Brushless motor
31 replies to this topic
#1 bbr
bbr
  • 2,429 posts
Posted 25 February 2021 - 12:58 PM
  • Tex, Phil Smith and Rob Voska like this
Mike Low
#2 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,628 posts
Posted 25 February 2021 - 12:59 PM
Mike
Any more info?
Cheers
Faster then, wiser now.
#3 bbr
bbr
  • 2,429 posts
Posted 25 February 2021 - 01:02 PM
No, just found this post by R Mack.
Game changer?
Mike Low
#4 Revtor
Revtor
  • 191 posts
Posted 25 February 2021 - 01:26 PM
I think this was discussed a year or so ago, and the general consensus seemed to be extra weight for no real advantage.
May be cool as a class in its own, Im sure there is some tweaking possibilities with that speed control and tuning etc. You just feed the track full power and use an RC controller to run the thing.
~ Steve Maietta
#5 Half Fast
Half Fast
  • 2,628 posts
Posted 25 February 2021 - 02:55 PM
This does not look particularly heavy
Cheers
#6 John Streisguth
John Streisguth
    Johnny VW
  • 5,638 posts
Posted 25 February 2021 - 03:04 PM
That would be interesting, being able to stand anywhere around the track instead of being stuck at a crowded control panel.
"Whatever..."
#7 bbr
bbr
  • 2,429 posts
Posted 25 February 2021 - 03:20 PM
The tech has been driven by the rc drone hobby. The radio gear is very lightweight now, and the price is low. Will be fun to see how it pans out for slot racing.
Airtonics, Futaba controllers and motors that never wears out, laptop tuning of speed controller.
Second channel for active air control?
Digital type racing with lane changing?
  • Half Fast and Vlado Yankov like this
Mike Low
#8 Bags
Bags
  • 567 posts
Posted 25 February 2021 - 06:33 PM
If that is a sensor less brushless motor I have the switch to make it work off of track power with a slot car controller. Wonder what it weighs?
Tom Bagley
#9 gotboostedvr6
  • 2,321 posts
Posted 25 February 2021 - 06:58 PM
Maximum switching rpm might be an issue.
David Parrotta
#10 gotboostedvr6
  • 2,321 posts
Posted 25 February 2021 - 07:05 PM
Poles in a 3 phase brushless motor refer to the total number of magnets, not the stator teeth like a brushed motor.
2 pole motor is typically limited to 160k rpm, 4 pole 80k,6 pole 60k, 8 pole 40k ect.
That brushless outrunner motor is likely between 6 and 14 poles
David Parrotta
#11 Bags
Bags
  • 567 posts
Posted 25 February 2021 - 08:11 PM
Here is a fully functional brushless road course car. With this setup you use the standard resistor controller. No R/C controller, no hot track and the braking system works.
  • NSwanberg, bbr and Keep It In The Slot like this
Tom Bagley
#12 bbr
bbr
  • 2,429 posts
Posted 26 February 2021 - 12:00 AM
here we go, some hardware to try:
Mike Low
#13 MSwiss
  • 25,899 posts
Posted 26 February 2021 - 12:09 AM
I ran the picture by someone who knows quite a bit about brushless motors
Their reply;
"It looks like an outer rotor brushless motor.  I doubt that it would work well at all.  It wouldnt be able to run at very slow speeds, when you let off there will be a delay before it will respond (because it is sensorless and needs to go through a starting routine each time you let off of the controller completely, also being outer rotor it will not start or stop very fast due to the high inertia.
I think it would be slow, also not very smooth."
#14 gotboostedvr6
  • 2,321 posts
Posted 26 February 2021 - 09:50 AM
Once it's moving the starting procedure will not occur again until you stop.
David Parrotta
#15 gshdralph
gshdralph
  • 29 posts
Posted 26 February 2021 - 04:20 PM
How much does this car weigh?
Ralph Bonin
#16 MSwiss
  • 25,899 posts
Posted 26 February 2021 - 05:52 PM
IIRC, he said the whole setup, (motor, "switch", and wires) weighs 60 grams.
Here's the thread;
http://slotblog.net/...y/?fromsearch=1
#17 crazyphysicsteacher
crazyphysicsteacher
  • 364 posts
Posted 01 March 2021 - 11:05 AM
Um, so every track call or time some idiot falls off in front it would need to restart. That would be pretty often for some classes.
Chris Wendel
Silver Side Down Racing
Silver Side Down Graphics
#18 Phil Smith
Phil Smith
  • 3,582 posts
Posted 01 March 2021 - 01:02 PM
Do RC cars, planes, quads, etc. suffer from these issues? I don't know but I can't imagine that they do.
Phil Smith
???-2/31/23
#19 dickytenkids
dickytenkids
  • 17 posts
Posted 01 March 2021 - 02:49 PM
the car (my one ) weighs less than my 1/24 eurosport (4 grams ) its as fast speed wise ,but have only run it on full rc gear ,i need one of your switches to run it as i want with a normal hand controller . to run it as it is now will need a fair bit of esc setup its very twitchy ,will need soft start and brakes will need backing off as it stops dead ,all stuff a normal hand controller can handle ,and the startup bleeping evertime it stops is infuriating
  • bbr and Keep It In The Slot like this
Richard Mack
#20 Phil Smith
Phil Smith
  • 3,582 posts
Posted 01 March 2021 - 03:08 PM
Hey Richard, the link in your signature  doesn't work. http://www.mackslotracing.co.uk/
Phil Smith
???-2/31/23
#21 bbr
bbr
  • 2,429 posts
Posted 01 March 2021 - 03:09 PM
Richard,
So what are the hardwares you are using?
Motor
Esc
Receiver
I am looking at using this
Mike Low
#22 MSwiss
  • 25,899 posts
Posted 01 March 2021 - 03:10 PM
Interesting.
Any lap time comparison?
Assuming you don't have any video, could explain start up "bleeping", in more detail, for us not familiar with these motors?
#23 dickytenkids
dickytenkids
  • 17 posts
Posted 01 March 2021 - 03:58 PM
havnt been on here for a few years ,website should get going again soon
motor is sunnysky 1106 8000kv motor ,20 amp micro esc and frsky micro reciver
will post when ive got something better going
guessing it will be somewhere between open 12 and eurosport speed
i think the handling may loose out as the motor is not spinning as fast as a brushed slot motor thats running 8-1 gearing
  • bbr likes this
Richard Mack
#24 dickytenkids
dickytenkids
  • 17 posts
Posted 01 March 2021 - 04:03 PM
if power is cut the motor has to go through a procedure to start again ,its sort of a safety feature to help not getting your fingers chopped off by the propellers,with bags system this doesnt happen only put this together to see if the motor would be fast enough.
Richard Mack
#25 Phil Smith
Phil Smith
  • 3,582 posts
Posted 01 March 2021 - 06:37 PM
This link works: http://www.mackslotracing.co.uk/ Your sig has http://www.mackslotracing.com
Phil Smith
???-2/31/23
