Gearing help...
Posted 11 February 2020 - 04:54 PM
Stock Car
Can Am
F1
Theyve gotta be different due to wheel size. *shrug*
Thanks in advance.
Posted 11 February 2020 - 05:01 PM
All three classes use .8125 OD minimum rear wheels and to answer the question we need to know what motor you are running. If It's IRRA®, and you are using JK Hawk Retro motors, gearing is pretty standard across the board, 9/28.
If you are racing RETRO rules, the Pro Slot FK motors are mandated 8T pinion and also use about a 28T crown.
Posted 11 February 2020 - 05:12 PM
Posted 11 February 2020 - 05:43 PM
Depends on the track, mostly 9/27 or 28.
Posted 11 February 2020 - 05:46 PM
For Stock Cars 8/28 for better control.
- Ramcatlarry and Half Fast like this
Posted 11 February 2020 - 06:25 PM
Flat track likes the 8T as well.
racing around Chicago-land
Posted 11 February 2020 - 06:59 PM
Posted 11 February 2020 - 07:04 PM
What Noose said. Sometimes on a shorter track I'll bump the crown up a tooth
- crazyphysicsteacher likes this
Posted 11 February 2020 - 07:21 PM
3 crowns, 2 pinions should cover most anything.
8 and 9 pinion, 37, 38, 39 crowns.
Rotor
"Kinky Kar"
Posted 11 February 2020 - 09:28 PM
Rotor
27, 28, 29!
- Ramcatlarry, NSwanberg and crazyphysicsteacher like this
Posted 12 February 2020 - 06:36 AM
27, 28, 29!
DOH!!!
Brain fart!
Rotor
"Kinky Kar"
