Once I took a good look at this chassis it was easy to see that outer 3 rails on each side were added at a later date. They were not cut flush with the original chassis and generally kind of uneven, and not of the same standard.
I unsoldered them cleaned up what remained and exposed a nice narrow F1 car chassis ready for any number of bodies that will need TBD.
It's always nice when you get a hunch and it turns out to be a well made chassis. Happy with this one.
Not sure if it's that old? Can somebody date those wheels for me. I guess those could have been changed though?
You are correct Larry, so I got rid of 6 of them.
Your also correct Bill,
all my original U.K. cars were taped on. But in the case of an open wheel car it's easy enough to punch an axle hole with a slit to slip over the axle tubes at the rear and the axle supports in the front. It will never be raced in anger so if it stays on for some practice laps I will be satisfied. If that does not work, there is always tape. We shall see.
