Air gap and arm diameter for 16D and S16D
6 replies to this topic
#1 ThunderThumb
ThunderThumb
  • 234 posts
Posted 13 March 2020 - 12:09 AM
What is a good air gap to run? The set-up has a .574" AG now. So should I get a .540" dia or a .560" dia armature?
Thanks.
Earl Anderson
#2 Zippity
Zippity
  • 4,859 posts
Posted 13 March 2020 - 12:23 AM
Go for a large diameter armature.
That's what Monty Ohren always recommended :)
Ron Thornton
#3 Bill from NH
  • 11,136 posts
Posted 13 March 2020 - 07:08 AM
I don't think there is any universal package on the "right way " to build a 16D motor.  .540 was a "fat" C-can arm & .560 was a "fat" D-can arm. I don't know what you're looking at now. Any motor isn't necessarily going to run the same on every track you try it. It's apt to be great on one track, a dog on another. I'd build at least a couple motors with different combinations to see how each ran on my particular track. Then go from there. At one time, there was a .585 min hole size for 16D's. I don't know if that rule (maybe a USRA rule?) still exists, but maybe your raceway doesn't use it if it does.
#4 Danny Zona
Danny Zona
  • 1,303 posts
Posted 13 March 2020 - 07:25 AM
The minimum was .575 for 16Ds in USRA back in the day. At least when I raced.
You're never fast enough!!! 💯 Lap times are the only truth. Everything else is just theory.
KELLY RACING 😎
#5 ThunderThumb
ThunderThumb
  • 234 posts
Posted 13 March 2020 - 10:07 AM
This is a play motor so a 574 AG with a 560 arm will work , so a 007 per aid AG is good
Earl Anderson
#6 Bill from NH
  • 11,136 posts
Posted 13 March 2020 - 11:16 AM
You're right Danny, thanks for the correction.
Earl, try what you mentioned & if it goes good, leave it alone.  We tried running scale cars using C-cans with a tight hole & Contender or Super Wasp arms. They ran punchy, so we opened them back up, but the magnets were stronger than 16Ds.
  • Danny Zona likes this
#7 ThunderThumb
ThunderThumb
  • 234 posts
Posted 13 March 2020 - 12:24 PM
Thanks Bill for the info
Earl Anderson
