Why do you use a power resistor in drag motors?
Why use a power resistor in drag motors?
Posted 14 June 2021 - 02:25 PM
Posted 14 June 2021 - 03:04 PM
Interesting question. I never used one in my drag motors. Maybe to tune the max voltage down for bracket racing?
Posted 14 June 2021 - 03:14 PM
Guys do it to slow the cars down, to shoot for better consistency when bracket racing.
- John Luongo likes this
Posted 14 June 2021 - 07:36 PM
They also put them on to keep the motor alive longer. The no endbell motors don’t like the 16.2 volts the drag strip have for power.
Keep em green!
Bags
Posted 14 June 2021 - 08:13 PM
Posted 15 June 2021 - 05:34 AM
years ago i ran brackets with a 40 ford coupe body mounted on an old whisper-jet rental car set up. bored out an O ring 1/2" front wheel and made it a drive pulley. that 36D made for a VERY consistent bracket racer. also very slow. my race prep was to clean all the goop on the starting lane for smoother take offs. would beat grp 7 cars. their light wouldnt go green until i was within 1 1/2ft of the finish line. they had to fine tune their dial-in time, then they would break out. lots of fun, but made them crazy. best regards
Posted 15 June 2021 - 09:28 AM
Mike is correct. The resistor tones down starting line torque which breaks the tires loose. Tire spin makes consistancy more difficult.
In bracket racing a low E.T. is not that important. What is important is the the car run the exact same E.T. every run. Plus a slower car tends to make the driver of a faster one red light. He is anxiously waiting to go, why you car is already half way there.
Posted 30 June 2021 - 12:52 PM
In addition to the above responses about slowing cars and reducing tire spin, I have noticed two other reasons that resistors are popular in bracket drag racing:
1) More consistency in back to back runs. In the later rounds when you have less and less cool down between rounds, I have found the resistors can help by reducing the slowing of the car after repeated passes.
2) Tuning to a 60 ft time. Resistors are also useful for fine tuning a cars 60 ft time. A lot of the better slot car bracket racers find a 60 ft range where they hit the tree with the most consistency. By using different sizes of resistors, one can tune a car's launch to match the range where you are most consistent on the tree.
Posted 30 June 2021 - 05:30 PM
I imagine bracket racing is by far the most popular type of commercial slot car racing, so obviously there's something about it that's very enjoyable. But I personally don't really understand the appeal. Is there any other form of racing that you intentionally make your car slower?
That said, I really like vintage drag slot cars and have accumulated quite a bit of it over the last 3 or 4 years.
???-2/31/23
