Boring out brass tubing
Posted 21 May 2020 - 02:01 PM
Posted 21 May 2020 - 02:25 PM
See other post.
Posted 21 May 2020 - 06:16 PM
or a reamer.
racing around Chicago-land
Posted 21 May 2020 - 06:45 PM
If your cutting 7/32 round tubing I use a tubing cutter then use an x-acto to de-burr it. If the ends need to be opened up a bit I used the handle end of a round file or the file itself.
If your looking for a normal size tube, 1.400" for example, Chicago Land has them precision cut and very worth the price. No burr's to clean up. They are all I used on my builds.
If your cutting say 3/32 round or square tubing I just use a dremel with a cut off wheel then use an x-acto to de-burr. Some builders will use a mini chop saw to get nice square cuts. These are available through Harbor Freight. Not sure of who else makes them.
Dominic Luongo
NERR photos from 2016 to now
Posted 21 May 2020 - 07:16 PM
Thanks for the props on my 80 cent, precut, 7/32" bearing tubes.
I also make them in 1.1".
Fred,
Are you looking to deburr the axle tube, or actually make the bore larger?
If the latter, why?
I also asked you a question, in your thread, about Cox controllers.
Posted 22 May 2020 - 11:05 PM
Posted 22 May 2020 - 11:22 PM
If so, keep in mind the car is teched for front and rear clearance, with the front wheels on the tech block.
FWIW, very few people race Retro with an axle rotating in a tube.
Posted 22 May 2020 - 11:26 PM
