Motor does not trip lap counter
21 replies to this topic
#1 smithspeedway
smithspeedway
  • 310 posts
Posted 29 June 2020 - 01:45 PM
We use an old TrikTrax lap counter with dead strips. It works flawlessly except for one thing. Some motors only trip the laps at half throttle. Some run Sloting Plus motors. Most work fine. One 21k motor does not. All JK motors except the 25k Hawk work fine. I have no idea how to fix this. Are there any old school wizards?
Steve
#2 MSwiss
  • 22,945 posts
Posted 29 June 2020 - 02:23 PM
Most likely no way to fix other than to convert to a photo eye to trip it.
My King has a BSRT system that does not count that motor, and other lower power motors, also.
The back EMF is too low.
#3 smithspeedway
smithspeedway
  • 310 posts
Posted 29 June 2020 - 03:20 PM
What's weird is that we have a division where a lot of guys run a super cheap generic motor like THIS and those work flawlessly. We have a Sloting Plus 300 g/cm motor that does not work, and motors rated at 330 g/cm and 230g/cm that work fine.
So, a junk surplus can motor works fine, as does a Falcon 7. If there was a limit or range I could understand.
#4 MSwiss
  • 22,945 posts
Posted 29 June 2020 - 04:30 PM
The best I can determine it has something to do with very low or neutral timing.
My last post was a bit of a misnomer, referring to lower-power motors.
High-power Phoenix motors don't count until they break in a bit.
And when I did the Hawk 25 longevity test for JK/Jerry Kulich, and car ran 3,200+ real miles, that car didn't count laps for the first 3,000 miles/200 hours.
Even then, it was a bit sporadic.
Apparently your Trik Trax has the same quirk as my BSRT, which is sort of HO-oriented, where I think they typically use light bars.
#5 tonyp
  • 14,842 posts
Posted 29 June 2020 - 04:48 PM
Would a longer dead strip help? You could put tape on the braid to make it longer and see if that works.
  • Pappy likes this
1965 "Evil Bucks Racer" Team
Revtech Team Trinity
Retro East co-founder
First IM Nationals Champion
Arco Champion
ip
#6 MSwiss
  • 22,945 posts
Posted 29 June 2020 - 06:05 PM
A longer dead strip might help, but tape won't make it longer.
That will be just create a longer dead spot between the power and the dead strip.
  • Guillermo Suar likes this
#7 SlotCarsten
SlotCarsten
  • 111 posts
Posted 30 June 2020 - 01:21 AM
I do not know of the specifics for TrikTrax, and I do not know of the specific motor being referenced.
However I can't stop wondering if it is related to the issue with high-timed motors that I discovered some 5 years ago and published in this THREAD.
If that is the case, a diode in series with the deadstrip wirings, and facing the correct way, might possible resolve the issue.
  • Ramcatlarry and NSwanberg like this
Carsten Grønnemann
www.lapmaster.dk
#8 John Streisguth
John Streisguth
    Johnny VW
  • 5,310 posts
Posted 30 June 2020 - 06:10 AM
When I had an HO track in my home, I had dead strips and electromechanical counters. To get the counting reliable, I had to put small capacitors across the terminals of the counters, which acted to increase the pulse length of the voltage.
"Whatever..."
#9 SpeedyNH
SpeedyNH
    Old Engineer
  • 374 posts
Posted 30 June 2020 - 10:31 AM
Also, is there a resistor in series with the dead strips to the counter like some that i've seen?
Steve Lang
#10 smithspeedway
smithspeedway
  • 310 posts
Posted 30 June 2020 - 01:30 PM
Thanks, everyone.
No diodes, resistors, etc. If I try that, what kind of resistors or diodes?
#11 SpeedyNH
SpeedyNH
    Old Engineer
  • 374 posts
Posted 30 June 2020 - 04:50 PM
i was going to suggest lowering the value of or eliminating any resistors, so don't add any.
We should ask John S. what value capacitors he used, e.g. 0.1 microFarad ceramic?
Steve Lang
#12 Ramcatlarry
  • 2,670 posts
Posted 30 June 2020 - 08:25 PM
Since current'is very low, a small diode should be enough. Be sure that the dead strip polarity is opposite of the track power (in order to increase the EMF). The diode will allow it to only count in one travel direction only.
