All chassis and Cox magnesium wheels with the same problem ... the white patina always surfaces ....I haven't found a really efficient one yet ...
Who has a simple method to restore them to new ??
Thankkksss !
Posted 15 June 2020 - 12:57 PM
Type in "Cox chassis cleaning" in the Slotblog search engine and click the green button.
https://www.electric...agnesium-parts/
Posted 11 September 2020 - 04:51 PM
I have been doing this a lot lately. This is my preferred methods.
I first put the chassis in the tumbler for a couple of hours. If there are any corners that the media has missed I blast with soda.
Wheels only get the soda blasting. Its does not change the surface in any way it only removes the corrosion.
Then I use a grey primer followed by a gun metal silver paint.
This next step is something I was playing with. I take a soft brush and a pinkish ink and lightly dry brush in random spots on the chassis.
Then last step is a flat clear. Done.
Took the pics in different lighting so you get an idea of the color. Hard to capture.
Posted 11 September 2020 - 05:09 PM
Martin,
What medium are you using in your tumbler? Wet or dry?
Rotor
Posted 11 September 2020 - 06:02 PM
Wet, its a ceramic cone for the most part and a mixture of other shapes.
I got the tumbler second hand an it came with the media. I cover media with tap water and add a cap of laundry soap I have on hand.
