Flexi chassis
13 replies to this topic
#1 Shooter7mustang
Shooter7mustang
  • 215 posts
Posted 11 February 2020 - 05:50 PM
Any way or suggestions on polishing Flexi type chassis?
Kevin Myhaver
Bad Dog Racing
Color Me Gone
#2 Pablo
  • 18,467 posts
Posted 11 February 2020 - 06:15 PM
Tumbling.
  • Tim Neja and Shooter7mustang like this
#3 Ramcatlarry
  • 2,955 posts
Posted 11 February 2020 - 06:21 PM
Over the years many different plating processes have been used for chassis including chrome and nickel plating as well as the early ones that used a (?) zinc/flat finish that did not age well. The early one is the one you had to grind off in order to solder to the frame. I usually use Scotchbrite and cleanser to go beyond the wire brush work.
  • Shooter7mustang likes this
#4 Jay Guard
  • 2,886 posts
Posted 11 February 2020 - 06:27 PM
For a chrome or nickel finish that's not too corroded I would recommend just polishing with a good polish like Simichrome. If it's corroded and somewhat pitted tumbling would probably be the right thing.
However if it's got a zinc plating like the Parma Flexi 1's tumbling is a very bad idea. Tumbling will polish it a bit but it will also leave a dull gray zinc coating on your tumbling media which will transmit itself onto anything else you try to tumble/polish after that.
How do I know this? Experience!
  • Ramcatlarry, Tim Neja, Samiam and 1 other like this
#5 Shooter7mustang
Shooter7mustang
  • 215 posts
Posted 11 February 2020 - 06:45 PM
Newer JKs
Kevin Myhaver
Bad Dog Racing
Color Me Gone
#6 Rotorranch
Rotorranch
    What's a title?
  • 1,755 posts
Posted 11 February 2020 - 07:13 PM
Newer JKs
How shiny do you want it?
Tumbler will shine and de-burr the chassis. Buffing wheel on a grinder can result in a mirror surface.
Rotor
Jeff Chambers
                                         "Kinky Kar"
#7 Pappy
Pappy
  • 14,132 posts
Posted 11 February 2020 - 08:29 PM
I like the mirror finish, myself. The turn marshals always notice it first when it's on it's top.  :laugh2:
  • aquavelvis, Rotorranch, Samiam and 1 other like this
Jim "Butch" Dunaway
#8 Shooter7mustang
Shooter7mustang
  • 215 posts
Posted 12 February 2020 - 09:26 AM
Rotor
What media ?
Kevin Myhaver
Bad Dog Racing
Color Me Gone
#9 ThunderThumb
ThunderThumb
  • 400 posts
Posted 12 February 2020 - 09:32 AM
Soak them in Evaporust , harbor frieght and Autozone has it , work good on steel items , use a foil pan for cooking to soak it in , leave it in for a day and its not acid or toxic either
  • Rotorranch and Shooter7mustang like this
Earl Anderson
#10 gotboostedvr6
  • 2,321 posts
Posted 12 February 2020 - 09:35 AM
Any metal polish will work
David Parrotta
#11 Rotorranch
Rotorranch
    What's a title?
  • 1,755 posts
Posted 12 February 2020 - 09:37 AM
I bought the ceramic triangles media from Buffalo Arms.
Rotor
Jeff Chambers
                                         "Kinky Kar"
#12 MSwiss
  • 25,955 posts
Posted 12 February 2020 - 09:44 AM
The below is with Buffalo Arms angled cylinder, ceramic media, their yellowish detergent, and a dash of Dawn.
How shiny it appears, is dependent on how I want to angle my camera.
I purposely tried to minimize it, to get a clearer pic.
IMO, the duburring is more important than the shine, and I would be careful of doing anything that might affect on how well your motor is soldered in.
IOW, getting polish in the motor box area.
I prefer a duller on the track, than a shiny car in the pits, with the motor dangling by the lead wires.
  • Tim Neja, Bernie and Shooter7mustang like this
#13 mreibman
mreibman
  • 655 posts
Posted 12 February 2020 - 10:06 AM
After wire brush and sanding, I had great success with certain spray paints (aluminum and gold) - with masking around motor and bearing solder points.
When I tried colors, the results were more "not so much"
With the gold on an original flexi-kar, I was asked by an experienced guy, "Was that like the 25th anniversary model or something?" The gold one is parked at the local raceway. I might have the aluminum one handy at home, and will add pics later on.
Now - why did I spray paint? Because I wanted it to look nicer than the crappy finish, no matter how much I brushed and sanded.
Mike Reibman
Alleged amateur racer.
Faster than a speeding Womp.
More powerful than a 36D.
#14 Dave Crevie
  • 4,696 posts
Posted 12 February 2020 - 12:15 PM
To get a true "mirror" finish, there is no substitute for good old elbow grease. Generally I don't polish slot car chassis, but I have done a few. I use
a Dremel with the 1/2 inch dia. polishing bob, first with red rouge, then green emerald polishing paste. Final polish is done by hand with 1200 grit
diamond paste. After so many years of polishing Chromadie plastic injection molds, I've taken to using this method on steel chassis. I works good
on brass, too, but use a slower RPM with the Dremel.
