Rotorranch's Pablo-built IRRA legal Stock Car
41 replies to this topic
#1 Pablo
  • 18,364 posts
Posted 15 December 2019 - 06:41 PM
I'll be doing everything on this car except the paint. Parts are all premium quality cool guy stuff, as usual. If you are a big fan of Tony P's work (especially retro stock cars) like I am, you will see a lot of his influence here  :dance3:  :D
The parts tub on left side is all stuff to be used for sure. The right hand tub is me playing around with different brackets/nosepieces/rail configurations, tongues, etc.
  • tonyp, miko, Peter Horvath and 4 others like this
#2 Geary Carrier
Geary Carrier
  • 610 posts
Posted 15 December 2019 - 06:44 PM
A pile o parts is always a good start... :good:
  • Pablo and tonyp like this
#3 Pablo
  • 18,364 posts
Posted 16 December 2019 - 09:07 PM
The Bartos double ball bearing front wheels are quality products, nice and hard. Both mike .827. I'll true them down just a hair to get to fresh rubber
One is slightly wider than the other and I will fix that. Perfection of parts makes my job easier
  • Peter Horvath and Rotorranch like this
#4 Jaeger Team
Jaeger Team
  • 444 posts
Posted 17 December 2019 - 04:46 AM
:popcorm1:
Maurizio Salerno
#5 Pablo
  • 18,364 posts
Posted 17 December 2019 - 07:29 PM
If I can make it work, this nosepiece has the basic dimensions I want. I (roughly) cut it out from a kit. The axle hole heights are wrong, but if I bend them inward until the jig wheels are at ground zero I'll be good to go. No guarantees; that's why I didn't finish the cuts yet. Rgeo "front" retro jig wheels will give .050" clearance with .820" stocker fronts
#6 Pablo
  • 18,364 posts
Posted 17 December 2019 - 08:45 PM
Yes, this will work  :)  For now, that's all I can say. Tomorrow, I'll perfect it and begin motor bracket/rail planning
  • tonyp, Peter Horvath and Geary Carrier like this
#7 Pablo
  • 18,364 posts
Posted 18 December 2019 - 07:37 PM
Planning - juggling bracket/rails/nosepiece, I had several motor bracket choices and I chose the Chicagoland 7/8. It will meet my rail plans, it's multi-.039 wire friendly, it spaces nice due to the brass width being .040, has a slight downward angle for the motor, an inner .039 rail slides under to nest the motor, etc. :good:
Nosepiece will need some more work to accept rails and clear flag rotation. No problemo :)
  • Peter Horvath, Rotorranch and Geary Carrier like this
#8 Pablo
  • 18,364 posts
Posted 19 December 2019 - 06:54 PM
The flag needed more rotation clearance, so I clipped an FSF nosepiece on and used it as a pattern to Sharpie mark it
Then I carved the curve, band sawed the other cuts, and etched alignment marks on nosepiece and 2 degree Swiss tongue. Hogged the axle holes out to 1/8", got a dummy axle in place jigged up with RGeo "front" jig wheels, and set the 3/4" guide lead. Time to heat up the 455 Hakko for some dummy axle tacking and tongue floating  :)  :aggressive:
  • Rotorranch and Geary Carrier like this
#9 Pablo
  • 18,364 posts
Posted 19 December 2019 - 09:55 PM
Nosepiece/tongue done. Rail notches will be widened as needed later
  • Peter Horvath, Rotorranch, Geary Carrier and 1 other like this
#10 Rotorranch
Rotorranch
    What's a title?
  • 1,755 posts
Posted 20 December 2019 - 05:28 AM
:sun_bespectacled:
Jeff Chambers
                                         "Kinky Kar"
#11 Pablo
  • 18,364 posts
Posted 20 December 2019 - 07:00 PM
All jigged up. No need for jig wheels at this point because the dummy has the front end set, and the motor bracket will use bearings straight on it without a tube. Looks easy, and it is. But making everything perfect takes me a long time.
