For Sale: Koford M325J power supply
#1 ThunderThumb
ThunderThumb
  • 275 posts
Posted 28 November 2019 - 12:44 PM
Koford M325J , plugged it in and works fine , comes with box , retails for $345.21 , if your looking for one here you go , this is the newer faster reacting power supply , the early versions lagged a bit when you turned up the voltage , comes with the original Koford box , looks new with no dents or scratches in it , this is Koford's Best Power Supply , $290.00 shipped to the Continental 48 States , I will double box when I ship it , I will pay the SlotBlog fee
M325J Digital switching power supply for cool operation with motors which pull high current at low voltage such as G7 and drag motors. Low voltage break in reduces comm heat and arcing.  Ideal for breaking in motors at 1-2 volts and 5 to 10 amps which would cause a M325H to overheat.  With standard power supplies breaking in at low voltage makes the supply run hotter.  The switching design of the M325J makes it run cooler as the voltage is turned down.  Up to 12 volts and electronically current limited to 16 amps.   Koford power supplies are the only slot car power supply that  regulate the output voltage so that as a motor breaks in and the current decreases the output voltage does not change. Smaller size and higher current then competitors. Digital read out  and fan.  It is a compact 4" wide x 5-1/2" deep (not including cord), and is 3" tall.  It weights only 2 lb 14 oz. Excellent for power hungry accessories like tire truers and comm lathes. The new standard for slot power supplies! $345.21 ea.
Earl Anderson
#2 PCH Parts Express
PCH Parts Express
  • 2,215 posts
Posted 28 November 2019 - 03:49 PM
That power supply is first class living... Treated with care..it should last 30 years.
Scott Salzberg
PCH Parts Express
#3 ThunderThumb
ThunderThumb
  • 275 posts
Posted 29 November 2019 - 03:33 PM
Here is a picture of the box.
Earl Anderson
