ESR 1 chassis tutorial?
6 replies to this topic
#1 Slot_Outlaw_24
Slot_Outlaw_24
  • 13 posts
Posted 23 April 2020 - 10:23 PM
So I decided on the ESR1 chassis as my next build. The guy who owns the shop is a big fan of it, and it looks like a great chassis from what he's shown me. It's fast, consistent, and durable.
He gave me a rundown of how to put it together but that was a month or two before the whole COVID mess. Now that I've got a slight break from classes and summer break on the way, I want to start building it and don't remember too much of what he said. I would go in person, but not sure I can do that with quarantine.
How exactly should I put this together? Thankfully I've got a great foundation to start on courtesy of the shop owner. I bought all the wire I'd need and he bent it for me, forming what looks like part of the center chassis. Specifically the wire and tubing holding the front plate to the rear (picture included). I also plan on building it with a wheelie bar.
Any pictures would be greatly appreciated. Hope you can help.
Will Sutkowski
#2 Matt Sheldon
Matt Sheldon
    Duffy's HMI Executive
  • 2,242 posts
Posted 24 April 2020 - 10:22 AM
Hi Will,
Are you looking to build a bar or no bar car? From your pic I am guessing no bar, but want to make sure before I reply. This is a great and easy build. Do you have a jig or most importantly the motorbox assembly jig at least?
  • Slot_Outlaw_24 likes this
Matt Sheldon
#3 Ramcatlarry
  • 2,956 posts
Posted 24 April 2020 - 11:39 AM
1) The rear motor/axle carrier is the first sub-assembly.  One aid is to slip bushings and an axle in place to help line up the parts.
2) Figure out the wheelbase of the body and the overall length to build.  ANY sort of jig block will help to locate the parts - even wood.
3) Locate the rear axle location and how much room under the nose of the body you need for the flag and front axle location.
4) ID how long the wheelie bar needs to be.  Many are a standard distance from rear axle to the wheelie axle (6 inch or so).
5) Line up your pre-bent wire to tie all of the parts together. Cut off the excess and square up the whole thing and start soldering.
Many racers use SS tubing instead of piano wire to save weight and tune the torsional spring of the frame.
#4 Ramcatlarry
  • 2,956 posts
Posted 25 April 2020 - 09:52 PM
FYI:  USDR (United Scale Drag Racers) rule book calls for "Wheelie bars must not exceed 5" from centerline of rear axle to center of wheelie bar axle."  also " Guide flag length is .980" maximum." and "Body must cover guide flag..." and have a 3d interior , .....
Local track rules might vary......
#5 Slot_Outlaw_24
Slot_Outlaw_24
  • 13 posts
Posted 30 April 2020 - 01:15 PM
Hi Will,
 I'm planning on building it with a wheelie bar. I didn't know it needed a jig. I asked the shop owner if it needed one and he said you could build it without one. I do have a wooden tech block that I put my chassis on when I work on them. I might be able to improvise something on that. I did order the motor box assembly jig and that should be a big help.
Will Sutkowski
#6 Ramcatlarry
  • 2,956 posts
Posted 30 April 2020 - 05:51 PM
Any 'jig' usually has marks or locator points to keep things squared up. Some builders have better eye skills than others.  It is always frustrating to finish a build and see it go sideways down the track from not having the parts squared up.
Use a Combination square to draw or scribe lines on a tech block at a minimum.
#7 Slot_Outlaw_24
Slot_Outlaw_24
  • 13 posts
Posted 07 June 2020 - 12:01 AM
I'm not the greatest at making things symmetrical on the first try, and decided to splurge on the jig. It'll be a huge help and will be a good investment.
Will Sutkowski