Cut a bunch of .039 rail wires. I find it easier to take the time and do it right - first I flatten and radius each end, then hand sand each one. Then clean with isopropyl alcohol, and check for straightness. A group like this is easy to check, no dial indicator needed - rolling them across a flat block will indicate any problems. These were perfect, not a single bad apple in the bunch. Ready to become rails
  • Peter Horvath, Rotorranch, olescratch and 1 other like this
#12 Pablo
  • 18,364 posts
Posted 21 December 2019 - 10:27 PM
Math says eight .039 rails per side will fit. That's one inside, one at bracket face notch, one outside, 5 more to follow. Just like making a sandwich, only with a digital micrometer  :)
Little alligator clips come in real handy for situations like this. I used silver solder on this piece because I don't want it melting when the bearings are installed
Now we have a 2 more wire braces for the bracket, and the first four rails on each side support the bracket connection in some way. The final four rails will simply be rails with no bends. Cross wire piece up front is a dummy to temporarily keep the rails in check
#13 Pablo
  • 18,364 posts
Posted 22 December 2019 - 10:24 PM
All rails in place, scrubbed up and quality checked
#14 Pablo
  • 18,364 posts
Posted 23 December 2019 - 09:41 AM
A couple guys have asked me about this, so I'm showing this photo. Sorry for shaking, I had to hold the ruler and camera same time LOL The question was, "have you screwed in the jig motor to ensure motor doesn't hang below chassis?" My answer was, no, but I did place the jig motor on it and checked it carefully. It is designed perfectly, slightly hypoid, face is angled down so front of motor sits at ground zero when uprights are flat on deck. Uprights are easy to bend (did mine with pliers and masking tape to avoid scratching it) and only took one minor tweak with fingers of the uprights to make them perfect in all respects. Screw holes are perfectly placed, motor shaft hole is big enough to use a 9T pinion without enlarging it, axle holes are in perfect positions to give proper clearance.
I give it  :good:  :good:  :good: product rating. Here is the money shot, it's screwed in tight for your viewing pleasure, and I'm guessing that's about 7 thou daylight under the front edge of the motor  :curtsey:
  • tonyp, Rotorranch, Geary Carrier and 1 other like this
#15 Pablo
  • 18,364 posts
Posted 23 December 2019 - 08:18 PM
Rails connected to nosepiece and braced with .039 wire pieces
  • Peter Horvath, Geary Carrier and Jaeger Team like this
#16 Upfront slot cars
Upfront slot cars
  • 269 posts
Posted 23 December 2019 - 08:28 PM
Great step by step ! I learned something ! I had never thought of using an alligator clip to hold that top brace on while soldering it ! Thanks !!!!
  • S.O. Watt and Danny Zona like this
Andrew Ford
#17 Pablo
  • 18,364 posts
Posted 23 December 2019 - 08:45 PM
:clapping:  :)
#18 MSwiss
  • 25,623 posts
Posted 23 December 2019 - 08:48 PM
Andrew,
What were you using before?
Something fashioned from leftover copper tubing from your still(s)? LOL
#19 Pablo
  • 18,364 posts
Posted 23 December 2019 - 08:57 PM
I get a sick thrill from burning my fingers only on rare vintage builds, not so much on retro LOL
  • MSwiss likes this
#20 Bill from NH
  • 14,317 posts
Posted 24 December 2019 - 07:13 AM
With vintage builds do burnt fingers smell better? :)
#21 Pablo
  • 18,364 posts
Posted 24 December 2019 - 11:23 PM
Fowler deck, Tony P. style. 15 thou brass governed by 25 thou wire pieces inside 1/16" tubes.
I didn't invent this stuff, I'm just copying the masters
  • slotbaker, Peter Horvath, Rotorranch and 3 others like this
#22 Pablo
  • 18,364 posts
Posted 25 December 2019 - 09:32 PM
Long pans nested in the jig at a perfect 2.999" width. Mike Katz style  :)
  • Peter Horvath and Geary Carrier like this
#23 Pablo
  • 18,364 posts
Posted 26 December 2019 - 07:22 PM
Pan management will be "old skool" twin .032 wire hinges. They nest close to the (.063) hinge tubes so they needed to be notched. All wires tinned, cleaned, and bent. I'm showing one pin tube set, which consists of .063 tubes inside 3/32 tubes to slightly elevate the body connections. There will be three pins per side  :)
Hey Rotor, do you remember I asked you what color you planned to paint the body? 1/4 oz. Team Associated weight is ready for prime/paint. Once dry, it will be permanently affixed atop the Fowler Deck
#24 Pablo
  • 18,364 posts
Posted 27 December 2019 - 09:57 PM
Elevated pin tubes; three per side  :)
Rotor asked me "why six tubes?" My answer:
-better body connection to the pans
-redundancy - if you lose a pin, you're still in the race
-even if you chose not to put pins in the middle tubes, having that 3/32 tube piece right at the edge of the pan provides extra support for the body skirt as it flexes under cornering
-adds strength to those extra long pans on an extra long 4.5" stock car body
-it's all weight down low, no CG penalty
-psyches out the competition  :crazy:
  • Peter Horvath, Rotorranch, Racer36 and 1 other like this
#25 Pablo
  • 18,364 posts
Posted 28 December 2019 - 11:35 PM
Dummy front axle removed, Bartos axle installed. Braced to never fail  :)
