Boring out brass tubing
7 replies to this topic
#1 Fred_J
Fred_J
  • 135 posts
Posted 21 May 2020 - 02:13 PM
If I wanted to overbore a front axle tube on a slot car, how would I go about it? Would I use, a drill bit or a reamer, or something else?
  • airhead likes this
Fred Jespersen
#2 Dave Crevie
  • 2,183 posts
Posted 21 May 2020 - 02:24 PM
Depends on how much bigger you need to go. Generally a reamer would be the choice since it will follow the bore and not walk off center like a
drill bit could. But don't try to take more than 1/64th at a time. I.E., if you are going from 3/32nds to 1/8th, use a 7/64ths ( .109 ) dia, reamer first,
then follow up with the 1/8th reamer. And use Marvel Mystery Oil to lube the reamer during the reaming operation if the tube is brass. Don't use
a hand drill to drive the reamers. Do it by hand if you have a large pin vice, or loose drill chuck.
#3 MarkH
MarkH
  • 500 posts
Posted 21 May 2020 - 04:05 PM
If you use a drill bit, dull the cutting edge about .003 to .006". It then become more of a scraper eliminating the chatter and self screwing into the tube.
A small fine stone and a couple passes over the cutting will get you there.
Mark Horne
SERG - www.slotcarenduro.club
#4 Matt Sheldon
Matt Sheldon
    Duffy's HMI Executive
  • 2,018 posts
Posted 21 May 2020 - 04:59 PM
Reamer if you have the proper sizes to progress from. Mark's advice on using a dull bit is great! When I have to open up motor brackets regardless if for an axle tube or pinion clearance, I chuck the bit up and then just turn by hand.
Matt Sheldon
#5 airhead
airhead
  • 720 posts
Posted 22 May 2020 - 06:31 AM
McMaster - Carr  has any size reamer you would need.
Billy Watson
#6 Dave Crevie
  • 2,183 posts
Posted 22 May 2020 - 08:54 AM
A drill bit, being two flute, will not cut a truely round hole, even with the rake broken to eliminate the cutting angle. A reamer is always the best choice.
You may be able to borrow what you need from another racer or a local machine shop. You are not the first to run into this problem. It goes way back
to when slot racing began.
#7 Eddie Fleming
  • 1,571 posts
Posted 22 May 2020 - 09:52 AM
Why are you wanting to bore it out in the first place?
Just curious as to what problem you are trying to solve.
#8 MSwiss
  • 22,819 posts
Posted 22 May 2020 - 10:06 AM
Eddie,
I asked him the same question in the other thread by the same name.
http://slotblog.net/...ng/#entry781728
As my post also alludes to, Fred isn't real anxious to answer follow up questions, related to his original question.
