For the guys smarter than me, I need an allen driver
24 replies to this topic
#1 MattD
MattD
  • 2,804 posts
Posted 23 July 2020 - 10:18 PM
I need a driver for the allen head machine screws that fit the outside tapped holes in the fk 180 motors.   I need to know the proper size to fit those little metric machine screws.   Anybody know the size?
thanks
Vintage Cox Slot Cars
#2 Ramcatlarry
  • 2,687 posts
Posted 23 July 2020 - 10:48 PM
whose screws?  Some are .050" and some are std 5/64"...or even 2mm.
Host 2006 ISRA/USA Nats
#3 BrettC
BrettC
  • 28 posts
Posted 23 July 2020 - 10:52 PM
The driver bit for them should be 1.5 mm.
Brett Chalmers
#4 MattD
MattD
  • 2,804 posts
Posted 24 July 2020 - 09:18 AM
I buy these screws in bulk and they are called M2 and are followed by the length, like M2X1 1/2.   Here is a picture to show the common screws.
Bottom driver is for self tapping allen motor can screws.   Middle driver is for set screws in wheels and gears.   Top screw is the machine screw that fits the outside holes in the FK 180 can.  It is the M2 size that I need a driver for.
#5 MattD
MattD
  • 2,804 posts
Posted 24 July 2020 - 09:20 AM
Larry when I look at drivers, I can't find one that says" this fits an M2 allen screw".   The last one I ordered that said 2m was way too small and I decided to not waste any more money unless I know I am getting the right size.
#6 Eddie Fleming
  • 1,631 posts
Posted 24 July 2020 - 09:59 AM
JK part # JK-80422 or new # JKL12
1.5MM
#7 bradblohm
bradblohm
  • 357 posts
Posted 24 July 2020 - 12:19 PM
https://www.professo...t-p/nsr4411.htm
Brad Blohm
#8 MattD
MattD
  • 2,804 posts
Posted 24 July 2020 - 01:45 PM
Thanks Brad.    I've looked at the PM website several times to try and find a driver with no luck.   I guess you had to make the website to know where to look!!!
I ordered a 1.5 from Amazon Prime this morning and it should be here tomorrow.
thanks guys
#9 bradblohm
bradblohm
  • 357 posts
Posted 24 July 2020 - 02:03 PM
Your initial point though is spot on.  Not enough use the three methods of referring to size.  I just remember NSR calling out M number, metric, and imperial.
Brad Blohm
#10 MSwiss
  • 23,029 posts
Posted 24 July 2020 - 02:07 PM
That link is very confusing, Brad.
.035" or .9MM is not what you would use with 2MM motor screws.
It is way, way too small.
Like everyone else posted, it's a 1.5MM.
The .035" one I have, is the size you take Slot-it wheels, off and on, with.
  • Jason Holmes likes this
#11 Dave Crevie
  • 2,274 posts
Posted 24 July 2020 - 03:01 PM
Plus you run into the problem of every fastener manufacturer not using the same specs. Technically, the ASTM specs for hex size are what we are supposed to be using, but then ISO got involved, and being European based, they didn't necessarily like what we Yanks were using for metric size tolerances. So things got a little balled up. My position as GM at a very large manufacturing concern put me in the middle of it all. Quite often we had to go to a different supplier for screws when our usual supplier was OOS. Then we found that the allen tips were rounding off at the specified torque. After sorting this all out, we ended up keeping different sets of wrenches, each purchased from the supplier of the screws. All that being said, while racing 1/32 home set cars with a club, we found that the Wiha wrenches were stripping out in the Slot-it set screws. The wrench's from Professor Motor lasted much longer. Likewise, I found the Koford and JK wrenches held up best for the 4-40 set screws in 1/24th gears and wheels.
  • Rotorranch likes this
#12 bradblohm
bradblohm
  • 357 posts
Posted 24 July 2020 - 05:59 PM
Yes Mike, I should have linked him to the proper tool he was looking for.  I just wanted to show Matt there were some tools on the PM website that listed all sizing methods.  And, as Dave points out, sizing and tool quality varies.  For me, in plasticar-land I like the NSR tools, and Sloting Plus are good, and in commercial-land it's old Parma tools and various "industrial-grade" items.
