Wing car tire/rim suggestions for local track?
9 replies to this topic
#1 mdiv
mdiv
  • 2,183 posts
Posted 04 August 2019 - 05:57 PM
Hey all,
Just looking for some tire and rim suggestions for running wing cars on my local track.  Not racing at the moment but looking for ideas.  Motors would be Mini Brute up to G27.
Here's the track:
I have one car that I've played with using a strap X12 motor. I threw some JK .720" treated tires on the car and went and played. Managed a 4.29.
Hope to hear some good info from those with more experience. Looking to keep a set of tire prices under $16. Back in 2014 we ran $100 wing cars for a few months and had some fun, I think at the time I was using Koford Wonder .750"s and the car handled well.
Thanks for your input!  :)
Mike D
PS: Speedshop rims are more for the scale guys, correct? Also in the future would be some running on a track not built yet...  ;)
Mike DiVuolo
#2 SoCal Bill
SoCal Bill
  • 34 posts
Posted 04 August 2019 - 06:15 PM
I assume you are running a cobalt 12 wing car. If your track is fairly smooth try Koford M472-650S-WXX. These are spec tires with a lower than normal price ($16).
If you need more bite, go to a softer version.
Bill Fagan
#3 mreibman
mreibman
  • 198 posts
Posted 05 August 2019 - 08:24 AM
Some of us have to run those "spec" tires on our wing cars.... I would not recommend them unless you have to use them.
For a good all-around tire, you could tray Alpha Supernatural, https://www.alphaslo...race-tires.html
Another reasonable choice is the JK "Big Daddy" tires (I don't have the part number).
Since I know you mostly run "vintage" cars, I would also suggest making sure the diameter matches the chassis as the older chassis are often set up for larger tires (.790 and 13/16), and smaller hub tires as those were more period.
Your mileage can and will vary - talk to the racers at the track for their suggestions as well as the track owner. Chances are he's selling the things that work on his tracks.
Just my opinions. Not gospel at all.
Mike Reibman
Alleged amateur racer
Faster than a speeding womp.
More powerful than a 36D
#4 philk
philk
  • 130 posts
Posted 05 August 2019 - 10:18 AM
Alpha or Koford Wonder rubber, soft, medium or hard , full width or narrowed, depending on how sticky the track is.
Phil Kreuter
#5 MSwiss
  • 22,823 posts
Posted 05 August 2019 - 10:33 AM
Mike, unless slot racing comes up with a "Traction-o-meter", that you can reference (IE-"My track has a 7.4 traction value".) you are asking an almost impossible question to answer accurately.
Here at CR, Koford M472P-WH ($12 retail) is a good economical wing tire for non-Gerding King tracks.
Still, too many variables to give you a definitive answer.
#6 Fast Freddie
Fast Freddie
  • 709 posts
Posted 05 August 2019 - 10:43 AM
One thing many wing car racers won't tell you is that there is a big difference between playing with wing cars and being competitive with wing cars.  Tires are a very big factor in one but not the other.  I've raced GP12 on a track similar to that one.  I used medium wonder rubber on a .500 rim, I glued the tires before running.  The motors you say your running have a very wide range of performance.  Keep in mind that the faster a wing car goes the more downforce it generates.  What this translates into is that you can run harder tires the faster you go.  So a car that has a MB motor will want softer tires then the exact same car with a 27 motor. Finding the right tire is the problem for all racers so don't get discouraged.  You will also find that the tire that worked yesterday might not work today but may be the tire of choice tomorrow.  Keep working at it and good luck in your racing.  It's also not necessary to find the optimum tire just the one that works best with your combination.
Fred Younkin
#7 mreibman
mreibman
  • 198 posts
Posted 05 August 2019 - 11:45 AM
Mike Swiss, What's the CR part number for the Traction-o-meter?
  • MSwiss likes this
Mike Reibman
#8 mdiv
mdiv
  • 2,183 posts
Posted 05 August 2019 - 08:14 PM
Thanks for the replies fellas.
I'm pretty sure the Koford set that Swiss gave the p/n for is what I was running on the $100 car.  Did really well on the Hurricane, I'll have to pick up a few sets.
Danke,
Mike D
Mike DiVuolo
#9 mdiv
mdiv
  • 2,183 posts
Posted 20 August 2019 - 05:15 PM
Fellas,
Found my old $100 car (prob best to call it Group F from now on..) and the tires are dry as Arizona weather.  Anyone ever re-rubber these M472P-WH's?  Jerry has a good supply of Alpha wonder donuts.  I found some smaller-diameter rims and he's going to re-rubber those for me when he gets back from Maine, and I've also picked up some HUGE rim tires off eBay.  Methinks one would have a very hard time re-rubberin' these...
A few years back I ran AM I15 at Port Jeff and there was a spec set of tires you needed to purchase.  I guess it makes sense you wouldn't re-rubber these, even if just for local practice...?
Wisdom is golden.
Or...Nike?  "Just do it"
Mikey
Mike DiVuolo
#10 Jason Holmes
Jason Holmes
  • 1,044 posts
Posted 20 August 2019 - 10:44 PM
Mike
Skinner re-rubbers Large Hubs all the Time 680id for your Grp F car on that track Koford Spec 615 WX or WX+ but I don't think you would ever need a 680 on that track to re-rubber Hub must be in great shape
jason