Host 2006 ISRA/USA Nats
#13 John Streisguth
John Streisguth
    Johnny VW
  • 5,310 posts
Posted 30 June 2020 - 09:11 PM
I was surprised, I actually had a complete second set-up that I never used... still have it 25 years later.
I used 220 microfarad electrolytics, polarized.
  • Ramcatlarry likes this
"Whatever..."
#14 Phil Hackett
  • 5,022 posts
  • Location:Was Silicon Beach Adjacent - Now the Playa District
Posted 30 June 2020 - 11:23 PM
We're entering the Wayback Machine for this: back in the olden days the lap counters were basically pinball machine counters. As the cars got faster there was a problem with the lap counter "missing" the count. Neal McCurdy whipped up a circuit that was more sensitive than using the car to trip a relay. I'm not an electronics guru but the circuit would sense the car passing the counter strip and then send an amplified and prolonged pulse to the counter. After the problematic counters were afixed with the circuit there were very few problems.
  • Cheater likes this
#15 Tex
  • 9,092 posts
Posted 01 July 2020 - 08:56 AM
I'm completely unknowledgable about such things, so I figured I'd chime in with what I "think" I overheard when Dallas Slot Cars had a sinmilar problem.....
DSC had such a problem(sporadic) until they made sure each lane had it's own ground, instead of one ground for the whole lot.....
#16 smithspeedway
smithspeedway
  • 310 posts
Posted 01 July 2020 - 09:38 AM
That is interesting. I don't remember which way I wired it in the first place. We use this - https://www.worthpoi...unter-517052043
trik-trax-lane-lap-counter_1_c8e20cd2a8b
There is one common wire to all 6 lanes. If I understand the system correctly, the pulses go out the common wire. The car completes the circuit on the dead strips to allow the pulse to return on one wire, scoring  a lap for that lane. Maybe I can start by reversing the supply and return lines?
#17 smithspeedway
smithspeedway
  • 310 posts
Posted 01 July 2020 - 01:49 PM
So, based on all your info, I said the heck with it and tried reversing all the wires to the dead strips. All motors count perfectly now. I guess I had it wired backwards for ten years.
  • Half Fast, Rotorranch and Shiggy like this
#18 SpeedyNH
SpeedyNH
    Old Engineer
  • 374 posts
Posted 01 July 2020 - 03:02 PM
wow, that's odd. when i've had 'em backwards, i don't think any of 'em worked!
good thinkin'.
now you can add the diodes, capacitors, multiple common wires and everything! (just kidding)
  • smithspeedway likes this
Steve Lang
#19 Rotorranch
Rotorranch
    What's a title?
  • 1,348 posts
Posted 01 July 2020 - 03:55 PM
Glad you figured it out!!!
I was wondering if it was reversed, but didn't want to confuse the issue.
Rotor
Jeff Chambers
                                         "Kinky Kar"
#20 smithspeedway
smithspeedway
  • 310 posts
Posted 01 July 2020 - 07:34 PM
Rotor
Yep, for TEN YEARS. Since it is just a feed line with 6 returns, I never considered that polarity mattered.
#21 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,362 posts
Posted 01 July 2020 - 09:51 PM
Oh Goody!
I like stories with happy endings :)
Cheers
Faster then, wiser now.
#22 SpeedyNH
SpeedyNH
    Old Engineer
  • 374 posts
Posted 01 July 2020 - 11:56 PM
yep, polarity: in my experience, most commercial dead-strip counters only use the negative half of the back EMF waveform when a car under power travels through the isolated sensor section and ignore/clip off the positive part of the AC waveform.
first time i hooked one up at a commercial raceway, i couldn't Believe that the thing had to be wired 'backwards' in order to work! then i took a look at the front-end circuitry on the counter card, and sure enough, that's what it was looking for.
i did double (or quad, can't remember) up on the return (common) wire on one track with a long counter cable (Queen City Engleman) and isolate the lanes somewhat, because if a bunch of cars went through the counter together simul, the signal strength on a lane might become slightly distorted sharing one return wire and fall off some in amplitude when i looked at it on a 'scope. that solved the very rare missed lap.
Steve Lang
