Direct Drive project
37 replies to this topic
#1 Alchemist
  • 1,804 posts
Posted 15 August 2019 - 01:17 AM
Greetings,
I'm cognizant this is not a  "mainstream" project, but I wanted to share what a couple of people have inspired me to build for myself.
Back in the latter part of 2013, Mike Swiss introduced the "Direct Drive" Slot Car concept, which got me excited when I saw the prototype lapping around his Chicagoland track.
So, a couple of days later, I made the decision to design and fabricate my own version of a 1:24 scale Direct Drive Slot car.
Then, our illustrious motor wizard, John Havlicek got "inspired" to build his version of a Direct Drive motor employing a 3/32" armature shaft instead of the usual 2mm shaft, using a C-can motor.
I was fortunate enough to acquire that motor from John.
So, I would like to take this time to say "Thank you" to Mike Swiss for presenting the Direct Drive Concept, which gave me the inspiration and motivation to create my own.
I'd also would like to say "Thank you" to John Havlicek, for providing me with the "Direct Drive" motor which set the initial foundation of my project.
So, having come across the Direct Drive prototype chassis that I fabricated back in 2013, and fortuitously located the direct drive motor John built, I decided I would finish this prototype.
Here is the humble beginning, using G10 Phenolic and a cut/drilled angle bracket.  Parts are bonded using 3M VHB RP Series tape - exactly like my "Not your typical Inline Chassis Project".
John H's Direct Drive motor - mounted
I chose to employ the terminal connector block, that I have a fascination with (LOL) and 18 awg solid core wire.
The solid wire is bent and routed to the terminal block, so there is not a concern of the wire coming in contact with the armature shaft.
Yes, I could have just "soldered the wires" but I choose to build my cars differently.
Here is the chassis completed.
And it weighs in at 85.6 grams
I'm glad I finally got to finish this prototype.
Working on Version 2 Direct Drive Chassis!
Thank you for taking a look.
  • Pappy, Tex, havlicek and 6 others like this
#2 NSwanberg
NSwanberg
  • 1,224 posts
Posted 15 August 2019 - 05:16 AM
It more or less looks like a standard 16C wind which I think would be pretty hot for a drect drive car. Good luck getting it to hook up.
John, did you do any kind of a special wind for this project like 60 turns of 38???
I've always thought it would make the most sense for rentals but JB at Downriver insisted the 1/32 JK direct drive cars were too slow. Now he is trying to slow his rental cars down with the Professor Motor 25,000 rpm motor.
SUPPORT YOUR LOCAL RACEWAY!!
Nelson Swanberg 5618
#3 havlicek
Posted 15 August 2019 - 05:33 AM
So many motors come and go that I had forgotten I did this...completely.  When Ernie said he was doing a direct drive car, I wondered what he was going to use for a motor, but thought to myself that something like 80-100 turns of #31 awg  with fairly neutral timing should be a decent starting point.  I have no idea what the wind is here or whatever other specs (magnets, air gap, commutator timing etc.) there are about the motor.
Huh?  Where's the photo showing that?  Maybe in the build thread buried in the SlotBlog archives somewhere?
#4 brucefl
brucefl
  • 927 posts
Posted 15 August 2019 - 06:31 AM
how does it perform on the track?
  • Tex and Geary Carrier like this
Bruce Schwartz
#5 Ramcatlarry
  • 2,430 posts
Posted 15 August 2019 - 09:07 AM
Since all of the 'modern' endbell hardware is designed for one rotation direction, the zero timing will allow for running the motor the opposite direction to point the hardware forward.  The other option is to reverse timing advance.  Keeping the timing advance to less than 10 - 15 degrees should keep it running cooler and smoother.
Pittman 85 and Ram 850/7 padlock motors with 1/8" shafts seem to work OK on 16V modern drag voltage direct drive.
Host 2006 ISRA/USA Nats
#6 Geary Carrier
Geary Carrier
    all there...???
