I want to build a custom armature that will basically be just like a Pro-Slot Big Dog (same wire specs and timing) but have a much longer armature shaft. So I talked to John at Pro-Slot and he told me that they don't sell the components to make your own arm. So my questions are these:
1. Is there a supplier where I can buy the raw components for building such an arm? Basically what I'd need are JK Hawk and or Pro-Slot Euro spec parts for my stack. Eventually I'll need the com components as too.
2. If the answer to 1 is no, I have a couple of unused PS-FK arms that hopefully I can use as donors. Is there some kind of stripper than can be used to both remove the powder coating and to break the epoxy bonding them together?
These both are probably pretty dumb questions but its my first foray into motor building.
thanks,
Larry
