BackTrack dual tire truer O-ring drive belts?
6 replies to this topic
#1 ThunderThumb
ThunderThumb
  • 193 posts
Posted 14 January 2020 - 01:28 PM
Does anybody know what OD or ID and thickness the O-rings should be? Or a McMaster-Carr part number?
Thanks
Earl Anderson
#2 MSwiss
  • 22,330 posts
Posted 14 January 2020 - 01:40 PM
I think most people just go into Ace Hardware with an existing one to match it up, or try a slightly smaller size.
That's what I did, until I bought a 382 pc.asst. box from Harbor Freight, for $7.99.
O-Ring Assortment, 382 Pc.
If the above doesn't work for you, I can check with Geary to get the exact info.
  • Tex likes this
#3 ThunderThumb
ThunderThumb
  • 193 posts
Posted 14 January 2020 - 01:44 PM
Mike, if you could, as I want to try and see if there are some made in America as the overseas versions deteriorate fast.
So if the size is available that would be great.
Thanks
  • MSwiss likes this
Earl Anderson
#4 bluecars
bluecars
  • 1,240 posts
Posted 14 January 2020 - 04:23 PM
Got mine at local hardware store.
Robert "Red" Valantine :diablo:
#5 ThunderThumb
ThunderThumb
  • 193 posts
Posted 14 January 2020 - 05:47 PM
I want to order from McMaster Carr so I need the correct size , thanks
Earl Anderson
#6 Ramcatlarry
  • 2,456 posts
Posted 15 January 2020 - 01:20 PM
FYI:  Parma used O-rings on the old rental Whisperjets. Buna-N (nitryl) belts were cheap, but did break. They ended up using the clear material belts to last longer. Not sure of the material - silicone or ? The extra loads of grinding two tire may be making an extra stress on the belts.
Host 2006 ISRA/USA Nats
#7 MSwiss
  • 22,330 posts
Posted 15 January 2020 - 01:41 PM
Earl,
Here's what I got from Geary;
The O-ring sizes are:
(2) 1-5/8 ID x 1-13/16 OD x 3/32"
(1) 1-3/8 ID x 1-9/16 OD x 3/32"
  • gc4895 likes this
