Carrara starting line problem
6 replies to this topic
#1 Philip Soares
Philip Soares
  • 3 posts
Posted 24 October 2019 - 02:00 PM
The outside lane on my Carrara analog track is dead. The problem looks to be a failed capacitor between the positive and negative at the rails. A quick check with a multimeter set on continuity shows that power is going through the capacitor causing a lack of power when controller is depressed.
I need to know what value or what properties the capacitor is to find a replacement. The capacitor is orange and is stamped with the number 223.
Thank you,
Phil
#2 zipper
zipper
  • 1,095 posts
Posted 24 October 2019 - 02:12 PM
Does it get hot? Then there is a short. Afaik those caps are just for RF (spark)  interference suppression and have nothing to do with moving the cars. In some home tracks the caps were built into the cars.
Pekka Sippola
#3 Philip Soares
Philip Soares
  • 3 posts
Posted 24 October 2019 - 03:40 PM
Thank you Zipper,I did a little expirement, I CUT ONE OF THE CAPACITOR LEADS, then tried to operate a car,The car worked fine when pulling the trigger on the controller,So there must be some relation to the track besides spark arrest for this capacitor,,and No the track didn't get hot like you had asked.Phil usa
#4 Dave Crevie
  • 4,580 posts
Posted 24 October 2019 - 04:23 PM
Those capacitors are only for RF suppression, so that kids playing with the track won't ruin daddy's TV reception
on Superbowl Sunday. Most home set cars also have them across the lugs on the motors. We always cut them off
so they don't pop during a race and make a mess inside the car.
  • Rotorranch likes this
#5 Rotorranch
Rotorranch
    What's a title?
  • 1,755 posts
Posted 24 October 2019 - 04:35 PM
Phil,
The cap is for RFI interference only. If it shorted out, it will prevent that lane from running. I will venture a guess that if you check the cap with your DVM, it'll show a dead short.
Rotor
Jeff Chambers
                                         "Kinky Kar"
#6 Philip Soares
Philip Soares
  • 3 posts
Posted 24 October 2019 - 07:39 PM
Thank you Rotor,my meter showed continuity when both LEADS were touched to the legs of the capacitor,which is a failed,shorted capacitor.After cutting away the capacitor the lane worked fine, thanks again, Phil,USA indy
#7 Rotorranch
Rotorranch
    What's a title?
  • 1,755 posts
Posted 24 October 2019 - 07:54 PM
It won't cause any issues with the performance of the cars or track. You may, however, get extra "rice krispies" on your AM radio.
Rotor
Jeff Chambers
                                         "Kinky Kar"
