2019 USRA Wing Car Nats schedule - Sept 11-15
4 replies to this topic
#1 Jason Holmes
Jason Holmes
  • 1,134 posts
Posted 30 July 2019 - 04:50 PM
USRA Wing Nats
September 11-15, 2019
Slot Car Raceway, LLC
11803 Westheimer Rd,  #720
Houston, TX 77077
(832) 243-6566
Owner: P. A. Watson
Directions
Facebook
Track: Gerding King
Class notes:
Grp F - Pro Slot PS4002FK hand-out motor, available after track opens on race day Sept 11.
Grp F, OMB, and Hillbilly B will be hand-out tires.
OMB - No Cahoza set-ups permitted.
C12 - Will run 3 mins on, 4 mins off. Two motors may be used; the second motor to be presented at tech to be marked. After qualifying, cars will go to the line as in the all-Main format
USRA Nats daily timeline:
7 AM - The raceway will open.
7-10 AM - Open practice.
10 AM - Track power is turned off.
10 AM - Tech opens.
10:30 AM - Tech closes.
10:45 AM - Qualifying will begin.
Schedule:
Sept 11: morning – Grp F, afternoon - OMB
Sept 12: morning – Hillbilly Box, afternoon - C12
Sept 13: 27 L
Sept 14: TMO
Sept 15: Opens
Timeline details:
Following the conclusion of the first class, the track will be open for a period of weo (2) hours. Only the racers participating in the next race will be permitted on the track and the only class of cars permitted on the track will be cars for the next class.
Tech will be open for 30 minutes after the track power goes off.
Qualifying will begin promptly after the conclusion of tech.
At the conclusion of the last race there will be a two-hour open practice on the track. This two -hour practice session will not go past 10 PM.
The raceway will close no later than 10:15 PM.
Please note that any cars that do not pass tech at the conclusion of tech will be given five (5) additional minutes to work on their cars. These cars will remain on the tech table and will be released to the racers at the same time. Drivers must fix their cars and bring them back to the tech table and pass through tech prior to the conclusion of the five-minute period. Every effort will be made to be sure a tech official is available.
Above info can be downloaded as the PDF below.
Attached File  USRA Wing Nats - 9.11-15.19.pdf   35.3KB   74 downloads
  • Bernie likes this
#2 CARSHouston
CARSHouston
  • 97 posts
Posted 06 August 2019 - 11:04 PM
Are we going to be using the illegally changed USRA Grp F rules with axle bearing at .032 clearance or the Local P.A. Grp F rules with bushings at .062 clearance?
  • The Number of likes this
George Marsanick Jr
#3 Jason Holmes
Jason Holmes
  • 1,134 posts
Posted 07 August 2019 - 12:56 PM
We will use what the Rule book Says
Jason
But that does not stop you from running Bushings and 062  Now me I will be running Bearings and 062+ on PA's Track. Now next year if it was me I'd going to the 032 because of Mike's King is a Drivers Track
#4 Bernie
Bernie
  • 1,269 posts
Posted 07 August 2019 - 02:38 PM
Group F cars run just fine at Swiss's track at the normal clearance. .032 would be iffy on tire wear.. Just say'n.. :good:
Bernie Schatz
#5 Jason Holmes
Jason Holmes
  • 1,134 posts
Posted 07 August 2019 - 02:47 PM
I'm sure you right Bernie but the lower clearance works in 2 ways your car may handle better and you get to use more Tire would I come in at 032 no but 050 yep and change my gearing but that might just be me
jason
