Designed with input from several top level racers, including multi-time National and World Champions, this pit caddy is designed for racers looking for an efficient, versatile pit caddy, that's lightweight and compact, so it's easy to pack for traveling.
The JCR Pit Caddy has accommodations for two wrenches, such as two tire wrenches, or a tire wrench and a guide nut tool. The wrench holes will accommodate Hudy, JK and other wrenches up to 15mm in diameter, including guide nut tools from JK and Sampson. It will also hold two axles, with gears and/or tires. This is perfect for having spare tire/axle sets ready to go and easily accessed if needed. In fact, the wrench and axle holders are oriented so that they are lined up for a tire change. Wrench to remove old tire, axle set with tire and a wrench with new tire. Plus another axle/gear set in case you strip a gear.
There's also a removable "bottle holder." For ISRA-style racing, where you are not allowed to work on your car between heats, the "bottle tray" is easily removed, freeing up additional space in the caddy to place your worn out tires/axles during a tire change. For USRA and local club racing, easily install the "bottle holder" to hold your braid juice and bushing/bearing oil bottles, and still have room to store additional parts in the caddy opening.
Versatility was one of the top design goals with this Pit Caddy. Along these lines, we designed a removable bracket that can be used to hang the Pit Caddy from the side of a track. This bracket should fit most tracks, and is easily removed and stored inside the Pit Caddy when storing in your box.
Speed and ease of use were also at the top of the design goals. Even the slot that holds the lane stickers is designed to securely hold them, while making it easy to insert them into the slot. Provisions have also been made to hold two pairs of braid and extra body pins.
Lastly, there's a walled-off area with a ramp, designed to store extra axle spacers. The ramp makes it easier to slide the spacers up the wall with your finger, making it faster to get to.
All of this, and a lid that snaps on, to securely store everything in a nice, compact easy to store box.
Available in several colors to match your color scheme!
Price: $24.99
Check out this item, as well as several other products I've designed at: JCRProducts.com.