Brad Blohm
#13 BrettC
BrettC
  • 28 posts
Posted 24 July 2020 - 06:15 PM
for SlotIt, it is listed at .9 mm, but I’ve found the tile rounds off fairly quickly, and ha been using a .95 mm, and finds it fits perfectly.
for wheels that go on a 1/8 th axle, the bit size in metric is 1.3 mm.
Brett Chalmers
#14 Rotorranch
Rotorranch
    What's a title?
  • 1,390 posts
Posted 24 July 2020 - 06:26 PM
The correct screw would be a M2x3, or M2x4 if has a thick motor plate.
Depending on the screw used, it could be 1.4mm, 1,5mm, or 0.050in. Maybe even 2.0mm depending on the screw head.
Lots of options.
Rotor
Jeff Chambers
                                         "Kinky Kar"
#15 Bill from NH
  • 11,228 posts
Posted 24 July 2020 - 07:22 PM
When I bought M2 screws, I bought hex head. I already had a handful of different hex bit screwdrivers.
#16 Rotorranch
Rotorranch
    What's a title?
  • 1,390 posts
Posted 24 July 2020 - 07:55 PM
I use M2 stainless steel M2 button screws. They will work with a regular 0.050 wrench. I buy them 100 at a time. I think Pablo will agree.
Rotor
Jeff Chambers
                                         "Kinky Kar"
#17 MSwiss
  • 23,029 posts
Posted 24 July 2020 - 08:04 PM
See his post #4.
If he had .050" ones, he wouldn't of needed a wrench.
I sell a lot of my CR018 cap head screws, because it has a deep socket, with a sharply defined end, that won't strip out when using a ball end (1.5MM) wrench.
They are also made of a steel alloy that is stronger than stainless.
#18 MattD
MattD
  • 2,804 posts
Posted 24 July 2020 - 08:32 PM
I use the .050  wrench  for self tapping allen head screws in the un-tapped center hole in the motor can.   I also have M2 machine screws that fit the threaded side holes and that is the driver I was looking for.  They are not the same size screws.
All the different ways of describing the size is what made it hard to figure out what I needed.
#19 MSwiss
  • 23,029 posts
Posted 24 July 2020 - 09:10 PM
On the self-tapping, .050" or 5/64" ?
The Parma and JK self tapping screws use a 5/64" wrench.
#20 MattD
MattD
  • 2,804 posts
Posted 24 July 2020 - 10:03 PM
My mistake Mike, the 5/64 is the self tapping screws.
#21 Ramcatlarry
  • 2,687 posts
Posted 24 July 2020 - 10:28 PM
I retap my metric motors to 4/40 so I can use my 5/64" motor wrench. No confusion, no problems.  My stainless screws work all the time.
#22 MSwiss
  • 23,029 posts
Posted 24 July 2020 - 11:56 PM
Larry, I think you meant 2-56.
A 4-40 cap head is huge, and uses a 3/32 hex wrench.
  • Ramcatlarry likes this
#23 MattD
MattD
  • 2,804 posts
Posted 26 July 2020 - 03:24 PM
The driver is labeled 1.5 and screws are called 2mm.    This driver is what I needed, thanks for the help.
Larry if you tap the cans, do you worry about metal bits in the can?
  • MSwiss likes this
#24 MG Brown
  • 6,638 posts
  • Location:The Land of Lincoln, where governors make the license plates.
Posted 26 July 2020 - 04:29 PM
I prefer WIHA drivers and they can be purchased directly from WIHA (Willi Hahn Corporation - A Subsidiary of Wiha Werkzeuge Gmbh Schonach Germany) or Granger, Zoro, Fastenal, Allied Supply Company and others.
Do yourself a favor and buy a set of the hex drivers and a carrying pouch. One set of Metric and one set of Inch. If you're feeling flush, their nut drivers are handy too.
“A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.” - Douglas Adams
#25 Ramcatlarry
  • 2,687 posts
Posted 26 July 2020 - 06:13 PM
Nut drivers are really handy for the retro front axle nuts and controller repairs.
