Looking to build a 1/32 Womp drag car.
What is a good frame to start with?
Thanks!
Posted 26 April 2020 - 02:56 PM
Thanks!
Posted 26 April 2020 - 03:28 PM
Any steel or brass Womp style frame. I added a short wheelie bar to one and replaced the 16D armature with a Grp 20. Drives like an altered short wheelbase should - a little wild.
racing around Chicago-land
Posted 26 April 2020 - 07:29 PM
Posted 26 April 2020 - 11:58 PM
Steel womp is slightly lighter than brass and the narrow sprints plus is lighter than any full pan frame of this type. Nice thing about these is you can cut the frame off ahead of the motor mount and extend the nose as long as you want with piano wire or tubing. In the late 1980's we made early 1/24 hardbody frames this way before the FCR was designed.
Most of the drag kits can be made any length or width and be lighter than these frames. Why waste a harder to find frame?
Posted 27 April 2020 - 11:23 PM
I tried drag racing a Womp. It was kind of a waste but to each his own. I did not modify the frame so it lives to carve corners when tracks reopen.
Posted 30 September 2020 - 05:30 PM
We have a class for that!...
I have seen some great Womp based modifieds and thought they could make nice Altereds or gassers.
Jim Cunningham
Nomad Raceways
Racing fun anywhere,
anytime for anyone!
Posted 30 September 2020 - 07:23 PM
Just a thought, would using a pin guide be a speed item on a drag car? Since the cars only run in a straight line, would the cars drive any differently?
Posted 30 September 2020 - 08:20 PM