  • 550 posts
Posted 15 August 2019 - 09:48 AM
... :good:
Cool my good man.
  • Alchemist likes this
#7 Alchemist
  • 1,804 posts
Posted 15 August 2019 - 11:17 AM
Thank you kindly Brother Geary!
Here's a lilnk to John's "inspired direct drive motor".
http://slotblog.net/...irect-drive-jk/
I have yet to test the car, but my plan is to do that in the near future.
Here is the discussion of the Direct Drive concept:  http://slotblog.net/...ept-discussion/
Thank you.
#8 Alchemist
  • 1,804 posts
Posted 15 August 2019 - 01:28 PM
Now, coming back to my present day project, I had been "imagineering" a Version 2 (V2)  for months, and have now produced a final working "prototype" design platform.
By exploiting redundancy, it allowed me to produce a V2, V3, and a V4 Motorbox - thus allowing to run most of the mini size motors that I have;  and . . . by turning the "motorbox" 180 degrees - either way, will allow the use of either CW or CCW direction motor.
Version 2 platform
I started out with an aluminum C-channel and cut a small section
Drilled the motor holes
Hand cut the motor lead/bearing pattern
Checking FK-130 motor fitment
Chassis pieces cut
I cut the chassis similar to my inline chassis, with the theory of removing more material from the middle, thus shifting more weight towards the guide flag.
The square piece acts as a brace but serves a couple of purposes;
1.  It acts as a jig, to precisely locate the motorbox onto the chassis
2.  It braces and keeps the motorbox from the possibility of shifting, either from the torque of the wheels or impact
My initial approach to mounting the 1/8" axle wheels, was to employ 1/8" steel pop rivets
I shared more info regarding pop rivet sleeves on my motor dyno thread, starting at Post #4 - if you're interested:  http://slotblog.net/...409-motor-dyno/
In the motor dyno thread, I stated I employed an aluminum pop rivet that had "no play at all", but using steel rivet sleeves proved to have more runout than I preferred.
I was able to eliminate the runout by truing the tires on the chassis but I refused to go in that direction.
In my search for a better alternative, I came across stainless steel capillary tubing which advertised the exact specs I required.
This SS tubing is axle straight!
Cut a couple of sleeves
The SS sleeves were almost a "press fit" so I used Loctite 680 retaining compound, which was recommended by a Henkel (manufacturer of Loctite products) tech.
Solid core wires
Chassis assembled
Ready for testing
Weighing in at 93.6 grams
Thank you.
  • Jencar17, NSwanberg, Samiam and 2 others like this
#9 Ecurie Martini
Ecurie Martini
    Ecurie Martini
  • 1,017 posts
Posted 15 August 2019 - 03:44 PM
I  tried a similar experiment in 1/32 scale using a relatively low RPM, high torque skewed armature model RR motor.  Power delivery was smooth, acceleration adequate, top speed was good but braking, important for flat track "road" courses, was almost non existent.  Perhaps it is less critical in the commercial track world.  In any event, I shall be interested in the test results.
EM
Alan Schwartz
#10 Alchemist
  • 1,804 posts
Posted 15 August 2019 - 04:03 PM
Greetings Alan!
Hope all is well!
Would you still have that "experiment" lying around somewhere - I'd really like to see your design please?
Thank you for sharing that.
#11 Don Weaver
Don Weaver
  • 1,476 posts
Posted 15 August 2019 - 04:08 PM
Very nice, clean build with obviously lots of thought.  My only suggestion would be to use a longer guide lead dimension (between C/L of front axle and guide post).
Don Weaver
L.H. Lapham
it will starve to death...
#12 Jairus
  • 9,781 posts
Posted 15 August 2019 - 04:18 PM
Would be fun to do a direct drive version with a planetary gear combo at one end driving the axle.
But that would take John (my best friend, hint) to wind an arm on a hollow shaft somehow. Been a thought since 1980.
  • NSwanberg, Alchemist and Geary Carrier like this
#13 Geary Carrier
Geary Carrier
    all there...???
