JK Products Floating Body Mount Set
15 replies to this topic
#1 JK Products
JK Products
  • 205 posts
Posted 10 August 2020 - 11:43 AM
Introducing our newest product. In stock, of course much lower cost than the competition with equal or higher quality. Only $3.5 for a set of 4 or $16.79 for 6 sets.
  • Tex, Pete L., cdtanner and 7 others like this
Tim Homola
JK Products
#2 Shruska55
Shruska55
  • 359 posts
Posted 10 August 2020 - 12:17 PM
For new racers, myself being one, are these for hardbody mounts?
Thanks,
Scott
Scott Hruska
East Texas
#3 Dan Searcy
Dan Searcy
  • 179 posts
Posted 10 August 2020 - 02:51 PM
Sorry for the dumb question, but how are they mounted on a chassis?  Any photos a a set mounted?
Dan
Dan Searcy
#4 Jay Guard
  • 2,840 posts
Posted 10 August 2020 - 03:49 PM
The longer piece goes through a hole (slightly larger than the small portion) in the the outside vertical part of a side pan.  Then you put the small piece over that from the inside and solder it to the longer piece.  Depending on how large you make the hole in the pan and how snuggly you put the inner piece on will determine how much "float" your body will have.  These are generally referred to as floating body mounts.  They can of course just be soldered solid to the pan if you don't want them to float.  It might be possible to use these for hardbodies but the typical use is for lexan bodies.
  • NSwanberg and Dan Searcy like this
#5 MSwiss
  • 25,899 posts
Posted 10 August 2020 - 04:06 PM
Thanks,
Scott
Scott,
The below is a typical chassis they would be used in.
#6 Shruska55
Shruska55
  • 359 posts
Posted 10 August 2020 - 06:55 PM
Thanks Mike,
It's a flexi chassi, but is it used to run hardbady and this a hardbody mounting system?
I don't have enough 21st century experience to see an advantage to floating a lexan body.
Scott
Scott Hruska
East Texas
#7 Bill from NH
  • 14,745 posts
Posted 10 August 2020 - 07:11 PM
Scott, that chassis is too wide to fit most 1/24 & 1/25 hard bodies.  Most lexan bodies are wider. Think of hard bodies being around 3" wide, lexan bodies about 3 1/8" to 3 1/4".
  • Shruska55 likes this
#8 MSwiss
  • 25,899 posts
Posted 10 August 2020 - 07:13 PM
Scott,
Not to say it could be implemented for a hardbody application, it's mostly for Lexan® bodies on Flexi style, stamped chassis.
Flexi chassis already have movement, so it's seems redundant, but I never raced this type car serious enough to see if it would make a difference.
These can also be used with chassis with non plated aluminum pans, to be able to use body pins, instead of clips.
  • cdtanner and Shruska55 like this
#9 Shruska55
Shruska55
  • 359 posts
Posted 10 August 2020 - 10:32 PM
Aha!
Mike,
The light bulb went off when I saw "body pins, instead of clips"...
Bill,
I've got a couple of Pro-Track hard body chassis and that's what partly confused me. Those are substantially narrower than my Ti22s!
Thanks for the detailed explanations.
Scott
Scott Hruska
East Texas
#10 team burrito
team burrito
  • 2,202 posts
Posted 10 August 2020 - 10:34 PM
Maybe when bodies were .010" thick or more; since most bodies are .007" & even .005" thick, a floating body mount would be overkill.
I do have a problem with DTM bodies; they have zero side flex & that kills the handling.
Russ Toy (not Troy)
#11 Tim Neja
  • 6,840 posts
Posted 11 August 2020 - 10:52 AM
This works on flat track retro cars as well.  Nice simple design for flexi cars though-- pretty slick Tim-- I'll try a package when I can get them for my flexi cars.
  • JK Products likes this
#12 MG Brown
  • 7,891 posts
Posted 11 August 2020 - 02:29 PM
I thought I would mention that some rules mandate .010" thick bodies so I assume that this would help.
#13 Dan Searcy
Dan Searcy
  • 179 posts
Posted 12 August 2020 - 12:31 AM
Got it.  Thanks
Dan Searcy
#14 usadar
usadar
  • 1,214 posts
Posted 16 August 2020 - 01:54 AM
Although, they are produced by Red Fox, Kamo uses these floating mounts for his new Retro chassis.
  • cdtanner, Tim Neja, eshorer and 1 other like this
Haruki Kan
Retro Tokyo
Retro Tokyo
Retro Tokyo on Facebook
#15 eshorer
eshorer
  • 905 posts
Posted 17 August 2020 - 06:21 PM
Haruki: Are those soldered pieces in front of the pin holders for keeping the body from curling in on top of the chassis? Or?
Eddie
Team Boola (circa the '60s)
#16 tonyp
  • 15,325 posts
Posted 17 August 2020 - 08:59 PM
It’s a stock car chassis. Keeps the body from hitting front tires in the corners.
  • gascarnut and usadar like this
