Plastic 'vacuum-forming' machine
4 replies to this topic
#1 Phil Hackett
  • 5,708 posts
Posted 26 June 2019 - 02:21 PM
Back in the corner of the dusty room was this small vacuum forming machine. Note! This will ***NOT*** pull Lexan (Polycarbonite) plastic but should work with styrene or other low temperature plastics.
Note it uses a Shop-Vac or other source for the "vacuum". The platen is approximately 9x13 inches. For scale there's a 1/32 scale mold on the platen.
It is 120 volt single-phase... or household power... as the product info label states.
I DO NOT KNOW if the machine functions properly.
It's also fairly bulky and heavy (+30 pounds) so shipping might be a concern so a local sale is ideal.
Anyway, what is this worth to you?
  • C. J. Bupgoo and LotusEliteman like this
#2 Jay Guard
  • 2,868 posts
Posted 26 June 2019 - 02:50 PM
Hey Phil:
I suspect your vacuum forming machine may be able to form polycarbonate (Lexan) if the vacuum system is upgraded with a vacuum tank and pump combo, which would probably cost around $150.  In my limited vacuum forming experience it's generally the amount of vacuum that limits what can be formed rather than the heater not being hot enough to sufficiently soften Lexan.  I certainly don't know for sure about your machine but it looks like a nice unit and it might well work for 1/24 lexan bodies with the vacuum upgrade.
  • Ramcatlarry likes this
#3 MSwiss
  • 25,929 posts
Posted 26 June 2019 - 03:50 PM
Phil's looks identical to the one we had at Koford, during the 19 years, I worked there.
We had no problem doing Lexan®.
As a matter of fact, after Stu moved to Ohio, and had an outside source pull them, I would have guys like Beuf, inquire, if I still had Peugeot's, pulled off of that machine.
That was because they were so well formed, with part of the reason being, they were pulled one at a time, on that fairly large grid.
Which was vs. the earlier bodies like the Mazda and Aston Martin, which were pulled 2 at time.
Stu, after that time having someone else do them, bought a killer vacuumform machine, in the last year or 2.
#4 Jay Guard
  • 2,868 posts
Posted 26 June 2019 - 04:16 PM
Mike:
Did you have a vacuum tank/pump system for the vacuum machine or did you just use a shop vac?
#5 MSwiss
  • 25,929 posts
Posted 26 June 2019 - 04:21 PM
I honestly don't remember anything else hooked up to it.
I thought it was self-contained.
But that was 15 years ago.
If I was closer, I would pick it up.
It did an a great job heating up burritos, and a spectacular job, cooking a steak.
  • Eddie Fleming, Sean Mikuen, Jesse Gonzales and 1 other like this
