Controller power transistor
Posted 02 August 2020 - 09:01 PM
Posted 02 August 2020 - 09:28 PM
Without specific controller brand ID, the answer is a positive - maybe. The transistor controller design has used both PNP and NPN polarity.
racing around Chicago-land
Posted 02 August 2020 - 10:32 PM
Posted 03 August 2020 - 06:48 AM
Earl, what are you trying to accomplish with your question? Transistors have different amperage, wattage, polarity as well as different drive characteristics that will affect how they react.
Racers would occasionally throw in low amperage versions of my silver TO-3 transistors and then wonder why they would blow or overheat.
I currently use 2) TIP35-C transistors in my newest design, and leave the part numbers on them. The higher wattage and amperage, compared to my original silver transistor, has definitely improved my controllers reliability.
- triggerman, Ramcatlarry, Jason Holmes and 4 others like this
Jim Difalco
Difalco Design
3075 NE Loquat Lane
Jensen Beach, FL 34957
(772) 334-1987
askjim@difalcoonline.com
Posted 03 August 2020 - 11:54 AM
Posted 03 August 2020 - 12:59 PM
I had a SK smile and the red and black wire going to the Power Transistor , so I assume the Power Transistor shorted out and since the wires are thin they took the brunt , thanks Jim
SK USES THE SAME TRANSISTOR AS dIFALCO
- Rob Voska likes this
John Chas Molnar
" Owner / Sponsor, TEAM JERSEY-TEAM AUSTRALIA
Posted 03 August 2020 - 02:01 PM
Not sure if the SK transistor is THE SAME as mine but it does work as a replacement. Part DD830 @ $17
Jim Difalco
Difalco Design
3075 NE Loquat Lane
(772) 334-1987
Posted 03 August 2020 - 02:46 PM
Posted 03 August 2020 - 07:43 PM
No, there most likely was a short on the track.
What symptoms does your controller have? Do you get any power on the wiper bands or just at full power?
Jim Difalco
Difalco Design
3075 NE Loquat Lane
(772) 334-1987
Posted 04 August 2020 - 01:10 PM
Posted 04 August 2020 - 01:18 PM
Whatever fusing system he has may not have worked properly which is why the wires are burned. You are going to need to replace the wiring and probably the transistor
Jim Difalco
Difalco Design
3075 NE Loquat Lane
(772) 334-1987
Posted 04 August 2020 - 02:28 PM
Posted 05 August 2020 - 11:08 AM
got that from the builder Jim. he said its a perfect fit
John Chas Molnar
