I do everything as stated by the op, however have switched to this with better results. It also prohibits rust. I typically add 3 tbsp.
  • MSwiss, Tim Neja and Lee Palmer like this
Matt Sheldon
#8 MSwiss
  • 26,012 posts
Posted 03 May 2019 - 02:35 PM
Distilled water is always the safest bet.
One other tumbler "trick", I experimented with recently, and was happy with.
After tumbling by new CR052, .040" thick brass guide washers, which had the diameter, lathe turned, to fit the guide recess, I drained / strained out the dirty water, and retumbled the media and washers, with a couple microfiber rags in the drum, to dry off said washers.
  • CDavis7 likes this
#9 gas
gas
  • 77 posts
Posted 03 May 2019 - 09:47 PM
Which speed are people using? Thumblers Model B comes in low-speed (20RPM drum speed) and high speed (40RPM). This has stopped me from ordering one. SKU #TT140 and TT140HS at Buffalo Arms.
George Ewing
Retired USAF, retired Ford service tech.
#10 MSwiss
  • 26,012 posts
Posted 03 May 2019 - 10:32 PM
I never knew there was a choice.
1 revolution, every 3 seconds, sounds slow to me.
I'm guessing mine is a 40, but I wouldn't stake my life on it.
#11 Pablo
  • 18,495 posts
Posted 04 May 2019 - 07:44 AM
Mine is the TT-140HS, motor is marked "3,000 RPM"
https://www.buffaloa...10-volt-tt140hs
#12 gas
gas
  • 77 posts
Posted 04 May 2019 - 08:18 AM
Thanks for your answers. Thats one of each, so speed isn't a concern.
George Ewing
#13 MSwiss
  • 26,012 posts
Posted 04 May 2019 - 12:35 PM
As I suspected, mine is a 40 RPM.
Another good investment for tumbling with ceramic media, is the below basket, I bought as a strainer, for a few $'s, at (IIRC) Menards.
#14 JimF
JimF
  • 2,220 posts
Posted 04 May 2019 - 03:27 PM
Having used both, I would highly recommend the 40 RPM motor. It takes much less time to acheive good results than the 20. I have used distilled water for years but even with that, a long tumbling session can occasionally produce some pitting. As a remedy to that, I have been adding possibly 1/4-1/3 cup of common antifreeze to the mix along with some 'Dawn'. Never had a pitting issue when I remember to put it in......... :dash2: It also seems to polish a bit better than water and soap.
In all cases, when I'm done, I'll squirt a bit of isopropyl alcohol into the hinge tubes and bearings followed by a blast of canned air, then oil.
Jim Fowler
#15 Tim Neja
  • 6,848 posts
Posted 04 May 2019 - 05:34 PM
I've been spraying my chassis down with WD40 after tumbling!! It seems to work well and I"ve had no pitting problems.
#16 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,631 posts
Posted 05 May 2019 - 11:53 AM
A few questions for the experts here:
1- How many pounds of ceramic medium?
2- How much fill of liquid?
3- Can more than 1 chassis at a time be tumbled?
Thanks in advance
Faster then, wiser now.
#17 MSwiss
  • 26,012 posts
Posted 05 May 2019 - 12:07 PM
1-I think the standard amount from Buffalo arms is 6 Lbs.
Use it all.
2-until you see it slightly above the level pellets seems to work fine.
3-Yes. The above 2 were done at the same time.
Whatever fits should be OK.
  • tonyp and Half Fast like this
#18 Pablo
  • 18,495 posts
Posted 05 May 2019 - 03:04 PM
1. Concur, 6 lbs.
2. Concur, about an inch above the media. If you mean how much soap liquid, one capful exactly.
3. I wouldn't do it
  • Half Fast likes this
#19 MSwiss
  • 26,012 posts
Posted 05 May 2019 - 03:45 PM
I guess if you had somewhat delicate, or concours chassis, they would possibly be banging into each other.
In the case of the 2 plate chassis I tumbled, I wasn't worried about it.
  • Pablo likes this
#20 Jay Guard
  • 2,937 posts
Posted 05 May 2019 - 08:46 PM
I routinely put 2 and sometimes even 3 chassis' in my tumbler at one time, never had a problem or seen any damage from the chassis' hitting each other, YMMV.
Here's a tip... Put a piece of heat shrink tubing (and shrink it of course) over the threaded ends of a front axle.  It keeps the fine threads from being worn away.
  • MSwiss, Tim Neja and Eddie Fleming like this
#21 Zippity
Zippity
  • 5,278 posts
Posted 05 May 2019 - 09:00 PM
Multiple chassis will not result in any damage.
The tumbling motion has very little force, if any.
A teaspoon of Simple Green added to the water, works a treat :)
Ron Thornton
#22 tonyp
  • 15,325 posts
Posted 06 May 2019 - 06:17 AM
I’ve done multiple chassis at a time, you just have to tumble longer.
#23 mhslot13
mhslot13
  • 35 posts
Posted 13 November 2021 - 04:35 PM
Hello - guys I'm new to this scratch building ! What with the tumbling? Is it really nessasary ? And whats the purpose can't you just clean with tooth bush or equivalent and simpel green and soap ? And about the chassis are there any kits for can am racing and which jig do you prefer
Marlon Hulten
#24 Zippity
Zippity
  • 5,278 posts
Posted 14 November 2021 - 02:12 AM
There is nothing wrong with doing it the long hard way :)
Some of us just prefer to let the Tumbler do it for 20 hours :)
Ron Thornton
#25 Martin
  • 4,420 posts
Posted 06 December 2021 - 04:14 PM
Just to add. I have a mixture of media and the smaller media can get stuck in the axle hole. So I routinely put a junk axle and nuts in place so media can not get stuck in the tube.
I have also used a similar set up in the rear with o-rings nuts and washers to protect the ball bearings.
Marlon, to answer your question.
I do both on older vintage chassis. First I clean with soap and water and tooth brush. Then look for stubborn stains and issues that would take the tumbler a while to polish out. May even do a bit of sanding with fine emery paper.This keeps the tumble time to a minimum. I personally do not like to round all those crisp edges off.
Its also a great way to look for damage etc.
I only ever tumble for 3-5 hours. That gives me that nice even shine.
