Dual motor madness!
56 replies to this topic
#1 dc-65x
  • 6,985 posts
Posted 31 October 2010 - 05:12 PM
This is another in my fantasy series of Mike Morrissey's Team Russkit "What if" cars. This time, "If one motor is good then two would be GREAT". :shok: ! Right :unsure: ???? Well, probably not :blink: since you rarely see that configuration. But I'm going to give it a shot in my best Team Russkit style that I, a regular enthusiast, can muster.
No CAD design this time, just a 6 inch scale, pencil and paper. I set up the component placement using a maximum track width of 2 7/8" with Russkit wide rear wheels. This is about as narrow as I can make the motor bracket and still fit in the 2 Cox crown gears. There are several mistakes in my sketch. Apparently I can't add....I guess that's why I like to use a CAD system :laugh2: . The overall bracket width should be 1.6" not 1.8" and the 1.6" and 1.8" dimensions in the side view should really be .6" and .8". Good thing I "measured twice and cut once" ;) .
I want to use a Russkit Ferrari 330P without having to flare the wheel wells. Here is a lovely Russkit Ferrari reproduction done by the Viceroy of Vacuum, John Dilworth:
Any who, I Duffied this neato bracket on my old Clausing mill.........
.........set everything up in my Rick's Jig............
...............started trying to bend some main rails from the motor bracket out around the wide twin motors......
.......and it was brass rod and tube CARNAGE! :shok: :blush: :laugh2:
A pound of brass later (K&S Corp. loves me) I've got a design and a pair of main rails and rear bracket bracing ready to build with:
Time to fire up the Ungar......Onward!
#2 Jairus
  • 10,174 posts
Posted 31 October 2010 - 05:34 PM
I likey!
(wish I could build one too....)
#3 Pablo
  • 18,454 posts
Posted 31 October 2010 - 06:42 PM
No spillage of flux on that workbench ;)
#4 Duffy
Duffy
  • 3,791 posts
Posted 31 October 2010 - 06:45 PM
This is another in my fantasy series of Mike Morrissey's Team Russkit "What if" cars. This time, "If one motor is good then two would be GREAT"! Right ???
You taught me something today, Rikky: keep all the bad bits--the collection of slightly-askew bends that got cut off the rod & redone--they not only make great humor shots, they're good when you do a commission run and need 128 stuffers 1/4" long, 32 teeny tiny L-braces, 64 pin-tube shims...gee, who knew?
I always learn something from your builds!
Duffy
Michael J. Heinrich
1950-2016
And I am awaiting
perpetually and forever
a renaissance of wonder
#5 Jairus
  • 10,174 posts
Posted 31 October 2010 - 07:11 PM
Makes ya sick huh P?
#6 dc-65x
  • 6,985 posts
Posted 31 October 2010 - 09:09 PM
Hi Jairus. You can build one too....I know you can build anything! You may want to wait to see if mine is a pony or a pooch :) .
Pablo. You can't use too much acid flux can you :unsure: . More is better...just like 2 motors ;) .
Sir Duffster. I'm tossing all the small brass bits. I feel I'm doing my small part to help the economy....."Buy Brass"!
With the main rails and bracket braces pre-bent the chassis went together pretty quickly. In no small part this was due to my Rick's Jig....a pin hole for everything and for everything a pin hole. I LOVE IT!. Here's the basic chassis all soldered up and covered with a quart of acid flux:
I've used extra long pieces to contact the jigs pins for alignment. They also come in handy to "drag" any excess solder away from the joints.
A little sanding off the all the "crap-O-la" and it's starting to look like something:
#7 Duffy
Duffy
  • 3,791 posts
Posted 31 October 2010 - 10:02 PM
Sure is, something. I'm making an appointment with my opthamologist tomorrow, and it's all your fault.
Duffy
Michael J. Heinrich
1950-2016
And I am awaiting
#8 Jairus
  • 10,174 posts
Posted 01 November 2010 - 10:06 AM
Rick,
You know, it you get John to wind you two identical arms.... one CCW and one CW then you can really balance things out. That way the gears can both be on the inside or out, and the car look visually balanced. Plus you get neutral torque!
Just a though... (hint, hint)
  • C. J. Bupgoo likes this
#9 zipper
zipper
  • 1,092 posts
Posted 01 November 2010 - 12:15 PM
Even mr. Spader didn't use that possibility. For some passionate retro builder something different to do...Posted Image
Pekka Sippola
#10 don.siegel
  • 5,857 posts
Posted 01 November 2010 - 12:44 PM
More inspiration Rick - or maybe anti-inspiration, depending on the case... But you inspire us as always!
#11 idare2bdul
idare2bdul
  • 5,799 posts
Posted 01 November 2010 - 12:50 PM
Bryan Warmack showed they could work.
Mike Boemker
#12 dc-65x
  • 6,985 posts
Posted 01 November 2010 - 02:30 PM
That's a beauty Jairus ;) .
Pekka, that's one wild ride. I love the way the body conforms to the motors.
