I got the call for another Strapnut drag motor. Like most of these, this started out as a plain-jane fk motor that got cut-up, hacked, smoothed. The JK end bell got turned down to fit the slightly smaller I.D. of these motors...blah bah blah. ***Interestingly, when I took apart the donor motor, I found a pretty big wire armature for the type...a #27 wind. Anyway, I went for a more contemporary look here, shooting the bearing end of the motor in "Anodized Red" and the sides in "Anodized Purple".
Inside, this one got to kray-kray-strong solid neos, and I was asked to tighten-up the airgap, so I shimmed each magnet in .007", and the arm in it's raw state fit fine...but the airgap is about as tight as can be before grinding. Bearings on both ends, with the end bell bearing keyed in place finishes off the setup. This will be a big wire arm, so shunts will be necessary...but more to follow.
