Parts bin abomination
27 replies to this topic
#1 Mad Mark
Mad Mark
  • 784 posts
Posted 03 December 2024 - 09:56 PM
got bored and felt like tinkering. I saved this hacked up super old classic chassis that should have been tossed out (I dont throw out any slot car stuff) and pieced this together.
tyco motor with I think some sorta different arm? thats also epoxied. the other tyco motor I have has blue lams and green arm wire. this is a very early classic chassis that doesnt have a drop arm recess so it doesnt sit flush with the bottom of the chassis so I made my own for max low cg. parts bin junk wheels and tires. E6000 currently drying on the pin tube body mounts.
  • Tex and Fergy like this
Mark Haas
#2 Mad Mark
Mad Mark
  • 784 posts
Posted 03 December 2024 - 09:57 PM
previous owner didn’t think the already flimsy beer can chassis wasn’t light enough so copious amounts speed holes where added
  • Fergy, Rob Voska and Samiam like this
Mark Haas
#3 Ramcatlarry
  • 2,946 posts
Posted 03 December 2024 - 11:01 PM
Silver commutator says Bonner to me.....3 VDC rated in the 1960's.
#4 Mad Mark
Mad Mark
  • 784 posts
Posted 03 December 2024 - 11:08 PM
It’s golden color I just have exposure turned up.
Mark Haas
#5 don.siegel
  • 5,858 posts
Posted 04 December 2024 - 05:55 AM
Maybe a Pittman DC65X arm - pretty common conversion at the time. Pittman arms have a typical "cap" around the wire connections, but looks like there's some epoxy on top so hard to tell.
#6 Dave Crevie
  • 4,583 posts
Posted 04 December 2024 - 10:58 AM
The motor does appear to be Bonner with the four crossways screws. If you can get it running I'd leave it as you found it. Some kind of history there.
  • Fergy likes this
#7 Mad Mark
Mad Mark
  • 784 posts
Posted 04 December 2024 - 11:30 AM
Its a tyco 951 or 952 not sure which. one is 6v and the other is 12v. Takes a bit of voltage to get it to spin up so guessing a 6v?
Mark Haas
#8 don.siegel
  • 5,858 posts
Posted 04 December 2024 - 12:06 PM
I had to look this up again, can't seem to remember which is which
Inline
901 - 6V
902 - 12V
Sidewinder
951 - 6V
952 - 12V
#9 Mad Mark
Mad Mark
  • 784 posts
Posted 05 December 2024 - 12:09 AM
Well whatever volts it is it runs terrible. is very slow and get super hot after like 5 laps on a flat track. these old non can motors seem to be hit or miss with me. They either run perfect with no fiddling or can barely make a lap.
Mark Haas
#10 Mark Onofri
  • 2,485 posts
Posted 05 December 2024 - 01:56 AM
Now I have to go to the slot car crypt.Like the Who said:
" I know what it means but"
PS: I've got six or twelve replacement arms that are genuine Tyco.Probably(6)six volt and (6) twelve volt. If you need one,pm me.
#11 Mark Onofri
  • 2,485 posts
Posted 05 December 2024 - 03:20 AM
Here's the factory propaganda.(third photo)
In the second picture,(top to bottom)
6 volt Tyco,3 volt Bonner,
?volt KKN?
The shaft is of a much larger diameter and, longer on the Bonner than the other.
{As illustrated in the first photo}.
PS: the photos posted in reverse order so, the description might seem weird after I eddditted it
  • JerseyJohn and PCH Parts Express like this
#12 Mark Onofri
  • 2,485 posts
Posted 05 December 2024 - 02:34 PM
Can you post a picture of the other side of the chassis? I'd like to see how it's mounted.
#13 Brian Czeiner
Brian Czeiner
  • 520 posts
Posted 05 December 2024 - 03:30 PM
The very roots of hot rodding. Build what you have.
  • Ramcatlarry likes this
#14 Mad Mark
Mad Mark
  • 784 posts
Posted 05 December 2024 - 03:52 PM
Mark Haas
#15 Mark Onofri
  • 2,485 posts
Posted 05 December 2024 - 03:55 PM
Thanks for the picture.
I'll re-post the propaganda, didn't realize it was that blurry. Thought it was just me.
#16 Mad Mark
Mad Mark
  • 784 posts
Posted 05 December 2024 - 03:59 PM
put my other motor in which is a 12v. not sure if this one has mods too because the magnet is different. with the square magnet the stock phenolic brush holder wont fit and the spring post is tight against the magnet. I took a messed up brush holder and filed it down and rigged up a new spring post and modded a mura motor type brush spring to fit.
Comparison with previous motor:
Also went down a tooth on the pinion to a 9. spur is higher 30s havent counted it yet
Mark Haas
#17 Dave Crevie
  • 4,583 posts
Posted 06 December 2024 - 08:52 AM
There sure was a lot of "kit bashing" going on way back then.
#18 Ramcatlarry
  • 2,946 posts
Posted 11 December 2024 - 12:17 AM
Kit bashing-  JC Whitey catalog, you could find all the parts to put a cadilac motor in ANYTHING..... :victory:
#19 Mad Mark
Mad Mark
  • 784 posts
Posted 22 December 2024 - 10:18 PM
so tested this new motor and it does the same thing. barely goes. wondering if track voltage just doesnt jive with these or something.
Mark Haas
#20 don.siegel
  • 5,858 posts
Posted 23 December 2024 - 04:55 AM
No, that is kind of curious. They're not speed demons, but should run okay on 12 volts, and they don't need a lot of amps either. Maybe the magnet needs a rezap?
  • Gary Bluestone likes this
#21 Gary Bluestone
Gary Bluestone
  • 764 posts
Posted 26 December 2024 - 05:27 AM
If it still doesn't go good after re-zapping the magnet, test the winding segments to determine each one's resistance  and that they are all unbroken.
#22 Don Weaver
Don Weaver
  • 1,858 posts
Posted 26 December 2024 - 07:44 AM
Check the windings first before spending money on re-zapping....
Don Weaver
L.H. Lapham
it will starve to death...
#23 Mad Mark
Mad Mark
  • 784 posts
Posted 26 December 2024 - 12:30 PM
What is strange is it spins up fine on power supply. guess has something to do with being under load.
Mark Haas
#24 dc-65x
  • 6,992 posts
Posted 26 December 2024 - 02:12 PM
Hi Mark,
If you removed the magnet from an "iron" magnet motor it will pretty much kill it until it is remagnetized.
Here is a link to an experiment I did on the subject:
Zapping Pittman magnets
  • Ramcatlarry and Frank Godbey like this
#25 Mad Mark
Mad Mark
  • 784 posts
Posted 26 December 2024 - 10:12 PM
Hi Mark,
That's interesting. I did have to remove the magnet because you cant remove the arm without taking off a plate that sandwiches it.
Mark Haas
