Can a mag chassis be soldered?
11 replies to this topic
#1 NHBandit
NHBandit
  • 128 posts
Posted 30 October 2019 - 02:42 PM
Here's my dilemma. I just bought some stuff on eBay and among the parts was a Cox mag chassis I intended to use for a project. The combination of the usual corrosion and the sellers fuzzy out-of-focus pics made me think it was just needing a mild blasting with glass beads.
Once clean it became obvious that not only had someone drilled out the holes for the rear axle to use with oillites or bearings but both holes were also cracked all the way through. So because the seller pretty much says in all of his auctions to expect damages and that he doesn't take returns (what a coincidence), I'm thinking I might try to fix it.
Can I solder in a pair of oillights and call it good or is it junk? What say the experts?
Mark Sturtevant
#2 Jason Holmes
Jason Holmes
  • 1,045 posts
Posted 30 October 2019 - 02:56 PM
Mark
I believe you can just glue in the oilites. Don't think you can solder mag. A lot of Retro racers glue in their bearings.
jason
  • Ramcatlarry likes this
#3 NHBandit
NHBandit
  • 128 posts
Posted 30 October 2019 - 03:04 PM
That's what I suspected.
Any particular kind of glue? I've got JB Weld.
Mark Sturtevant
#4 havlicek
Posted 30 October 2019 - 03:07 PM
Personally speaking, I'd find a close fit for the OD in brass tubing, cut off a couple of short pieces with notches to clear the chassis connections. Then, clean the area well where the tube pieces will fit over the cracked sections immediately before working on it and slather-on some JB Weld. After setting, any part of the brass and/or JB Weld repair that's proud of the chassis can be sanded flush. I think this would have a good chance of working well. Whatever you do, don't try an acetylene torch (just kidding, but I did see that done to a magnesium loading dock ramp when I was a kid working at a scrap yard. It made for great entertainment... for a while anyway).
After the above, the oilites or bearings can also be epoxied-in and that will help strengthen the area even more.
If you'll be using oilites, make sure they are clean and dry before epoxying them in.
  • NHBandit and Jesse Gonzales like this
#5 NHBandit
NHBandit
  • 128 posts
Posted 30 October 2019 - 03:29 PM
But setting magnesium on fire is so much fun. I remember we did that in high school science class and it sure did burn bright.
And... don't even get me started with salvage yard stories. I spent half my life managing salvage yards. You should see how high you can launch a guy sitting on a couch when you set off three airbags under the couch...
Thanks for the advice. I'll give that a try.
  • Rotorranch and Jesse Gonzales like this
Mark Sturtevant
#6 MattD
MattD
  • 2,632 posts
Posted 30 October 2019 - 04:40 PM
I would epoxy bushings in and I would come up with some kind of girdle around the outside that I would epoxy around the outside of the whole bearing ears.
  • NHBandit likes this
Vintage Cox Slot Cars
#7 NHBandit
NHBandit
  • 128 posts
Posted 30 October 2019 - 05:02 PM
Thanks guys. Did the "girdle" trick and now I need to order some oillites. And FYI a spent 9mm round if you cut it near the base is thick walled Brass and exactly the right ID.
  • Rotorranch likes this
Mark Sturtevant
#8 Lone Wolf
Lone Wolf
  • 2,352 posts
Posted 30 October 2019 - 05:51 PM
You can span the area between the holes with a 1/4" I.D. brass tube that will fit behind the motor. You can then use standard oilites. The tube can be epoxied in and the full length tube will ad strength to the compromised area.
Joe Lupo
#9 Rotorranch
Rotorranch
    What's a title?
  • 1,298 posts
Posted 30 October 2019 - 06:19 PM
ROFLMAO!
Rotor
Jeff Chambers
                                         "Kinky Kar"
#10 Phil Hackett
  • 5,004 posts
  • Location:Was Silicon Beach Adjacent - Now the Playa District
Posted 01 November 2019 - 11:47 AM
If you're soldering with a torch, mag can be ignited. If you're using a soldering iron you won't get fire. Mag burns when the melting point is exceeded. I have never seen a 1200°F soldering iron with enough mass to light off mag. Open flames are much hotter.
To answer the question: yes, you can solder mag but it's not easy and you'd need a fixture to hold everything while heating and then there's a flux somewhere that used for it. Acid flux wouldn't work, neither would paste flux. Mag is also like aluminum where the metal being heated looks OK until it melts. It doesn't turn red or change colors as it gets hotter (this applies to torch heating since a soldering iron just doesn't have the capacity to melt mag).
I'd use JB weld. DO NOT HEAT JB Weld. It works best if it sets at room temperature to about 150°F max. Make a fixture for holding everything in alignment and then use wax paper or car wax to keep the epoxy from sticking to things it shouldn't.
  • Jason Holmes likes this
#11 Dallas Racer
Dallas Racer
  • 2,324 posts
Posted 01 November 2019 - 12:13 PM
It doesn't matter what stipulations the seller makes, eBay will require the seller to pay for return shipping and refund your money in full.
  • MattD and NHBandit like this
Phil Smith ® ©
#12 MattD
MattD
  • 2,632 posts
Posted 01 November 2019 - 02:34 PM
Same deal as a seller saying if you want your purchase insured, you must request it and pay for it..  Seller states I am not responsible for the Post Office delivery".    That doesn't work.   Seller is still liable if you use Paypal, just as Phil said.   Ebay pretty much sides with the buyer on any  problems.
  • Dallas Racer, Jason Holmes and NHBandit like this
