Removing Hudy drum shaft?
4 replies to this topic
#1 swodem
swodem
  • 1,176 posts
Posted 20 January 2023 - 11:18 PM
Does anyone know how to remove the steel shaft from the aluminium drum?
Is it cemented in?
Retaining compound?
Has it been sweated in?
I don’t think it’s threaded in.
I need to remove this for a project.
Steve Meadows
#2 Pablo
  • 18,467 posts
Posted 21 January 2023 - 10:13 AM
Unscrew the allens that secure the pulley and the one that secures the drum to the shaft. Remove one of the side panels (I forget which one) and it comes out. The shaft is not glued or threaded to the drum. It should tap right out.
#3 gotboostedvr6
  • 2,321 posts
Posted 21 January 2023 - 02:09 PM
I’ve handled maybe 200 of them and youd think I would know by now…
Actually, there’s three distinct drums that Hudy has produced. Not sure if the attachment is different but the drums sure are.
David Parrotta
#4 gotboostedvr6
  • 2,321 posts
Posted 21 January 2023 - 02:17 PM
It’s likely pressed in based on how wide the mating surface is
David Parrotta
#5 swodem
swodem
  • 1,176 posts
Posted 21 January 2023 - 05:09 PM
I’ve given it some pretty solid taps with a hammer but it doesn’t seem eager to budge
I don’t want to hit any harder for fear of distorting the drum
I’ll try a press
Steve Meadows
