Red Fox GT12 chassis build instructions?
19 replies to this topic
#1 Tim Wood
Tim Wood
  • 398 posts
Posted 04 December 2019 - 10:16 AM
Anywhere you can get instructions or a layout showing where parts go to build unassembled newer version Red Fox GT12 chassis? Can look at pics of assembled ones but would be much easier with some instructions/location of parts to be assembled.
Thanks,
Tim
Tim Wood
#2 Tim Wood
Tim Wood
  • 398 posts
Posted 08 December 2019 - 03:42 PM
Just looked at Assembled chassis on Pacific Slot Cars website up in Washington and looked at Scotts PCH website, these are for the RedFox GT12 chassis and got 2 differant assembled cross members rear of chassis with parts reversed on each chassis. Trying to install this chassis which way is the right way to install the cross member and attach the parts. Not only is the cross member turned over and installed differant also the slotted small parts are reversed on the center section and the pans. What is the proper installation of these parts. Redfox are you available to show a picture or instructions, please chim in and help solve the puzzle ? of your chassis. I do not want to proceed until I get it the way it was designed. Forgot to add missing a part for the guide piece, instead gave me an extra front pin tube part. Oh well I can make it work on that part missing. ?
Thanks for any help from anyone who uses these chassis. Big race coming up and want to start using these cars.
  Tim
  • Phil Beukema likes this
Tim Wood
#3 Frankie Schaffier
Frankie Schaffier
  • 365 posts
Posted 08 December 2019 - 07:50 PM
Tim,
I have an assembled RedFox GT12 chassis. I'll get you some pictures early tomorrow.
I'm not sure how to post pictures here; may need to send me your email and I'll send them to you that way.
  • Roy Lievanos and Tim Wood like this
Frankie
Rob Voska's only friend.
#4 Frankie Schaffier
Frankie Schaffier
  • 365 posts
Posted 09 December 2019 - 09:50 AM
  • Ramcatlarry, Tim Neja and Tim Wood like this
Frankie
#5 Tim Wood
Tim Wood
  • 398 posts
Posted 09 December 2019 - 09:36 PM
Thanks Frank,
  Much appreciated
Tim
Tim Wood
#6 Tim Wood
Tim Wood
  • 398 posts
Posted 15 December 2019 - 09:51 AM
Thanks to all for response on chassis build, Now how do I get rid of the rust on chassis after build. I was told this was treated steal. Any suggestions, Thanks again, Tim
I am not going to buy a Tumbler. If using a tumbler is best way, I have a friend. :good:  Merry Christmas
Tim Wood
#7 glueside
glueside
  • 434 posts
Posted 15 December 2019 - 09:56 AM
Tumbler or maybe Navy Jelly:
https://www.amazon.c...sl_5b8lblx22a_b
  • Tim Wood likes this
Jeff Strause
#8 Frankie Schaffier
Frankie Schaffier
  • 365 posts
Posted 15 December 2019 - 10:58 AM
Tim... Not sure how to get the rust off... But to keep it from rusting. You probably already know, but I've had a couple guys ask why my stuff don't rust up. I use the same oil I use for the axles, a couple drops on my finger and wipe down the chassis at the end of the day. The biggest culprit seems to be finger prints causing rust, probably from sweaty hands at the track. I just keep a thin layer of the axle oil on it at all times.
  • Tim Neja and Tim Wood like this
Frankie
#9 swodem
swodem
  • 1,176 posts
Posted 07 January 2020 - 07:22 PM
https://www.wd40.com...s/rust-remover/
Steve Meadows
#10 pmwslots
pmwslots
  • 49 posts
Posted 10 January 2020 - 01:18 PM
what is the name of the oil if you don't mind sharing ?
Perry
Perry Walters
#11 Frankie Schaffier
Frankie Schaffier
  • 365 posts
Posted 11 January 2020 - 06:26 AM
Good morning Perry,  I just use the Champion axle oil that comes in the little bottle with the needle applicator.. If you need a picture of the bottle let me know, I'd be happy to send it to you.
  • pmwslots likes this
Frankie
#12 Rob Voska
Rob Voska
  • 1,133 posts
Posted 12 January 2020 - 08:50 AM
1st rule is don't let the rust start! (very hard to do)  In europe chassis get washed and scrubbed with water & a cleaner like "Zoro" (not available in US) a tooth brush and scrub brushes.  It's similar to comet, zud or bar keepers friend but less abrasive.  Chassis is oiled and I wrap mine in a paper towel and then a ziploc bag.  The acid flux rusts them like crazy.
#13 pmwslots
pmwslots
  • 49 posts
Posted 12 January 2020 - 10:02 AM
that would be great Frankie.
Perry Walters
#14 Rotorranch
Rotorranch
    What's a title?
  • 1,755 posts
Posted 12 January 2020 - 03:54 PM
  • Frankie Schaffier and pmwslots like this
Jeff Chambers
                                         "Kinky Kar"
#15 Frankie Schaffier
Frankie Schaffier
  • 365 posts
Posted 12 January 2020 - 06:12 PM
Perry... Looks like I've moved on from the Champion, now using Epic.. I'm guessing about any of the oil would work for you.
  • pmwslots and Tim Wood like this
Frankie
#16 Rotorranch
Rotorranch
    What's a title?
  • 1,755 posts
Posted 12 January 2020 - 06:39 PM
I usually use this.
My 20 year old can of WD 40.
Rotor
Jeff Chambers
                                         "Kinky Kar"
#17 Rotorranch
Rotorranch
    What's a title?
  • 1,755 posts
Posted 12 January 2020 - 06:51 PM
Go remove the rust without screwing anything up, pull the motor and tires, and soak in this stuff. Use as directed.
Rotor
  • Tim Neja, swodem and Tim Wood like this
Jeff Chambers
                                         "Kinky Kar"
#18 pmwslots
pmwslots
  • 49 posts
Posted 12 January 2020 - 07:52 PM
ty Sir
  • Frankie Schaffier likes this
Perry Walters
#19 ropon
ropon
  • 271 posts
Posted 03 March 2021 - 01:53 PM
I recently built a Mack Bulldog 3. Forgot to wash it and left it out for several days. Rust city so I cleaned it and sprayed a light coating of Rustoleum Clear on it. No further problems with rust.
Ron Vincek
#20 ropon
ropon
  • 271 posts
Double post, oops. Deleted.
Ron Vincek