Don, that's an amazing collection of "Dual Motor Madness"! Thanks for posting the pics.
Hi Mike, I don't know why but I ASSumed Bryan's was a 4WD :blink: . Now I'm more hopeful that I can get a 1966 style twin motor to work.....we'll see :) .
#13 gascarnut
gascarnut
  • 3,938 posts
Posted 01 November 2010 - 02:42 PM
Cool subject, thanks Rick!
Lots of nice photos too!
Don, don't you own one of those dual-motor flat-iron thingies? I seem to remember you posting photos once before.
Dennis Samson
Scratchbuilding is life
Life is scratchbuilt
Samson Classics
#14 don.siegel
  • 5,857 posts
Posted 01 November 2010 - 05:30 PM
Dennis,
Guilty as charged; here's the only picture I found in my archives - the car is slightly different from the one posted above, mostly in the motors. I don't know if mine is the only survivor or not. Our Swedish friends, especially Ravajack, came up with quite a bit of history on this car when the photo first appeared in scratchbuilt.com
Where does that article come from Pekka? Would love to see the rest if there are other pages.
#15 Mr. Frank
Mr. Frank
  • 1,238 posts
Posted 01 November 2010 - 05:54 PM
Them some cool rides, old and new.. Need to get some pictures up of my duel motor car and the one with 4 , yes 4 motors
TRUE 4 WHEEL DRIVE.. One motor per wheel.. COOL and FAST..
Mr. Frank
Frank Elavsky
5/20/60-2/9/12
#16 Mad Mexican
Mad Mexican
    Safer Barrier Tester!
  • 1,274 posts
Posted 01 November 2010 - 06:09 PM
Mr. Frank
Amigo Frank,
I don't think that car would be LEGAL for OCC Racing!:blink: :laugh2: :laugh2: :laugh2: :laugh2:
Adios
Javier Zavala
In loving memory of my mother Francisca Escalante Zavala
March 24, 1927 - April 5, 2011
Vaya Con Dios
#17 Duffy
Duffy
  • 3,791 posts
Posted 01 November 2010 - 06:14 PM
We definitely need an Outlaw class. --Oh, wait: we got "Lost Causes!"
Michael J. Heinrich
1950-2016
And I am awaiting
#18 68Caddy
68Caddy
    The Direktor
  • 10,546 posts
Posted 01 November 2010 - 06:25 PM
I found Warmack's dual motor car, maybe he could tell the story!
I think he build more then one dual motor, better ask him because I have a bad memory.
Nesta
- Gabriel
Nesta Szabo
#19 Rick
Rick
  • 8,844 posts
Posted 01 November 2010 - 07:23 PM
Looks like another home run at the plate Rick! Keep posting, I love to follow along.................
Rick Bennardo
"Professional Tinkerer"
scrgeo@comcast.net
R-Geo Products
Lead! The easy equalizer...
#20 zipper
zipper
  • 1,092 posts
Posted 02 November 2010 - 12:06 AM
Sorry, that's all - it's an ad from an ancient swedish book about miniracing. But it mentions an article in a swedish mag "allt om hobby" 3-68
which somebody might have (???)
Pekka Sippola
#21 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 02 November 2010 - 04:40 AM
Spotted this a while ago on a forum, but can't remember who built it.
Steve King
#22 Marty Stanley
Marty Stanley
  • 2,582 posts
Posted 02 November 2010 - 05:53 AM
My guess on the builder would be "TV Tommy Ivo"!
Back on track - Rick that is some absolutely beautiful work, as is expected. Have you ever thought of doing something like the Russkit dual motor Spyder Indy Car?
Keep up the builds, they're super!
Marty Stanley
1/24/48-2/18/16
#23 Bill from NH
  • 14,782 posts
Posted 02 November 2010 - 07:02 AM
Doug Azary, from the Tulsa, OK area, built that 4-motored GT-40. :)
#24 Champion 507
Champion 507
  • 1,521 posts
Posted 02 November 2010 - 12:46 PM
Yes, I built that car 7 years ago. If you want to read about it please click on the link. I will be happy to answer any questions.
http://getyourwebsit...gallery075.html
Doug Azary
"You want it when?"
#25 dc-65x
  • 6,985 posts
Posted 07 November 2010 - 06:44 PM
Thanks to everyone for the "multi-motor madness" input :) .
Now back to my own madness, the chassis went back in my Rick's Jig for the final 2 rails.....
....and to setup to make the drop arm. I'm using a Russkit Slant Guide so I had to use the guide to set up the angle Korrectly:
The drop arm and down stop were all left long to use the jig's pins for alignment:
Here all the crap-O-la is sanded off and ready to have "The Buff" put to it:
In keeping with my philosophy of "If it don't go, chrome it" here's the chassis with "The Buff" put to it:
A couple of details, here the main rails are "kicked out" to clear the dual motors.....
....and the drop arm up-stop hidden under the front axle tube:
Motor building time.........Onward :D
