Hi All,
With COVID and other issues causing significant down time between races for me, I've run into the issue of tires drying out. I've searched the blog for solutions and there are a ton of options from home-made to commercial products. A member of our club has recommended Mary Kay Silky Hands because it has lanolin in it which is a moisture absorber, but I know not a MK reseller. One thing I have discovered while looking around is that lanolin is a common denominator for many of the home-made products using things like sun tan lotion or hand creams.
I did have some limited luck doing the following: Apply Goo Gone, then using my Food Saver, put them under vacuum for 24-48 hours. Repeat up the 3 times maximum. I say 3 times under vacuum because more than that, tire and hub separate from the combo of moisture and pull of the vacuum. My preferred solution is to use a jar of 100% lanolin that I have for dry hands and badly chapped skin. By itself it is far too tacky to massage into a natural rubber slot tire.
My question for the forum is this: What, if anything, could I use to dilute the lanolin sufficiently to allow it re-hydrate dry tires all the way to the hub so that I can then true them up? A small jar of lanolin runs between $10-18 and diluted would probably last beyond what's left of my racing days.
Thanks in advance!
Scott H
Frankston, TX