  • 550 posts
Posted 15 August 2019 - 05:24 PM
Some crazy winder could do that... :)
#14 Alchemist
  • 1,804 posts
Posted 15 August 2019 - 10:53 PM
The V3 motorbox is designed to accomodate the FC-130 motors.  This motor runs CCW.
Weighing in at 81.7 grams
V4 is my last motorbox platform.   It  accommodates the ProSlot FK4002 type motor.
This is the first prototype iteration and needs quite a bit of fitment tuning on the endbell side of the motorbox.
The endbell is unique (to me) in that it has a "Skeleton Keyway style" design.
That's it for me.
Thank you everyone for taking a look - time to go do some track testing.
  • Jairus, MSwiss, NSwanberg and 2 others like this
#15 Ecurie Martini
Ecurie Martini
    Ecurie Martini
  • 1,017 posts
Posted 16 August 2019 - 12:34 AM
EM
 I'll look and see - it was about 20 years ago and the pile of "it didn't work, salvage for parts"  is pretty deepThe only thing that I recall with any certainty is that the motor shaft/ wheel bore conundrum was dealt with by machined wheel inserts with 1-72 set screws to secure the shaft/axle after the inserts were set in the wheels with Locktite.
EM
Alan Schwartz
#16 NSwanberg
NSwanberg
  • 1,224 posts
Posted 16 August 2019 - 03:21 AM
Just going by what I can see of the stack in the last picture.
#17 havlicek
Posted 16 August 2019 - 04:54 AM
Well, even with superhero vision and the ability to zoom-in by the magic of computers, that's a pretty impossible estimate to make!  :)
#18 NSwanberg
NSwanberg
  • 1,224 posts
Posted 16 August 2019 - 08:43 AM
It was a SWAG estimate - scientific wild *a$$ guess.
#19 Martin
  • 1,355 posts
Posted 16 August 2019 - 11:18 AM
Ernie.Love your out side the box thinking here.
I would recommend adding an outrigger bearing axle support next to the wheel hub.
It will reduce the load on the motor bearings and help save the motor shaft from bending in a crash.
#20 MSwiss
  • 22,248 posts
Posted 16 August 2019 - 11:38 AM
It's not possible with that motor mount, unless that outrigger bearing was easily removable, which IMO, would make the alignment iffy/tricky.
When I suggested to Jerry the idea of a direct drive car, I brought up the motor shaft bending as a possibility.
He wasn't concerned, and I when asked about it later, after the car came out, he mentioned he had sold a fair amount of cars, and hadn't gotten any complaints.
But the cars aren't that fast.
That said,most Eurosports, use 2MM axles.
They have a bit wider support, but are much, much faster.
#21 Martin
  • 1,355 posts
Posted 16 August 2019 - 04:13 PM
Mike, I was thinking something like these. Yes you are correct it would be 4 extra screws to remove the motor, and the chassis would need to be wider at that point. But with that much over hang, the first wall shot will finish that motor IMO
https://www.qbcbeari...ted_BallB_I.php
#22 MSwiss
  • 22,248 posts
Posted 16 August 2019 - 04:16 PM
How do Eurosport cars seem to do OK with 2MM axles?
#23 Martin
  • 1,355 posts
Posted 16 August 2019 - 04:34 PM
Do they have this much exposed unsupported axle over hang?
and they are drill blanks correct?
  • SpeedyNH likes this
#24 MSwiss
  • 22,248 posts
Posted 16 August 2019 - 04:45 PM
in this case, extremely close.
And again, running at Eurosports speeds.
I seriously doubt Ernie will get a direct drive car to reliably run at the same sort of speed.
#25 Martin
  • 1,355 posts
Posted 16 August 2019 - 05:28 PM
I think a fair visual would be with gear and wheels set at legal width. Your pic is misleading.
Remember Ernie's axle adapters are made from SS tubing.
I was thinking Ernie's design was an opportunity to make something stronger. Not weaker.
