IRRA R&C Jail Door Sports Car chassis
25 replies to this topic
#1 Pablo
  • 18,454 posts
Posted 29 April 2020 - 01:25 AM
This one will be made to fit a Truescale T70R Lola body like this:
  • Pappy, Tim Neja, DocSlotCar and 3 others like this
#2 Pablo
  • 18,454 posts
Posted 11 May 2020 - 08:03 PM
Specifications and design for the chassis will be almost exactly the same as this Lotus 40 car:
http://slotblog.net/...r-lotus-40-car/
The only differences will be, the front axle tube will be slightly longer, and there is less room for the .875" OD front wheels - it's really tight. So I'll take that into consideration. But it will basically be a carbon copy of the Lotus 40 chassis.
Rough trimming of the body is done for now
  • Lou E, eshorer and Peter Horvath like this
#3 Pablo
  • 18,454 posts
Posted 12 May 2020 - 04:38 PM
Previous JK Jaildoor bracket needed a lot of tweaking to make right. This one, I got lucky, it only needed a slight tweak, a slight boring of the tube holes, and we are off to the races...…...
  • Peter Horvath likes this
#4 SpeedyNH
SpeedyNH
    Old Engineer
  • 763 posts
Posted 12 May 2020 - 06:25 PM
i used to think that the T-70 was one of the worst-handling slotcar bodies, back in the 60's. hope that yours turns out a lot better than mine did!
Steve Lang
#5 Noose
Noose
  • 23,303 posts
Posted 12 May 2020 - 07:19 PM
It was the Pro go to body after the Lotus 40 and just like in real CanAm it was overcome by the McLarens!!! Lol
#6 tonyp
  • 15,325 posts
Posted 13 May 2020 - 09:04 AM
You forgot the 6 weeks the Elfin ruled. Lol
  • Tex and Noose like this
#7 bbr
bbr
  • 2,429 posts
Posted 13 May 2020 - 11:30 AM
It is interesting how things get refined. even with the modern retro racing, when I first started, about ten years past, the grid had all sorts of bodies, now it is all Ti22.
Mike Low
#8 tonyp
  • 15,325 posts
Posted 13 May 2020 - 11:38 AM
Always happens. One or two of bodies of the era always work best.
#9 Tex
  • 9,244 posts
Posted 13 May 2020 - 11:55 AM
I noticed the same, that grids soon became all Ti-22's. My idealistic mind was filled with visions of a good mix of old USRRC and Can-Am cars though. I was running the retro program at DSC and decided to make some changes before the next series began. I announced that spoilers on TI-22's would be limited to 1/4" while leaving all other bodies to use 1/2" spoilers. You'd have thought I said I was gonna shot their grandmas! The track owner told me the majority of racers were very upset with this and wouldn't race. I became so disillusioned(and disappointed in their selfish shortsightedness) that I quit slot racing for over a year.
#10 tonyp
  • 15,325 posts
Posted 13 May 2020 - 12:15 PM
The original rules now looking back should have been bodies that were run on in lines only.
  • Eddie Fleming likes this
#11 Don Weaver
Don Weaver
  • 1,856 posts
Posted 13 May 2020 - 12:58 PM
In the interest of diversity the "Doghouse Raceway" simply banned all Ti-22's.
Don Weaver
L.H. Lapham
it will starve to death...
#12 old & gray
old & gray
  • 1,208 posts
Posted 13 May 2020 - 02:04 PM
While we are "banning" bodies shall we include the Lola Coupe from the GTC class?
Every class I have run either 1) develops a preference for one body (Parma Intrepid in early GTP, O/S Matra in mid 70's GP 7) OR 2) becomes an open season for mold makers to develop the next trick body.
Given the stated goal of retro to have a stable rule base and a consistent performance standard (equal motors, approved bodies, minimum weight) this situation is the logical outcome especially after ten years of experimentation.
Personally I prefer the current state of affairs to a box in the corner of "it was competitive last month, now it's a back marker".
  • Half Fast and John Streisguth like this
Bob Schlain
#13 John Streisguth
John Streisguth
    Johnny VW
  • 5,638 posts
Posted 13 May 2020 - 02:21 PM
And it's interesting to note that most recently approved bodies have no advantage over ones that have been in use for a few years.  IMO, that says a lot about the approval process.  The last paradigm shift was the F1 bodies with "tea tray" rear decks.  Other than that, it's been very stable.
