JK Enterprise Guide Flag
6 replies to this topic
#1 JK Products
JK Products
  • 203 posts
Posted 09 November 2020 - 01:37 PM
Supply will be a little tight for a few weeks but she's available now.
  • team burrito, NSwanberg, glueside and 2 others like this
Tim Homola
JK Products
#2 JK Products
JK Products
  • 203 posts
Posted 09 November 2020 - 01:41 PM
The blade is 1.1" long, maximum 0.10" wide so they are not currently legal for IRRA rules.
Tim Homola
JK Products
#3 Jesse Gonzales
Jesse Gonzales
  • 621 posts
Posted 24 December 2020 - 05:31 PM
I have not mounted many of the Red Fox guides I have modified so I'll be ordering six of the standard deck plus six of the cut down deck units from Tim soon. One question, do they hold up to extreme heat from hot braid? as in will I need to place a layer of polyamide film on the bottom?
Jess Gonzales
#4 old & gray
old & gray
  • 889 posts
Posted 24 December 2020 - 05:59 PM
... One question, do they hold up to extreme heat from hot braid? as in will I need to place a layer of polyamide film on the bottom?
Jess Gonzales
I have found this guide increased the speed so much I had to fit a liquid cooling system to prevent melt down. It works best with a water glycol mixture and a two check valve system to circulate the fluid. /s
  • team burrito, Half Fast, Eddie Fleming and 1 other like this
Bob Schlain
#5 glueside
glueside
  • 385 posts
Posted 25 December 2020 - 06:28 AM
Jess Gonzales
Raced everything from Group 27s to Womps and never had the issue of hot braid do anything to the guide.
They will hold up to what ever you throw at them.
Jeff Strause
#6 Jesse Gonzales
Jesse Gonzales
  • 621 posts
Posted 25 December 2020 - 06:56 AM
water cooling in PC's is very nice until the water block leaks. I'm sure these will function just fine on air.
Jess Gonzales
#7 old & gray
old & gray
  • 889 posts
Posted 25 December 2020 - 01:20 PM
Years ago I designed liquid cooling systems for electronics. I had a call from a mechanical engineer who was very excited about an idea he had to solve the BTU per square inch problem he had been handed. After many hints and a NDA he reveled he was designing a cooling system for electronics which would flood the boards with silicon fluid but he needed a pump and heat exchanger. His plan was to patent the concept but he was very disappointed when I told him he was on solid engineering footing as I had been proving similar systems to my customers for five years.
  • team burrito likes this
Bob Schlain
