This motor came to me in a slot car parts lot, but the plastic case seems to suggest it's from a toy car, probably a battery-op from the '60s. Any ideas what car or other vehicle or manufacturer it belongs with? Measures about 1.25" wide by 1.25" long by 7/8" thick.
What toy motor might this be from?
Posted 09 July 2020 - 03:49 PM
Posted 11 July 2020 - 11:26 PM
Pop the gray case off that sucker Ed.
racing around Chicago-land
Posted 12 July 2020 - 09:38 AM
Are those actually little bolts holding the bushing in in picture #2?
Posted 13 July 2020 - 06:29 PM
They are not real bolts Mike, just fakes molded into the casing. Turns out the motor is no longer working, I tried it on 3 and 12 volts with no response. Larry, the casing would probably need to be cut apart, as it looks like it's factory glued together securely.
Posted 13 July 2020 - 10:50 PM
Robbie the Robot? One battery, or maybe two....
Posted 13 July 2020 - 11:15 PM
Looks like a plastic case with a motor inside. f it's not working crack it open like Larry suggested.
???-2/31/23
Posted 13 July 2020 - 11:16 PM
Or not. Either way you have nothing to lose.
- Ramcatlarry likes this
???-2/31/23
