A variety of newer RTR products
#1 Ralph Thorne
Ralph Thorne
  • 2,152 posts
Posted 03 December 2019 - 02:21 PM
It's been a busy year, and not all of our new product announcements made there way over to Slotblog, so here's a quick recap of some of the smaller things. These are all available at ERI, and on our website. We have about five more things coming very soon too!
Our new drill blank axles are the new gold standard for 3/32" rear axles. Made from actual drill blank material. Long lasting and true axles at an unbeatable price!
Price $17.50 per 10 pack. Full discounts to distributors and tracks.
The RTR curved Lexan scissors cut through bodies like a hot knife through butter. The curved-tip design allows the user to reach into corners and create sharp, smooth radius curves. The ergonomic handle makes operation comfortable. Also useful as a regular pair of scissors. Every workbench should have a pair or two!
Price $7.99. Full discounts to distributors and tracks.
With modern chassis getting stronger and stronger, the older guide tongue benders just weren't cutting it anymore. We increased the size to allow more leverage and easier tweaking. It's made from stainless steel, and all of the hardware is stainless steel also. It comes with everything you need to use it. Just unscrew the thumb screw, place one washer on the top and bottom of the guide tongue and thread the thumb screw back into the handle.
Price $24.99. Full discounts to distributors and tracks.
Check out our all new high quality 60/40 rosin core solder. It is .08mm /.032" thick so it flows easy and smooth. The cap has a hole in it for easy dispensing, and it stores easy without spilling. No more need to carry huge solder rolls around anymore and it's priced so low you can't not try it out.
Price $2.99. Full discounts to distributors and tracks.
New Stay-Clean Flux Pen. Filled with original Stay-Clean acid flux, the pen has high quality bristles and a spill tight cap.
1) Before first use, twist the non-brush side of the pen, it can only go one direction, until the air bubbles are gone.
and it begins to dispense flux.
2) Once the flux begins to dispense for the first time wipe it on a paper towel to insure there won’t be too much.
excess.
3) Each additional use only requires a few twists of the cap and light pressure to control flux usage.
Price $4.99. Full discounts to distributors and tracks.
Now we also have, available separately, precision 3/32" drill blank jig axles. Measures 4" long. These can be used as a direct replacement for our Bearing/Bushing Alignment Tools, or on their own in almost any standard jig.
Price $3.49. Full discounts to distributors and tracks.
New medium tension motor springs. These are a nice three-coil spring, that put out roughly 170 grams of pressure on our scale, stronger then your standard "light" spring. They work great on FK set ups with open style arms in them. Sold by the card, six pairs to a card.
Price $11.99. Full discounts to distributors and tracks.
#2 team burrito
team burrito
  • 2,202 posts
Posted 04 December 2019 - 12:06 AM
i like the acid pen; i've been using a paint pen myself.
Russ Toy (not Troy)
#3 Ralph Thorne
Ralph Thorne
  • 2,152 posts
Posted 08 May 2020 - 09:30 AM
Our 3/32" drill blank axles are back in stock!
Available here: http://ralphthornera...dware_c_22.html