But...enough thread drift...sorry Pablo! :)
  • tonyp and old & gray like this
"Whatever..."
#14 Pablo
  • 18,454 posts
Posted 13 May 2020 - 05:22 PM
No need to be sorry, it's all relevant  :)
When I built the previous (sistership) chassis, I noticed the rails had been moving around a little in the middle with the application of heat. This time, I'm going to prevent that by adding a temp crosspiece, to be removed later. Each rail I add will be tack nailed down. I used tubing, it solders quicker with less heat and it's easier to slice off when the time comes
  • Tex, Peter Horvath and Tracking Angle like this
#15 Pablo
  • 18,454 posts
Posted 13 May 2020 - 06:41 PM
Every now and then I like to get it off the jig for a cleaning and a checkup on my flattest block. So far, so good
  • Pappy and Peter Horvath like this
#16 Don Weaver
Don Weaver
  • 1,856 posts
Posted 13 May 2020 - 07:47 PM
Good idea!
Don Weaver
L.H. Lapham
#17 Pablo
  • 18,454 posts
Posted 14 May 2020 - 06:34 PM
All five rails in place, forward cross tube done, all joints finalized. Now the temp anti-spreader gizmo gets sliced n diced off
Bits removed and rail surfaces cleaned up with Soder-Wick; ready for the hinge assembly
  • Pappy, Lou E and Peter Horvath like this
#18 Pablo
  • 18,454 posts
Posted 15 May 2020 - 06:32 PM
I tried the Mike Katz method of simply curling the first rod around the tongue gizmo using the jig and pin. Worked much better for me, thanks Mike  :)
  • DE38 and Peter Horvath like this
#19 slotcarone
  • 3,990 posts
Posted 15 May 2020 - 07:26 PM
Glad to help! :)
  • Pablo likes this
#20 Pablo
  • 18,454 posts
Posted 16 May 2020 - 08:25 PM
Lola drop arm
Hinge bracing; same as the Lotus 40 chassis
  • Pappy, slotbaker and Peter Horvath like this
#21 Pablo
  • 18,454 posts
Posted 18 May 2020 - 11:01 AM
Wiggle management for the drop arm
  • Pappy, Peter Horvath and old & gray like this
#22 Pablo
  • 18,454 posts
Posted 18 May 2020 - 11:21 PM
After 8 hours of tumbling, my drop arm wiggle management actually improved. I wish you could feel it. It lifts about 15 thou, droops and wiggles a couple thou. Unhindered and smooth. If there is drop arm nirvana, this is it
Lola chassis is done
  • Pappy, Jencar17, Tex and 7 others like this
#23 Alan Dodson
Alan Dodson
  • 179 posts
Posted 19 May 2020 - 10:46 AM
Pablo, do you use K&S brass rod or is there another source you prefer?
#24 Pablo
  • 18,454 posts
Posted 19 May 2020 - 04:26 PM
I've always used K & S. The brass rod, tube, and sheet has always been fine for me. For 1/16 rod, I like the three 12" lengths in packs, part # 8162. I don't even test it, it's always straight.
K & S music wire the last couple years has been hit or miss in straightness. Some of it is really bad. I contacted the company, they denied the problem exists and claim it's straight when it leaves the factory. Baloney. Some builders don't mind if it's wavy. I do.
I still like my method of using dressmaker (thin) pins for the first hole punches. Then I examine the alignment, and if it needs a little movement to correct, I mark with a Sharpie. Then when I go full harpoon I bias it appropriately. In this case, the left side holes need to go forward just a hair.
Boy howdy the front wheel wells are going to be crowded on this Lola  :shok:  :)
  • Lou E, Matt Sheldon, Peter Horvath and 2 others like this
#25 Pablo
  • 18,454 posts
Posted 19 May 2020 - 05:21 PM
Lola body is trimmed/pinned and ready for a trip to Jersey along with the Lotus sistership body for Noose paint  :dance3:
  • Tex, Lou E, Peter Horvath and 1 other like this
